Question about Foxconn (755A01-6ELRS) (K8S755A6ELRS) Motherboard
2long 2short 2short beeps on mother board - Foxconn (755A01-6ELRS) (K8S755A6ELRS) Motherboard
    Scholar:
  • 121 Answers
You really need to go to the BIOS manufacturer's website to ensure the beep codes are the same but here is a link to a site that has some of the common codes with different BIOS manufacturers. To determine which BIOS you are running, when the computer boots up, it should be at the bottom of the screen as it initializes each device. It looks like a black screen with a bunch of lines popping up with the status of each device. The Bios will be down at the bottom left during this process. IF you have a splash screen instead you will need to interupt the bios boot process, either by hitting the DELETE button, or F1 or F2, depending on the manufacturer. Hope this helps. If not post back with the computer manufacturerer and model number and I will try and determine the step by step instructions to assist you.
http://www.5starsupport.com/info/beep_codes.htm
Posted on Aug 03, 2010
Laptop beeps 32 times on boot up
http://www.bioscentral.com/beepcodes/awardbeep.htm
maybe will help ,but try to lessen how are grouped (the beeps) thing like 1short +3 long +2short.
like if there are problems with the ram will be 3 normal beeps .
try to group the 32 beeps .
Jun 22, 2013 | HP Pavilion Dv3-1075us Notebook
As i turn on my pc, i hear 1long and 2short beep..and the light of the monitor power is blinking..what could be the problem? Hope that you can help me..TNX
The beep code you are getting Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information. Plan English - you have a bad video card or port. If your video output is on a PCI card, replace the card. If it's on the board, you will need to replace your motherboard.
Good Luck
C2Solutions
Jan 19, 2011 | Computers & Internet
1short beep 2short beeps 1short beep
Looks like you need a new MoBo. See Here
Sep 03, 2010 | MSI MS-6398E Motherboard
Abit av8 bios post codes 8.3 - 8.6 - 9.c What is failing on boot ? I get one long beep followed by 4 short beeps. I have swapped video cards and reflashed the bios with no help. If I reboot 2 or 3...
I still did not find beep code that match your problem..
Anyways here are the common beep codes for your motherboard.. it might help you too.
1. No beep - no reaction, the mother board is dead, power supply problem, processor and or ram problem.
2. 1beep - board is working fine.
3. One long beep then it shuts down - cpu problem, your processor is not working or missing.
4. 1short beep - system boots normally
5. 2short beeps - CMOS setting error.
6. 1long 1short beep - dram error
7. 1long 2 short beep - video card or monitor not connected
8. 1long 3 short beep - keyboard error.
9. 1long 9short beep - ROM error
10. Long beep - memory card is missing or not connected
11. Short beep - power supply error
12 Four beeps - there is no fan detected on Fan1 or Fan2 header. make sure to attach or reset CMOS bios to factory setting.
Hope this gave you an idea of your problem..
Much appreciated if you rate this help..thanks..
May 23, 2010 | Abit AV8-3rd Eye Motherboard
There is a continious beeping sound from mainboard; when on. sonds like from the bios or cmos. any ideas Thanks
most likely it is a sound from mother board
- try to reseat the mother board(take out and put it back in)
- then check if still getting a sound/beep
- if not good!
- if yes replacement mother board suggestion
TIP:
- try other mother board on your computer first to check if you can hear a wierd noise
Mar 31, 2010 | Lenovo 3000 J Series 1.80G VBE PC Desktop
No display on screen only 1 long beep then 2short beeps
This is a memory error. First remove all your memory then put it back in again. If the error persists and you have more than one memory module, remove one at a time and see if it will boot. If you only have on module, then that module will have to be replaced.
Jun 14, 2009 | HP Pavilion dv2000t Notebook
Change fax to recognize distinctive ring. Officejet V 40
Hi devoncarl2,
I'm not exactly sure what your asking. I'm going to assume that you want to know how to turn on your distinctive ring function for your fax/telephone. On most models of all-in-ones or stand alone, there is a setup function button on the unit itself. It will scroll through various options for different functions. Scroll until you see something about incoming calls or "distinctive ring" or phone/fax setup. It is here you will have the opportunity to select the distinctive ring your local phones service offers i.e. 3 long 2short or 2long 2short etc.. I hope this helped a little, if not, hit me back, we have other options.
Thank you for using FixYa.com
Sincerely, cyyyd7
Oct 08, 2008 | Computers & Internet
Dead motherborad
mkjameel
all mother board bios has a beep coad for successful post. looks at mother board manual which is provided with ur mother board. or vander web site. (some mother board one single beep for successful post).
thanks
Buddhadev
Jul 08, 2008 | HP (D7580-60003) Motherboard
Intel 845 chipset mother board no reaction - expecting solution
this is normal No-Ram. No-Beep.
The ram is all part of the bios analysis beep codes.
install memory, and setup the board to the manufacturers specification.
1 beep at post is normal on many bioses.
Mike @ compurepair.
Feb 22, 2008 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
Foxconn (755A01-6ELRS) (K8S755A6ELRS) Motherboard Logo
96 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
