Question about Kenmore Washing Machines
Kenmore heavy duty model 4568291 Help! my washer seems to be working fine except it is leaking from underneath (started out just a little trickle but seems to be getting worse
  • 91 Answers
SOURCE: slow cold water only fill kenmore heavy duty 70 902202
remove fill hoses and inspected for debris or cloggs ,,,,
Posted on Jan 04, 2009
  • 64 Answers
SOURCE: Kenmore 70 series washer: leaky water pump
NEW WATER PUMP
Posted on Aug 31, 2009
mgprice
  • 744 Answers
SOURCE: kenmore washers, heavy duty 80 series, no spin
Hello, Your problem is going to be with your lid switch, this is located normally either in the control panel or about half way down on the right side under the lid. This is a safety feature to stop you opening the lid while the machine is in a high spin. Once you have located the switch trace the wires back to the wire harness in the control panel. Disconnect the lid switch from the wire harness and with an ohms meter check for condinuity on pin 1 & 3 (the 2 outside pins not the middle this is a ground) You should find you have no condinuity and should replace this switch. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Posted on Oct 14, 2009
  • 278 Answers
SOURCE: ultimate care supreme leaks underneath
First check the hoses to the machine. If they leak the water follows the hoses and drips on floor. Also check the hose connection at the washer. They will leak inside. Next it may well be a water pump going out or the plastic hose that is under pressure when operating. The pump is in the middle of machine underneth - Sorry - Good luck
Posted on Oct 16, 2009
  • 1937 Answers
SOURCE: I have a kenmore heavy duty 70 series extra
This assumes that you have a basic Kenmore / Whirlpool top load, directdrive, neutral drain (it doesn't spin until the pump removes most ofthe water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Seethe Sears site sub-components for the agitator, basket and tub. It'spossible that one of the gaskets or seals has worn over time.
I'd also pull off the cabinet and check the hoses leading to and from the pump. It's also possible that the pump is leaking.
See the following for how to remove the cabinet.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Posted on Oct 20, 2009
My washer works perfect except in the heavy duty fast/fast setting It agitates and seems to be working very hard then stops. it starts for awhile then stops again. There is also a smell of hot metal.
Double check your coupling work first then try the drum bearings by reaching in through the front and see how much movement the drum has? Does it rotate smoothly? Have you run it with the access panel off and listened close up?
Feb 16, 2016 | Washing Machines
I have a kenmore elite washer model 26962502. It makes a loud banging noise on spin and turns slowly. What has broken? Underneath it looks like two pins have come out and fallen into little plastic c
Yes , it is possible that the heavy load could have made the suspension soft or the drive shaft could have shifted or damaged.
You need to remove and check the bearing and suspension ,
click this link: Bearings
Jan 25, 2013 | Kenmore Washing Machines
Kenmore heavy duty 70 series model 110-8237012
probably your drain pump leaking it has a seal right where it attaches to motor,,,,mine is leaking there but haven't replaced it yet! lol
Feb 27, 2010 | Kenmore Washing Machines
Water not cutting off at full level and leaking-Kenmore washer 80
The water lever sensor/switch is not working and needs to be replaced. IT has a air tube that senses the water lever by pressure. It the tube is clear then the switch needs replaciing,, If they is a clog, clear it and retry before replacing it.
Feb 06, 2010 | Washing Machines
Kenmore Heavy Duty 70 Series Leaking in the back
If you bought a new washer and you still have a leak, i guess it was not the washer but where it drains into. Sink or stand pipe has a leak. unless you are useing the old drain hose from your old washer. Dry up everything and look for the sorse of water with a bright light when the washer drains .
Nov 22, 2009 | Washing Machines
I have an old Kenmore Heavy Duty 70 series washer.
its a filter inside the water hose thats still blocked or the relay inside the washer for the cold feed is not opening up fully it could just need a clean or maybe a new one fitted
Nov 05, 2009 | Kenmore 22422 Top Load Washer
Kenmore Heavy Duty Washer Leaking from bottom
Probably the drain pump seal has gone bad.
Check it for leaks.
If your floor is good and level look for water near the front center of the machine.
Feb 25, 2009 | GE WHRE5260E Top Load Washer
Slow cold water only fill kenmore heavy duty 70 902202
Dec 30, 2008 | Kenmore 22422 Top Load Washer
Speed Control only works in Heavy Duty
sound like your motor is going out ,,,, the wiring at the motor may also be loose from out of balance loads
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Washer won't agitate, spin or drain
It's not your exact model but does have some good information about the possible causes.
http://www.shopyourway.com/questions/1099421
If you need further help, reach me via phone at https://www.6ya.com/expert/sean_97e45db9c0ed1da4
Apr 07, 2017 | Washing Machines
Washing Machines Logo
94 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
