Question about Kitchen Ranges
Whirlpool Range burners don't stay on
I have a freestanding electric range that I purchased 1.5 years ago from Best Buy and rarely used. This is a sudden problem that began yesterday. All the burners come on , but stay on only 1 second, then go off for a minute then come on agan for a second.Whirpool wil not give any technical support at all.
I can' afford to have a repair man out. I do not know how to get at the control panel. Can you help?
I will never recommend Whirlpool.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=545111
Generic problem for all Kitchen Ranges
Posted by swetepi on Apr 25, 2008
I have a freestanding electric range that I purchased 1.5 years ago from Best Buy and rarely used. This is a sudden problem that began yesterday. All the burners come on , but stay on only 1 second, then go off for a minute then come on again for a second. Whirlpool will not give any technical support at all.
I can' afford to have a repair man out. I do not know how to get at the control panel. Can you help? I will never recommend Whirlpool.
I would advise you to ALWAYS to FIRST UNPLUG YOUR APPLIANCE before beginning any service procedure.
You may check your factory owner’s manual under the trouble shooting guide to see what is happening. Do you have a glass top or the top with metal burners?
If you have the kind with the metal burners the top in most cases are on a hinge and will lift up for service, you definitely have a short somewhere or a loose connection, check with Whirlpool’s customer service to see if they can send out a owner’s manual from the factory or check to see if it is still under a factory warranty and if it is there would be no charge. Or check with your local Whirlpool appliance dealer – sometimes they can be of some help. So if you need further assistance, please feel free to contact your local appliance dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://whirlpool.com/home.jsp
Contact Us
Hours: M-F 8am–8pm Local Market Time
S 8:30am–5pm Local Market Time
- Get shopping help
- Order parts and accessories
Call 1-866-698-2538
Thanks, Don – The Appliance Man
Go Ahead. Use Us.
Posted on May 05, 2008
Whirlpool WFG510S0AS2 range - stove burners work just fine, but both the oven and broiler does not stay lit. NOTE - this unit has been converted from natural gas to LP
when the lp conversion is done , it is normally just a jet size change that is done
however the air shroud has to also be adjusted to get a clean blue burn of the flame
The just jet change results in a slightly yellow flame which is incomplete burn of the gas and that creates carbon build up at the jet and burners causing partial blockage
I would suggest that you call in an accredited gas fitter to check the problem and if necessary , clean the jets and adjust the air shroud
Dec 30, 2015 | Whirlpool WFG510S0AS
My oven doesent work but the burners still work. what could it be
Your top burners are Sep then your oven .u have a bad element. Replace it .call repair clinic.com at 1-800-269-2609 or 1-866-822-0890 and order your part
Nov 06, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
My electric Amana Range with self cleaning oven model Art6100 or Art6000 approx. 11 years old will not work on the clean cycle. Burners and oven work fine. We had the door off and apart to clean a few days...
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Aug 28, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Glass top range is pitted and scratched from an abrasive cleanser. Can it be replaced. It is a whirlpool freestanding range about 2 years old
Yes, your glass top assembly on your range can be replace. Here is one link where you can get the part, http://www.apdepot.com/Products/PartsLookup2/IPLLookupFrames.aspx?Brand=WHIRLPOOL&ModelNo=GR399LXHS1&ImgID=EdI2&ImgFile=WTKIKKLL
It is a relatively easy job to replace the main top since the burners are not attached to the top assembly itself. Remove 2 or 3 screws on the front of the top and you can easily lift the entire top off of the range and replace it with the new top.
Apr 17, 2011 | Whirlpool GR399LXHS Electric Kitchen Range
Purchased a used gas oven yesterday. The top burners are working fine, but the oven is sooting up. We live in the country and use propane, but did not receive any additional orfice or instructions. In the...
We need a model number to be specific.
Check the gas regulator and make sure the pressure cap has been set for propane.Most of them are turned over to put more pressure inside the valve.
If so. Check the air shutter on the bake gas tube and adjust for the best color flame.
Also tighten the bake burner orifice with a 1/2 inch wrench.
Oct 03, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool 465 Surface Hot Indicator Light stays on all the time.
Most likely a faulty burner limiter switch. Not sure if they can be purchased separately from the burner element.
-Dave
http://www.appliancepartspros.com/part_details.aspx?part_id=3767588
May 31, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Broiler works, as do burners. The oven will not come on. Gas whirlpool range 2003 year. Model SF367LEKB
jdelvecchio5Does the igniter (glow bar) come on whenever the bake function is selected.?
If the glow bar does not come on the safety valve will not open - no bake burner. check the electrical harness first then Try changing the igniter (glow bar first) before changing the safety valve/regulator.
Dec 02, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Inglis electric freestanding range model #IRE3230- Oven no longer working
If the oven and the electric panel no longer work, this is an electronic problem. The burners and the oven light will not be effected, nor will the fuses. The electronics card will need to be replaced by an appliance technician.
Oct 24, 2008 | Kitchen Ranges
Kitchen Ranges Logo
169 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
