Question about RCA R52WM24 52" HDTV Projection Television
I have a r52wm24 model rca tv that won't turn on. The power button flashes 9 times and stops then flashes 5 more times. It started by turning itself of repeatedly, then a few seconds/minutes later turning back on. How expensive is this fix?
I have the same tv i turned it off 3 nights ago and now it wont come on at all. I bought it on black friday 4 yrs ago i thought a RCA would last forever, guess i was wrong, I hope i can get a part to fix it or im going to be standing in line this black friday for another tv.
Posted on Nov 13, 2010
  • RCA Master
  • 8,617 Answers
The deflection board needs replacement. You can get the ITC222A deflection board PSB-260 from www.tvrepairworld.com which comes with instalation instructions
Posted on Aug 03, 2010
TV turns itself off, then on automaticlly
The fan should run for a few minutes after shut off to cool the lamp down.
If I read and understand correctly somewhere in the cycle you are getting 5 red blinks? that is an error code........
Either you or I can Google the model number of the set with 5 blinks.....or visit the Sony site to see what it means.....
Apr 24, 2012 | Sony KF-42WE620
My tv turned off while I was watching it, now it won't come back on but the power button on the front flashes. The button flashes 5 quick times stops for a second then 9 times, then starts over. What do...
You have an open power crcuit on one of the transistors, also the display board has probloems ( 5 flashes)
This is not DIY stuff it requires special tools and a knowledge of circuit diagram redaing and the ability to retune the boards. dor a 52" I deem t6he cost around $600.00
Please rate my help++++Thanks for using FIXYA
Jun 10, 2010 | RCA R52WM24 52" HDTV Projection Television
MY TV RCA MODEL R52WH74 WHEN YOU PUSH THE POWER BUTTON ON IT FLASHES ONCE AND THEN FLASHES NINE TIMES
CK 3 capacitors on Deflection board bootom board to he left if cp150 2200uf 16v is puffed up it is bad other 2 are 220uf 35v cp114 cp120
Nov 12, 2009 | Televison & Video
Flashes/blinks 9 then 5 won't turn on.
Check the CRTs . That model was notorious for laser like cuts right around the neck by the yoke. I just had one today doing the same thing. The CRTs are no longer available so the set is scrap. I hope that's not your case. Let me know.
Oct 20, 2009 | RCA D52W23 52" HDTV CRT TV
Remote control
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Jul 24, 2008 | RCA Universal Remote Control
52 RCA DLP 1080P Television with NO picture and buttons flash
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
http://servicemanuals.vstore.ca/
Dec 30, 2007 | RCA HD61LPW175 61" Rear Projection HDTV
Remote control code
depending on the remote you have from rogers but the newest remote has 5 device's across the top we call it a 5 button there is a 3 and a 4 and a fat 5 button that is the old pvr remote all are pretty much the same in setting up easiest way is on 5 button remotes select the device ie. tv pres and hold setup untill light flashes 3 times enter 9-9-1 the with the tv on press ch+ button untill tv turns off once tv is off press setup to lock in the code test it by pressing tv then pressing power should turn tv back on if not repeat previous steps untill you get the right code some tv models are not compatible with the rogers remote 3 and 4 button pretty much the same except insted of a setup button you have to press and hold tv and select at the same time untill light flashes 3 times press 9-9-1 then press tv button untill tv turns off press select to lock into place
Dec 29, 2007 | GRIFFIN TECHNOLOGYTotal Remote-PDA Remote...
RCA R52WM24 52" HDTV Projection Television Logo
184 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
