Question about HP Photosmart 8250 InkJet Printer
IMy wife pulled the paper tray completely out of
My wife pulled the paper tray completely out of the HP 8250 printer and I cannot figure out how to get it back in. It goes part way in and won't go further.
  • Jinx Jul 18, 2012
    I have exactly the same problem -- can't get the paper tray to go back into the printer! I'd pulled the tray all the way out in an effort to clear a paper jam (B4 realizing there was a back door for this), and now can't get the main tray to slide back in. There's nothing in the manual about this, and unfortunately Mr. Wong's answer doesn't address the question either. Can anyone help?? (Paying HP for customer support is my LAST resort!) Thanks...
  • Charlene Macias
    Charlene Macias Oct 25, 2013
    did you guys find out how to put the main tray in? I did the exact same thing like you Jinx. Now i'm having trouble to have it back the same.
  • HP Master
  • 6,826 Answers
Loading your paper
Paper loading tips:
● Load paper with the side to be printed facing down.
● You can print photos and documents on a wide variety of paper sizes, from
8 x 13 cm (3 x 5 inch) up to 22 x 61 cm (8.5 x 24 inch). The 10 x 15 cm
(4 x 6 inch) photo paper is available with and without tabs.
● Before loading paper, pull the Main paper tray out (use the Main tray release or
the tray grips) and slide out the paper-width and paper-length guides to make
room for the paper. After loading paper, adjust the guides to fit close to the edges
of the paper without bending the paper. When finished loading paper, push the
Main tray back in all the way.
● Load only one type and size of paper at a time in the same tray.
● After loading paper, extend the Output tray extension to catch your printed pages.
Use the directions in the following table to load the most commonly used paper sizes
into the printer.
Paper type How to load Tray to load
Any supported
photo or plain
paper media
1. Extend the Main tray by
pulling it out with the Main
tray release or the tray
grips.
Load the Main tray
Chapter 2
(continued)
12 HP Photosmart 8200 series
2. Slide the paper-width and
their outermost positions.
3. Load paper with the side
Check that the stack of
paper is no higher than
the top of the paperlength
guide.
4. Adjust the paper-width
inward until they stop at
the edges of the paper.
5. Push in the Main tray all
the way in.
6. Make sure the light on the
Photo tray button is
turned off to enable
printing from the Main tray.
Load paper and adjust guides inward
1 Paper-width guide
2 Paper-length guide
1 Push the Main tray all the way in
Posted on Aug 03, 2010
HP OfficeJet Pro 8600 tray can't be inserted all the way. Stops with 3 inches of tray sticking out.
  1. Grasp the handle on the front of the input tray, and then pull the tray towards you to open it.
    Figure 1: Pull out the input tray
  2. Slide the paper width guides out as far as possible.
  3. Remove all paper from the paper tray.
  4. Inspect and remove any foam or tape packaging materials in the paper tray.
  5. Insert a stack of unused, plain white paper (with the print-side down) in the center of the tray.
    Figure 2: Load paper into the tray
    CAUTION: Do not load any paper above the solid red lines on the sides of the tray. Do not use torn, wrinkled, perforated, wet, or folded paper. Make sure to remove all paper clips and staples before loading the paper. Figure 3: Stack label height
  6. Slide the paper guides in so that they rest against the edges of the paper, and then insert the tray into the product and push it forward until it clicks into place.
    Figure 4: Slide the paper guides in and reinsert the tray into the product
  7. Pull out the tray extender on the output tray.
    Figure 5: Pull out the tray extender on the output tray
Step two: Load paper in optional Tray 2
Tray 2 is an optional accessory. Follow these steps to load paper in Tray 2.
NOTE: Tray 2 supports only plain letter or A4 paper.
  1. Grasp the underside of the tray, and then pull out the tray from the bottom of the printer.
    Figure 6: Pull out the tray from the bottom of the printer
  3. Load a stack of unused, plain white paper (print-side down) in the center of the tray. Make sure that the stack of paper aligns with the engraved lines in the tray.
    NOTE: Load Tray 2 with only U.S. Letter or A4 plain white paper.
  4. Slide the paper guides in so that they rest against the edges of the paper.
  5. Carefully reinsert the tray into the printer, and then push the tray forward to close it.
    Figure 7: Reinsert the tray into the printer
  6. Pull out the tray extender on the output tray.
    Figure 8: Pull out the tray extender
Load specialty paper Follow these steps to load specialty paper such as card stock, envelopes, photo paper, or labels.
Before you proceed, verify that your printer supports the specialty paper on which you are attempting to print by viewing the product specifications . If the size, type, or weight of the paper is not available, the printer does not support printing it. Also note the tray loading capacity for the type of paper on which you are attempting to print.
