Question about SanDisk 2GB microSD Memory Card
Locked card memory card was working fine, then one day I couldn't access the pics, or use it to take more and an error message: "card locked" appeared. tried the little tab on the side, even tried putting tape on it, nothing is helping and I am desperate to get the pictures off the card!
  • 6,831 Answers
Hello
Ok, here is something you can try:
In your case the problem is not with the card but rather with your camera's card reader. This is a rather hard problem to fix yourself but here is what you can do.
Open the card slot of your camera and peer inside with a sharp light or torch. You should see a little metal tab or switch inside the card slot. This is the write protection switch. Contrary to popular belief , the switch on the card does not impact the operation of the card itself but rather tells the camera that the card should be locked by depressing the little pin inside.
If you put a protected card into a camera with no protection switch , the card would operate normally.
However , with time and repeated use , the switch will start to bend slightly until it will no longer depress when a unlocked card is inserted.
With a toothpick or needle , slightly and very gently push this tab up a little bit. (some camera's will require you to pull the tab down), This will allow the switch to operate once again and should solve your problem.
Kind Regards
Andrea
Posted on Aug 03, 2010
My Sony DSC-S930 camera says file error?
Get a card reader and use it to download to a folder you create on your desktop. If that doesn't get you all of your pics, take the card to a Walmart store and use their picture kiosk machines to print the pics or even make a CD of them. Once the pics are safe, you can format the card in the camera to get it erased and back to original condition.
Oct 24, 2011 | Sony DSC-S930 Digital Camera
8GB CENTON SDHC memory card - class 4 - worked okay first day. Removed card to transfer pics to computer. Did fine. When inserted card back in camera JVC-PICSIO GC-FM2BU, got "Memory Card Error"...
Sounds like you forgot to use the "safely remove hardware" when you removed the card from the computer. Also, never format a card in a computer and then expect it to work in a camera. You can try to format it a few more times in the camera but if not successful, then you should think about getting an new card.
Feb 19, 2011 | Cameras
Memory card locked, already tried little switch on the side
It may have to be unlocked in the camera settings. My phone has a lock feature for photos, to prevent accidenta erasing.
Jul 17, 2010 | SanDisk 2GB microSD Memory Card
Memory card error message
Cards are coming in different formats and it might be possible that you brought a card which is not suitable or functional with your camera. The other reason could be that we are having options to lock our memory card in digital camera and you might have taken out your earlier card without unlocking it. The system might be broken from inside and this could be a reason that you are still getting a message that memory card is locked. It seems possible based on problem you are sharing.
May 28, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
Error message "cannot rename"
dont access, may be your memory card locked
Aug 06, 2009 | SanDisk Computers & Internet
Cyber-shot DSC-W35 format error c:13:01
Software for Memory error correction is available on charge basis to get data/ pictures.
Jul 29, 2008 | Sony Cyber-shot DSC-W35 Digital Camera
Can't access pictures taken
If you can't access the memory card even with a card reader...your camera is working fine...the problem is ith your memory card (internal problem)...if your warranty is not finished sony will replace that to a new one
PLEASE RATE ME ( FIXYA )................................
May 26, 2008 | Sony 2GB Memory Stick PRO Duo Memory Card
Memory stick error
Try using another memory stick, or insert a confirmed good memory stick, if OK, the memory stick is defective, if the same error, try pressing reset at the back of camera, a small hole beside the the DC jack. if OK, then fine, if still the same, camera needs repair. thanks
Sep 12, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
SanDisk 2GB microSD Memory Card Logo
67 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Carlos Calvo
Level 1 Expert
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
