Question about Microsoft ZUNE JS8BRPBDLUG MP3 Player
On your pc open the zune software and restore the zune device firmware
  • 10 Answers
SOURCE: zune reset
Hi I can help you this is how. BUY A 4G ZUNE!!!!! cause your 30g zune is broken or something, or reset everything and instal it again
Posted on Jan 31, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: device firmware
http://www.zune.net/en-us/support/usersguide/default.htm
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Posted on Jul 06, 2008
Tempenema
  • 20 Answers
SOURCE: Broken zune
i get the same exact problem what i do is restart my computer and plug my zune into a diffrent usb port(i have 4...2 in the front and 2 in the back) and my back ones work fine try that and let me know if it works
good luck
~Temp
Posted on Sep 09, 2008
SOURCE: Windows 7 (64 bit) build 7000 and zune problem
i had the same problem at first with my 3rd generation zune. first you have to open up the zune software folder then right click the short cut and click run as administrator then it will detect the device and everything will work. good luck
Posted on Mar 21, 2009
  • 88 Answers
SOURCE: zune 30gb says "Connect Zune to your PC" and when
Hi if you have done this 7 times the HD is bad and will need to be replaced. I fun into this all the time with the Zune players.
If you need more help, parts or repair services you can go to my repair service web page at firehouse7777.weebly.com and find info to contact me if needed. thanks
Posted on Dec 29, 2010
I want to start over with my Zune Model 1089. I want to clear everything off of it and start over. Please help....
1. Slide the "hold" switch so that it is in the unlocked position. 2. Press the "Back" button and the top of the Zune pad at the same time and hold until the device resets and begins to power up. Release the buttons when the Zune starts to power on. 3. Immediately press and hold the "Back" button and both the left side and the center of the Zune pad and continue to hold until the Zune restarts. The phrase "Please Wait" will appear on the LCD screen. Release the buttons.
4.Let the Zune continue resetting. It will clear the contents and eventually display "Connect Zune to your PC" when it is ready.
5. Connect the Zune to your PC via the sync cable. Follow the prompts given by the Zune software to completely restore the Zune device to the factory settings. If you have downloaded newer Zune firmware, you have the option to restore the Zune firmware with the latest version.
Mar 06, 2011 | Microsoft Zune JS8-00001 Digital Media...
My 4gb zune pink wont turn on or do anything except when plugged into a pc the zune tells me to open the zune software and and restore the device firmware
If it's not doing anything else, so you should probably let the zune software do the restore. Usually doing a restore will fix any software related issues.
Mar 02, 2011 | Microsoft Zune JS8-00001 Digital Media...
Zune 30gb says "Connect Zune to your PC" and when
Dec 11, 2010 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
It keep telling me that i need to restore the zune device firmware
The "firmware" is specialized software that gets downloaded to the ZUNE.
Then, when you turn the ZUNE on, it runs that software, to control the device,
i.e., to respond to the buttons that you push, and to retrieve files from the "library" stored on it.
If that firmware gets corrupted, you must download a copy of the firmware from the ZUNE web-site, and then run the ZUNE software on your computer to download the firmware from your computer to your ZUNE.
Nov 30, 2010 | Computers & Internet
How do I restore my devices firmware for my zune 30gb
How to restore your Zune device software:------------
When you restore your Zune device software, the startup partition and the data partition are removed and rebuilt. In addition to removing the Zune device software, this process also erases all audio, videos, podcasts, and pictures that are stored on the Zune device.
Warning To restore the Zune device software, you must have a Windows-based computer that has an Internet connection. That computer must have the Zune software installed. And you must be able to connect the Zune device to a USB port on that computer by using a Zune Sync Cable. Do not perform the following steps if you do not have any one or more of these things immediately available.
After you start to restore the Zune device software, you cannot again use the device until you complete all the steps. You will not receive any confirmation or warning on the Zune device after you start the following procedure.
To restore the Zune device software, follow these steps:
1. Set the Hold Switch to unlocked.
2. Press and hold the Back button at the same time as you press and hold the top of the Zune Pad. When the Zune device begins to power up, release the buttons.
3. Immediately after you release the buttons in step 2, press and hold the following special button combination, depending on your Zune model:• If you have the 4GB Zune, the 8GB Zune, or the 80GB Zune, immediately press and hold the Back button at the same time as you press both the left side of the Zune Pad and the Play/Pause button. Continue to hold these buttons until your Zune device restarts and "Please wait" appears on the screen.
• If you have the 30GB Zune, immediately press and hold the Back button at the same time as you press both the left side of the Zune pad and the center of the Zune pad. Continue to hold these buttons until your Zune device restarts and "Please wait" appears on the screen.
Note "Clearing contents. Please wait" appears, followed by “Connect Zune to your PC."
4. After “Connect Zune to your PC” appears, connect the Zune device to the computer that has the current Zune software installed, and then update the device to the current Zune device software.
----------- Click this link directly for more troubleshooting:-- http://support.microsoft.com/kb/944909 -------- If error problem while restoring then click this link below:-- http://support.microsoft.com/kb/945278 ---------- Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 03, 2010 | Vacuums
Mar 19, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune reset
Jan 13, 2009 | Microsoft Zune JS8-00001 Digital Media...
I was having problems with my zune so i decided to click on "forget this device"now i want it back and i have no idea what to do.now i restored my zune and i cant get my computer to know my device to get...
go to zune website and redownload the zune software then try to reconnect it if this dosent work go to my computer and look for zune and try to restore from there
Dec 17, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Broken zune
good luck
~Temp
Aug 28, 2008 | Microsoft Zune JS8-00001 Digital Media...
Microsoft ZUNE JS8BRPBDLUG MP3 Player Logo
205 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
lugnuts1
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
