Adjusting length of time OSD stays on screen
I wish to calibrate my monitor using Huey pro. When i bring up the OSD it only stays on the screen for a few seconds,not long enough to make adjustments. Please tell me how to adjust the length of time the OSD stays on screen. I am working with windows XP
  • nosmit Apr 29, 2008
    Found the time out function, but now can't find how to adjust it. Lots of other functions on the same screen how to I get the highlight to move down to the one i want.
    Genius:
  • 1,554 Answers
In the menu is a timeout function, as long as your making a movement choice you should be able to find it. if nothing else go up and down until you locate it.
Posted on Apr 25, 2008
  • Karl Whisenand
    Karl Whisenand Apr 29, 2008
    what ever monitor you are using is the same for most all type.
    you open the menu button
    to go up and down use an adjacent button to go up or down you will have to experiment to find which one.
    then to enter the menu it is either the menu button again or another button entirely another expeirment
    sometime the osd buttons are on the side of monitor instead of the front like menu.
Lcd monitor working fine but the adjustment screen apears on my monitor in a small square enveloppe how can i restore system thanks in advanceDewulf Jan
I assume by "adjustment screen" you mean the OSD (On Screen Display). This is the box where the menus for adjusting the screen appear. If I'm correct, that means you have pushed the "menu" button on your LCD and need to push it again to turn the OSD off. If pushing it again does not solve the problem I would say it's time to have the LCD repaired. In many, but not all, that OSD goes off on it's own after a bit.
Mar 01, 2014 | Relisys TL565 15" LCD Monitor
Osd volume control won't go away
bad switch i monitor.
fix switch
or new monitor.
its just a switch, it closes and OSD pops. on demand by said switch, OSD is a timing processor in the display that has the OSD code in it , "program"
Mar 25, 2017 | HP Computers & Internet
My 2001FP shows the contrast cotrol greyed out and the screen has very low contrast, which I need to correct. I use it with a Dell Inspion 9300. The laptop screen has excellent contrast. The 2001FP...
I have four Dell 2001FP monitors. The unavailable contrast is standard for this monitor when used with digital input (DVI). Make sure your brightness is at 100%.If you want a better result of dynamic range and color, the only effective option is color calibration. I use the inexpensive Huey Pro, available
several places, including eBay. Retail is around $100. It something one uses maybe twice a year, takes five minutes to install and use, and the results are notable. I'm a designer, and need excellent color. This is the best solution. Calibrate your laptop as well, and the color should be almost exactly the same between them.
As an alternative, you can use the color settings, select User Preset, and start with something around 40 red 43 green and 37 blue. Adjust proportionately upward until you get what you want.
Another possibility is to use a different connector cable if your laptop has that option, since your monitor an take four different input formats.
Good luck.
Dec 07, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
"OSD LOCKED" box on my screen
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
OSD stands for "On Screen Display." It is an onscreen configuration menu included with various monitors. When you press the MENU button or one of the other buttons on the front or side of a monitor, the onscreen display may appear. The OSD typically includes monitor calibration options, such as brightness, contrast, and color adjustments. Some OSDs may also include horizontal and vertical position controls as well as tilt and keystone adjustments.
If you can't make adjustments to the monitor settings using the OSD interface, the onscreen display may be locked. You may also see the phrase "OSD Locked" appear when you try to change the settings. Some monitors include an option within the menu called "OSD Lock", which you can turn on or off. If this option is available, simply turn OSD Lock off and you will be able to make adjustments to the settings.
If your monitor does not include the "OSD Lock" option, you may be able to unlock the OSD by pressing and holding the MENU button on the front or side of the monitor for several seconds. If you try this method, be patient! It may take up to 15 seconds for the OSD to unlock.
VOTE ME
Dec 07, 2010 | Dell Computers & Internet
Hi, i'm trying the PMS code Pantone 2756 C on illustrator Cs4 and what i'm getting on the screen/printed material is completely different from the color bridge that i have
You cannot match a Pantone swatch book to your monitor unless you have calibrated it using something like Huey: http://www.pantone.com/pages/products/product.aspx?pid=562&ca=2 as a monitor is backlit and printed materials are not.
Depending on what sort of printer you are using, it also may need to be calibrated or have its profiles updated.
Oct 08, 2010 | Pantone Color Bridge Uncoated
We're seeing heavy pixelation on all of our prints.
I would try going to the color menu on the printer and performing the density and registration calibration that should cure your problem hope this helps.
Nov 25, 2009 | OKI C5650dn - 1212601 - - Laser Printer...
How do I set the monitor so the menu will stay on long enough to change it?
There should be a setting in the monitor menu listed as OSD (On Screen Display). Try increase the length of time for it to stay on longer.
Nov 09, 2009 | X2Gen MG19MY 19" LCD Monitor
OSD on m onitor
sounds like bad capacitors on the power pack, is this an older monitor ? could use some more info on age and type of monitors and the video card used.
OSD is On Screen Display and it is for adjusting screen functions like color brightness etc.
different screen resolutions can cause a monitor to shut down.
Apr 04, 2009 | Acer Computers & Internet
Screen settings problem
OSD = On Screen Display. Once loaded it is normal for the OSD to stay on your screen untill it times out or you Exit it.
Nov 24, 2007 | Samtron MONO TTL 13 Monitor
Computers & Internet Logo
601 people viewed this question
David Payne
David Payne