Sep 27, 2013 | HP Officejet Pro 8600
The paper won't feed properly. Regualr of photo. It constantly says there is no paper when the tray is full.
Try changing the type of paper that you have under your printing preferences into hp premium photo paper instead of automatic.
Feb 14, 2011 | HP - HP Photosmart 8250 printer
How do you remove paper tray on hp photosmart 8250 printer to clear paper jam
Hi we2halls,
You may want to try the procedure on this link to help you clear the "Paper Jam". It includes detailed instructions and some illustrations.
Hope it helps.
Thank you for using FixYa.
Nov 15, 2010 | HP Photosmart 8250 InkJet Printer
Hp 8250 led screen indicated paper trays are empty when the are full
Here's a solution for that printer.
Click here to view the solution.
I am an HP employee. I do not represent HP on this site.
Aug 12, 2010 | HP Photosmart 8250 InkJet Printer
My hp 8250 constantly does not feed paper. It tells me to load paper when the tray is full. Often times I have to push the paper toward the rollers with my finger to get the paper to catch and have it...
There is a plastic switch that detects paper. You will probably have to disassemble it to get to it. It could be dusty and jammed or broken or stuck. If it's broken, you might check to see how much a local shop will repair it for. Often, it's just better to buy a new one. Good luck.
Mar 20, 2010 | HP - HP Photosmart 8250 printer
Daughter left HP Photosmart 8250 idle for a year. Have just put in new ink, but paper will not load. How to service?
unplug the printer from the power and from the computer..
open the back door of the printer and check if both the rollers (inside the printer & on the door) are rolling (upwards)..if not then press & Hold the Power button for 60 seconds when unplugged from the power..
If the rollers still dont move..then u need to service the printer..
if rollers moves..then connect the power cable to the printer and directly to a wall jack (not to a power strip)..
power on the printer and load paper in the main tray..(ensure photo button is not lit up)..
photo button should be lit up in case u want to print photo and the paper is placed in the small phto tray which is exactly above the main tray...
place the paper to the xtreme right in the tray and slide the paper guide from left to right..
then try printing ..
Dec 24, 2008 | HP - HP Photosmart 8250 printer
My printer isn't grabbing the photo paper
have you tried with normal paper..does it still do the same
when you load the paper does the roller sit on the paper at all...watch the roller....
but if your machine reports that there is no paper even though the roller is sitting on the paper
turn off your printer//remove the ink cartridge.....get a can of contact cleaner..with the nozzel on..throughy spray the roller area this is where the papper sensor is...
if this still doesnt help you will need to open the printer and check the sensor
keep me posted
Cheers
Nov 17, 2008 | HP Photosmart 8250 InkJet Printer
Out of paper
My wife and I encountered the same problem with our HP 8250 Photosmart Printer. Me being an avid do-it-yourselfer, and a tightwad, searched tirelessly for a solution. HP was totally useless in providing information beyond what is posted on their website; which was all the service technicians would spew forth, both by phone and on-line. I had nearly resolved to buying the $50+ paper feed roller cleaning kit when I decided to look more closley at the machine. After romoving the rear access cover and watching the printer perform it's functions of trying to fruitlessly feed the paper off the paper tray; I noticed that the rollers were in contact with the paper and they were rotating normally, but there was just did not appear to be enough friction to feed the paper forward. The paper was new and was HP brand. I figured why not try and clean the rollers with some generic rubbing alcohol on a long wood handled cotton swab (available at most drug stores). Afterall, the HP site and technicians mentioned "DUSTY" rollers. I turned the machine off, disconnected the USB and power cables, and began cleaning as follows: Simply wet the cotton swab with the alcohol and gently brush/rub the rubber surface of one roller at a time, while rotating the rollers with another cotton swab using the wooden end. After several rotations of both rollers and a half dozen swabs, I replaced the rear access cover and turned the machine back on. My wife and I have printed pictures and documents flawlessly since. Total cost of the do-it-yourself cleaing kit: about $3.00.
I hope this someone else finds this solution helpful and as inexpensive as we did.
Thankx Fixya, for a great web site that pairs problems with solutions.
Mar 16, 2008 | HP - HP Photosmart 8250 printer
8250 hp printer
Adjust the paper settings in the print driver. The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program in which it was created.
  2. Click File .
  3. Click Print .
  4. Click Properties . The Printer Properties dialog box displays.
  5. Click the Paper/Quality tab.
  6. In the Size is drop-down menu, select the size of the paper loaded in the unit.
  7. In the Type is drop-down menu, select the type of paper loaded in the unit.
  8. Click OK .
hp website
Jan 29, 2008 | HP Photosmart 8250 InkJet Printer
HP Photosmart 8250 InkJet Printer Logo
1,328 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
