Question about Dishwashers
Problem is that our dishwasher is not pulling the water into the machine, we tried opening and closing the water supply valve..can you help
    Scholar:
  • 68 Answers
Where the water connects to the machine, there is usually a little in-line screen at the water valve. (usually bottom, front, left behind kick panel) If it isn't clogged, the valve may be bad.
Posted on Apr 25, 2008
Does closed water supply valve cause damage to dishwasher inlet valve or control board damage?
no
no water flow means that the inlet solenoid valve will stay open until the water level sensor is triggered by the water level
no water = no action
Jun 28, 2017 | Washing Machines
Fdd914 dishwasher error code A10 appears and its not in the booklet
Hi, the interpretation for error code A10 is: A10 = fill solenoid valve triac closed/open circuit - check valve/ operation - machine drains until level switch resets + 30"
Now, to try and solve the problem yourself: Turn off the water supply to the dishwasher & remove the hose, Run the machine for several minutes in a normal position. Turn the machine off, reconnect the fill hose, turn the water back on then turn the machine back on.
If this doesn't solve the problem, then you'll need to call a service person.
Jun 12, 2011 | Hotpoint-Ariston FDD914 24 in. Built-in...
My dishwasher is showing error code a10 model ide 1005
Jun 12, 2011 | Dishwashers
My Samsung dishwasher has a error code 4E after i start it up could you please let met know what this means thanks
Most common error codes that are caused by installation errors are:
  • 4E. If your dishwasher is displaying error code 4E, it can be caused by the water supply valve. The water supply valve may be closed, or not fully open. Most water supply valves are not frequently opened or closed. Because of this, they may be difficult to turn. To make sure this is not your issue, turn the supply valve to the fully closed position, clockwise, and then turn the valve to the fully open position, counterclockwise.
    • Check your water pressure. Your dishwasher requires a minimum of 20 psi and a maximum of 120 psi.
    • Water filtration info.
Nov 14, 2010 | Samsung DMR57LF Builtin Dishwasher
There is no water getting into my dishwasher.
Check the valve where the water enters the washer. The valve can stick with hardwater build up and the solenoid will not be able to open and close
Jul 01, 2010 | GE 24 in. GSD6660GSS Built-in Dishwasher
E4 error after attempting to fill and get to temp
This is what I found for the E4 code...hope this helps...and thanks for rating my effort...The Fang.
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2.Make sure probes are clean.
3.No water pressure — main water supply valves may not be working.
4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the
OFF-ON procedure.
5. Delime machine.
Apr 28, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart LX15H indicates E4 and will not fill.
This is what I found in the manual...and on a couple of other sites....
OFF-ON procedure.
5. Delime machine.
If this doesn't help let me know and I will get to the bottom of it....good luck and thanks for rating my effort...The Fang.
Apr 27, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Dishwasher
Hi, it sounds like there is no watewr supply to the machine. Try turning the valve closed, and then opening it again. If that doesn't work, turn off the water and disconnect the supply hose. Then, with a bucket handy, turn the water back on slightly to see if water is coming through the end of the hose to the machine. Also check the gauze inlet filter for blockage with grit.
Let me know how you get on before rating the solution!
Thanks, D.
Jul 30, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Cycle will not start
sounds like your machine is not taking in any water at all, which is the first thing the dishwasher wants to do on all programme settings.The constant whirring noise you refer to will be the water valve trying to take water into your machine.As yours isn't filling in the first place the programme cannot progress without water and it will just sit there whirring.Anyway, to resolve this matter I would check the fill hose which goes from the back of machine to your cold water pipe in your kitchen/utility, in case somebody has turned off supply.where the flexi hose meets the copper supply pipe there should be a thumbturn shut/open valve, turn this 90 degrees or a quarter turn and if you here a rush of water for a split second then you have fixed it.At this point try setting away a programme to see if water is going into dishwasher. If not have a bucket ready and unscrew the flexi hose altogether to make sure water is travelling past shut/open valve.If not you need a new shut/open valve.If water is able to pass this valve reconnect to dishwasher turn shut/open valve a quarter turn to open flow of water again,test machine on any programme again ,if it fills then your sorted, if not it must be your dishwashers internal water valve that will need replacing.Not a major job (located behind fill hose) but make sure electric and water supplies are off first before dabbling and write down your machines make and model number before shopping for part. GOOD LUCK.
Aug 07, 2007 | Baumatic 18 in. BFD46 Free-standing...
Water filling does not stop
Water supply to the dishwasher is done through an electromagnet valve,loocated at the water pipe's enterance to the machine. A defect in the valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it, and the valve may leak and drip water into the tub.You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from the machine before doing it !!!!! and as well to close water main tap to the machine. In case cleaning doesn't help, you should replace the valve. Good luck !!
Jun 23, 2006 | Indesit 24 in. IDL700 Built-In Dishwasher
Dishwashers Logo
57 people viewed this question
Top Dishwashers Experts
