Question about Toto MS950CG-12 Neorest 500 Elongated One Piece Toilet with Integrated Wash
I have a Neorest 550 brand new. It wont clear the bowl with any paper in it, and the nozzle seems very weak?
    Scholar:
  • 67 Answers
Ensure the water supply is opened to full. This unit needs the max water pressure available to work properly. You can test the water pressure by running the water into a bucket at full capacity for 10 seconds from the cold water supply for the toilet. If you get 1.5 gallons or more then you have sufficient water pressure. If your water pressure is good remove the water filter from the toilet and ensure it didn't get clogged with something during installation. The other 2 possibilities are that the toilet is defective and requires repair or replacement or the wax ring may be obstructing the water flow. Try the simplest things first. I would also contact the manufacturer to trouble shoot with them as well.
http://admin.totousa.com/Product%20Downloads/H06939R%20NEOREST%20550%20BOWL%20UNIT%20ENGLISH,%20IM,%20V.01.pdf
Customer Service & Technical Support
Tel: 1-888-295-8134
custservice@totousa.com
techsupport@totousa.com
Posted on Aug 03, 2010
Can't disconnect water line to replace fill valve
you could try a basin wrench....if that does not work i would cut it off with a cheese saw or hack saw blade then replace all parts with new...
Jan 31, 2013 | Toto "MS980CMG12 Neorest 550 Dual Flush...
HI there, I got a lawn mower mtd yard machine briggs ans stratton 4,5 hp, it start pretty well but won't stay running, I change the spark plug, oil, gas brand new, clean the carburator, clean the air...
There could well be a build up of sediment and debris in the main jet to the carburetor. It is easy to get to and clean. It is the brass bolt that holds the lower float bowl onto the main body of the carburetor. To clean it, drain your gas. Remove the bolt and external washer UNDER the carburetor bowl. Clean out the bowl of any sediment and/or water. To clean the brass bolt, use no metal objects. Carb/Choke aerosol spray cleaner will do the job. Pay close attention to the hole in the bottom of the bolt and the very small holes about 2/3 of the way up the bolt. Clean till shiny with holes cleared and reinstall. Your fuel flow problem and shut off condition may be solved.
Jun 05, 2011 | Mtd 22" Yard Machine Push Mower
Printer don't print in black and white. black don't seem to be working and brand new ink cartreag.
The nozzles in the cartridge may be clogged and need cleaned out.
http://swapink.com/Merchant5/merchant.mvc?Screen=cp_faq&Store_Code=SI
The first tip on this site should clear out the nozzles. Using warm water seems to flush the nozzles out better.
Mar 26, 2010 | Kodak Office Equipment & Supplies
The bowl is full of water and cannot be snaked by a plumber it will not flush. it is a neorest 600
When you say it does not flush; do you mean it flushes...the water just won't go down (won't empty the contents of the toilet bowl)?
Be more specific.
JZ...
Dec 09, 2009 | Toto MS990CGR-11 Augusta Decorative...
Increasing water in bowl
You really can't because of the design. Any water above the level now will drain off. Sorry
Nov 04, 2009 | Toto Toilet Onepiece Neorest 600 ...
ToTo S300 spray very weak
Poor some clr in the washer bottleand block the nozzles as you run the clr through. they will clear up, but don't leave the clr on your paint or in the washer bottle. Rinse everything out and off.
Jul 10, 2009 | Toto MS950CG-12 Neorest 500 Elongated One...
Toto Washlet weak
If you are using well water you might want to upgrade your filtration system.or add a mixing valve to the water supply of your washlet and add a filter there, you answer your own question you have very hard water.So the product is getting abnormal; wear and tear. Without making changes to your water supply you will continue to prematurely go thru fixtures,
Jul 02, 2009 | Toto MS950CG-12 Neorest 500 Elongated One...
Clearing Memory
go into service mode then into ram initialize and do all job clear. yo avoid this happening again set "inc. file save to invalid"
Mar 04, 2008 | Panasonic Panafax UF-550 Plain Paper Laser...
Toto MS950CG-12 Neorest 500 Elongated One Piece Toilet with Integrated Wash Logo
140 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
