Question about VXI Corporation Blueparrott B250-XT Bluetooth Headset
How do you put blue parrott B250--XP in discovery mode.
  • 3 Answers
From the power off position, switch the unit on by holding the function button for 3 seconds. Keep holding the function button until the indicator light on the function button flashes red and blue in an alternating pattern. The unit should now be in discovery mode and ready to pair with another device..
Posted on Aug 09, 2010
My iPhone 4 will pair with a blue parrott b250 xt but the Bluetooth link won't stay connected. It drops then reconnects drops then reconnects. How can I fix this problem?
You could try closing everything non vital on the iPhone to make its job easier or mabye it a power issue with the headset. A) even rechargeable batteries have a lifespan, B) you got a bad one so try keeping the power connected to the headset while you pair it. 10_25_2013_12_17_40_pm.png
Sep 08, 2013 | Cell Phones
Where can i find a battery for a blue parrott b250-xt headset
Either an "Interstate Battery" store or a "Battery Plus" store or dealer would have one or if not they can make one for you! They have specially made a few for me
Dec 11, 2011 | Radio Communications
How do sync with my new phone?
1. You must start with the headset in the OFF position. Put the headset in pairing mode by Pressing and holding the Multi-Function Button until the lights are flashing alternating Red and Blue, you will then release the Multi-Function Button. Please note the headset will continue flashing Red and Blue until the paring cycle times out (approximately 2 minutes) or completes the paring with the cell phone. If you only press and release the Multi-Function Button the headset will not go into the paring mode.
2. Once the headset is in paring mode, go to the Bluetooth menu / connections of your cell phone. Select add new / search for / find new device (different phones have different but similar names for the options). The cell phone should find a device called VXi B250-XT. Move the cursor over the VXi B250-XT and press (OK, select, enter, or whatever your phone uses for a prompt). If the cell phone asks for a passkey code you will put in 0000 (four zero's). The headset will then pair and connect to the cell phone and be blinking Blue once every second. Your phone may ask you if you want to connect to the B250-XT and/or add it to your trusted device list, press (OK, select, enter, or whatever your phone uses for a prompt).
Aug 01, 2011 | VXI Corporation Blueparrott B250-XT...
How to reset a bluetooth i.tech i.oval 303
Most manufactures have a factory 4 digit pin that once you have put it to discovery mode,usually blue tooth manufactures use the power button to reset the discovery mode,by holding the power button down while turning it on keep holding the power button for 6 to 10 seconds a light should appear on your device,thus the device is in discovery mode,once your blue tooth device has been put into discovery mode you should go into your phone menu and turn the blue tooth power on,then it should have an add new or seach for device,click that and it should pair with the phone,you will need a 4 digit pin pairing code,Most blue tooth manufatures use factory pairing pins they are as follows 0000,1234,1111,or 9999 try them in that order,i hope this helps you
Feb 22, 2011 | Itech i.Tech i.Oval 303 Bluetooth Headset
What is pairing code for b250-xt
Goog day..
All VXi Blue Parrott products us "0000" (Numeric zero - no quotes) as the passcode.
Hope this helps.
GB
Jul 08, 2010 | VXI Corporation Blueparrott B250-XT...
Lost the instructions to my blueparrot b250xt, how do i pair it to my cell phone
Good day... You may find the users guide on the following web site.
www.blueparrott.com/pdfs/202711B_B250XTUserGuide.pdf or visit the VXi web site at www.vxicorp.com, go to the support tab (new window), support tab - Manuals, Find the B250 XT and download.
Hope this helps.
Mar 21, 2010 | VXI Corporation Blueparrott B250-XT...
Blue parrott will connect with my Palm Centro, but there is no sound in the earpiece. Please help.
try this: have both on but not in use,plug the charger in for 10 secs only then unplug, watch lites go from red to blue then flashing just blue at a rate of 1x per second. that resets it. worked for me.i called the company
Mar 14, 2010 | VXI Corporation Blueparrott B250-XT...
How to pair my blue parrot b250 with my phone lost my notes on how to pair
1. Turn headset off (panel 5).
2. Hold down the headset’s MFB until the red and blue lights
flash and you hear 2 rising tones, followed by 4 more tones.
Important: Wait for all tones and for both lights to flash. This
may take up to 15 sec. Release the MFB.
3. Follow the manufacturer’s instructions for putting your
cellular phone into Bluetooth discovery mode.
4. Wait 5-15 sec. while the devices discover each other.
When the phone discovers the headset, select “Pair” and
enter a passcode of 0000 when instructed. When pairing
is complete the headset’s blue light will stop flashing and
the phone will prompt you to ‘connect’ to the headset.
Enter “Yes” on the phone to connect to the headset. When
connected, the blue light will flash indicating that the
headset is in standby mode ready to receive a call.
USER GUIDE
Jan 03, 2010 | VXI Corporation Blueparrott B250-XT...
VXI Corporation Blueparrott B250-XT Bluetooth Headset Logo
2,057 people viewed this question
Top VXI Corporation Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Are you a VXI Corporation Radio Communication Expert? Answer questions, earn points and help others
