Question about Technics SH-GE90 Home Equalizer
I have a Technics Stereo graphic equalizer. Trying to find out why it's not getting any power. it has no fuse inside. I hook the plug into the outlet and nothing. atleast the light on the equalizer does not come on when I push the power button.
  • Technics Master
  • 17,130 Answers
The power supply unit has failed in your equaliser. If it is the main transformer check for the continuity of the primary and if open you will need to replace with the same one or rewind with the same parameter.However if the thermal fuse is blown you can short the winding with a fuse wire. Also check on the dc side for any fusible resistors that would have opened out. Hope you check this out. Good day
Posted on Aug 11, 2010
How do I hook up my Kenwood ge-74 graphic equalizer to my technics sa-gx530 receiver?
Because they are two different brands the only connection you can have is RCA cables which you can buy at any stereo shop, including car audio. You will not have any special functions from the two being connected. You will have control over sound quality.
Feb 16, 2016 | Kenwood Audio Players & Recorders
Can I connect an external Technics SH-8036 Stereo Graphic Equalizer to my Technics SA-500 receiver?
You can but you will need to use one of the tape loops to do so. That means you will also have to use the tpae monitor switch of the front panel. Just get 2 sets of interconnects and run one from the tape out to the input of the equalizer and the other from the tape in to the out put of the equalizer.
Feb 11, 2016 | Technics Audio Players & Recorders
Would I be able to connect an external Technics SH-8036 Stereo Graphic Equalizer to my Technics SA-500 receiver?
Yes, it is hooked up using the (cassette) tape inputs and outputs. Use the tape monitor switch on the receiver to switch the EQ in or out.
Feb 11, 2016 | Panasonic Technics Sa-dx930 A/v Stereo...
Where can I get a free manual
go on panasonic website or google the manual you want.i use manuals lib
Jul 02, 2014 | Technics Audio Players & Recorders
Hooking up EQ to RECIEVER for a TECHNICS MODEL SH-8017
You'll need 4 connections total. On my integrated amp, I connected the four connections to all Line In and Line Out ports. And the other ends into the tape 2/EXTRA ports respectively.
Jul 19, 2013 | Panasonic Technics Stereo Graphic...
Sh-e66 user guide,more information on obtaining a user guide, for stereo graphic equaliser,this was purchased second hand without one.
Go here and register for free to get it...
http://www.hifiengine.com/manuals/technics/sh-e66.shtml
It's one of my favorite sources of free manuals.
Had you web searched "technics Sh-e66 manual" you might have found it on your own.
Sep 23, 2011 | Technics Audio Players & Recorders
I cnt find away to instal my stereo graphic
'Organizer'?
It takes two to tango.Install to what? No manuals?
Any analog audio processor or tape deck traditionally goes into a Tape Monitor Loop on a receiver or preamp. Be advised that the use of any Tape/Processor Loop will disable digital audio sources on a digital receiver/preamp.
Web search that term. Then add 'equalizer' to it. They all attach in the same basic way.
Aug 05, 2011 | Technics SH-GE50 Home Equalizer
I need a hook up digram fof an optimus model 31-2025 stereo equalizer
http://support.radioshack.com/support_audio/doc48/48943.htm
Ten-Band Stereo Frequency
Equalizer (310-2025) Connections Faxback Doc. # 48943
Follow these steps to connect the equalizer to your audio system.
CAUTIONS: Use only shielded audio cable with RCA-type connectors (not
supplied). This type of cable is available at your local
RadioShack store.
Before you connect the equalizer, turn off all components in
your audio system and unplug their power cords.
Before you plug in the equalizer's power cord, complete all
connections and be sure the equalizer's POWER button is out.
1. To connect the equalizer to your receiver, connect the receiver's TAPE
OUT jacks to the equalizer's MAIN IN jacks.
Then, connect the equalizer's MAIN OUT jacks to your receiver's TAPE
IN or TAPE MONITOR jacks.
2. You can connect a tape deck to each set of tape jacks (TAPE 1 and TAPE
2) on the back of the equalizer.
To connect each tape deck, connect the equalizer's TAPE OUT jacks to
the tape deck's in jacks. Then, connect the tape deck's out jacks to
the equalizer's TAPE IN jacks.
3. Plug the equalizer's power cord into your receiver's switched power
outlet or any standard AC outlet.
WARNING: The equalizer's power cord has a polarized plug. To prevent
electric shock, do not use an extension cord or other
receptacle unless you can fully and easily insert the plug's
blades.
4. Connect the power cords of all other components.
(wr 08/04/98)
Feb 24, 2010 | Audio Players & Recorders
Technics SH-GE90 Home Equalizer Logo
436 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
