V3000 motherboard problem
Hi guys,
i facing problem with v3000 with AMD processor. laptop is getting switch on but no display. Anybody can give a solution for it. i am a technician but not able to solved problem pls help me
I have a solution and i have tries ask a technician to open the motherboard and their is dry in display chip after solder it should be ok .
Posted on Nov 21, 2008
Hey mate,
I had the same problem.
Mine started with the wireless card "disappearing" for the device manager which sometimes reappeared when I restarted but was slowly not reappearing as time wore on.
Then the computer sometimes didn't turn on, or would only turn on after a couple of attempts. It would power on, the fan would whir but the hard drive wouldn't speed up / seek and nothing would be displayed. I had another technician (I am one myself too) and he thought it might be software.
Keep in mind things not working and then working randomly is a good indication of hardware failure rather than software.
I bit the bullet, bought a motherboard for $130 AUD on ebay from China and started the rebuild.
It's easy to do. Keep in mind that your laptop is not working so you have little to lose. Start with the underside, remove all visable screws, then remove accessable components (hard drive, ram, etc) and slowly start to pry away the two halves of the bezle.
As you start to remove cables from the motherboard you will get towards the heatsink / fan. THE PLUGS AROUND THERE BECOME BRITTLE OVER TIME FROM HEAT. BE CAREFUL.
As long as you are patient and methodical you will be able to do this yourself.
Also start with the accepting belief that you WILL have to take apart and reassemble 3-4 times before you get everything right.
Best of luck
Posted on Dec 18, 2009
    President:
  • 2,351 Answers
You know how to use the [ Ask Me ] button.
I suggest you ask, mewms_1404
http://www.fixya.com/users/mewms_14904
mike
Posted on Apr 25, 2008
Where i download amd phenom x4 processor driver
i got an AMD phenom x4 9550 prossesor and i cant find anything.. not even on the AMD site.. could you guys help me?
Feb 08, 2011 | MSI 785GME51 Motherboard AMD Phenom X4...
I have a compaq presario v3000 i remove the vista now xp is running on my laptop but drivers are not working after change the os.
The model "V3000" is a generic term for a bunch of different models. To make sure you get the right drivers for your specific model, start at HP's site here and pick yours from the list. Then pick the Windows XP operating system and you'll find the drivers they have for download.
Mar 08, 2010 | Compaq Presario R3000 Notebook
Facing Problem with compac v3000 no display
First see if any monitor will work, plugged in at back? If works, check, just isn't been LCD monitor has been disabled by a key command, then if NOT work, it is probably Video card. OR actual LCD, OR the LCD power supply and/or Inverter? may also be bad connection to MB? Or Broken ribbon in lid, or case. Faulty sleep open/close LCD switch? Try those.
Mar 02, 2010 | Compaq Presario 2580US Notebook
Amd athlon heatsink
If you don't install the heat sink and fan carefully you could blow out your processor. Make sure you clean all the old heat sink paste from the processor and the heat sink. Then apply a thin layer of paste like "arctic silver" on the heat sink so that it makes full contact with the processor. I think you have a socket A processor...so do a google search for "installing a socket A processor" and you should have all the info you need. Good Luck...Hank
Jan 12, 2010 | EPoX EP-8KRA2+ Motherboard
COMPAQ V3000 AMD SEMPRON COPROCESSOR PROBLEM
If your v3000 only shows leds but no video you need to replace your GPU(graphics processor) Hp has an active recall for this problem for certains models, you can check if your v3000 qualyfing for this recall in ww.hp.com
The manner that we resolve this issue:
you need to remove your MoBo completely from your laptop, remove your heatsink and coller from your Cpu/Gpu, with a heat gun(similar to hair dryer) reheat your gpu, this will cause that your gpu re-soldering and will function very well.
If you think this is so hard to you you can send your laptop to: VCRTECH
10001 buckwood Av. 79925 El Paso Tx
We repair your laptop in 2-3 business days and we charge $80 usd for this repair.
Thanks
vcrtech
www.vcrtech.com
support@vcrtech.com
vcrtech@hotmail.com
Please give me your feedback
Apr 21, 2009 | HP Compaq Presario V3000T Notebook
Turboc3 doesnot work in my amd motherboard with amd processor
PC or laptop? socket 754 motherboard for Sempron, with the square hole in the middle with no pins in square hole?
Jan 18, 2009 | AMD Sempron 3100+ 1.8GHz 256k Socket 754...
JetwayV266b (REV: 3.00) - Max processor speed??
Design ATX form factor 4 layers PCB size: 30.5x24.4cm Chipset VIA KT266A/VT8233A Chipset CPU Socket Support AMD Athlon 700MHz∼1.4GHz processor Support AMD Athlon XP 1500+ 2600+ processor Support AMD Duron 600MHz 1.3GHz processor Support 200MHz/266MHz (Double Data Rate) Front Side Bus frequency processors Reserves support for future AMD processors 2600+ is the highest it will go. http://www.machspeed.com/manuals/VIPER/V266B.pdf page 3
Sep 17, 2007 | Jetway V266B Motherboard
Computers & Internet Logo
773 people viewed this question
David Payne
David Payne
