Question about Sony SLV-775HF VCR
Have message on screen of 3L 11 Ac. what does that mean?
Pioneer Plasma Tv Throwing Code (11 green blinks on front lights) also on Screen Says (Thermal Alert Shut Down (11) )
Possible set is seeing a temperature too hot inside the set, can also be a fan in the unit if it has them it takes very little dust to slow their speed enough (dust on the fan blades).
Dec 22, 2012 | Televison & Video
Error 29 message coming up on screen
see the error code and fix it. God bless you
Error 29, Excessive AC Input Current, this mean that some elements inside of the treadmills is consuming more AC currente, like transformer, main motor.
see the block diagram attached.
Nov 28, 2012 | Precor 954i Treadmill Refurbished. 115...
I get the message "error 11". What does it mean?
Error 11 is disk dirty, disc scratched, or mechanical failure. Try a lens cleaner. If that does not work, the CD player is bad.
Hope helps.
Mar 25, 2011 | Pioneer CDX-FM673 6-Disc CD Changer
I was rewinding a tape and the VCR just stopped. When I hit either play or rewind the VCR makes a kind of whine or grinding sound and then the following message appears in the display: 3L 22 AA. What...
Have you tried ejecting the tape?
If the cassette will not eject, the tape is probably fouled on the capstans and will need to be "surgically" removed, VERY CAREFULLY from the machine.
Apr 16, 2010 | Sony SLV-975HF VCR
When I put the tape in, the tape does not slide down as it is and the door close. The screen display shows C:32:11. I do not know what that means. Thank you!
The camcorder has detected an issue that may require a power reset.
To power reset,
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
Aug 02, 2009 | Sony Handycam DCR-HC28 Mini DV Digital...
Toshiba Satellite A105-s101 video problems
Unmountable boot volume means most likely the hard drive has failed.
Dec 18, 2008 | Toshiba Satellite A105 Notebook
Problem with laptop- no power
The battery needs to be taken out once in a while. It is possible to use the ac adapter and power cord without the battery to power your laptop. Please press on the power button for 10 seconds for your computer to turn on. Check if you can see any message on the screen.
Sep 04, 2008 | Toshiba Satellite A105 Notebook
Error H U 11
U11 is a "dirty video heads" message. Either use a cleaning tape or have the unit professionally cleaned.
Feb 17, 2008 | Panasonic AG-DV1000 Mini DV VCR
Televison & Video Logo
176 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
