Question about GE Profile 21.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX22PRBWW
GE REFRIGERATOR TFX22P
Neither the freezer or refer sections are cooling. Compressor and fan both running. What are possible causes and fixes. Thanks
  • turtlebug Jun 17, 2008
    I have a GE TFX22P. Both freezer and fresh are not cooling. Frid side is in the 50 degrees. The repairman said it was not the heater defroster. No ice build-up. He said it was low on freon and might have a tiny leak. He put freon in it and it did get much colder but the refrigerator compressor and fan run constantly. Is that normal? Then he said after he put the freon in that the compressor tested poorly and I needed a new compressor. 500 dollars for the part. If freon worked doesn't that mean I have a leak? Why would I want a new compressor if I had a leak, or does adding extra freon cover up symptoms of a bad compressor. I am a woman ...lol. ....please help. I can't afford not doing the right thing. Should I buy a new frig? I am worried that I will blow money on a condensor and still have a freon leak. How long will it take for freon to leak back out? What should I do? Thanks so very much for any help. I need it badly
    Genius:
  • 1,073 Answers
Check the defrost heater bet it is bad part number for replacement heater is wr51x10053
if the heater is bad defrost coil with a hair dryer till no ice is on the coil
be sure to lay a towel under the coil to catch the water if you dont the drain pan will overflow
Posted on Apr 25, 2008
GE TFX22P Refrigerator Evaporator Fan
Fun run as long as the compressor runs and you do not need to worry about it. the only thing you need to verify are the temperatures in the refrigerator and and freezer compartment: below 40-F, and below 0-F
if temp ok, do not wory about it.
Aug 18, 2014 | GE Profile 21.6 cu. ft. Side-by-Side...
My Whirlpool ET8WTKXKT0 doesn't cooling down. The fan is working, but the compressor like dead. What I have to check? Thanks. Victor
Its the problem with compressor,The problem is weak compressor.The refrigerant ( R12) in the compressor is got low.The compressor is weak.The compressor needs to be replaced.-------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.------------ But as you mentioned that freezer not cooling this indicates problem with compressor.When compressor cools the freezer section then fridge section gets cold.If freezer section is not getting properly cold then fridge section will not cool properly/.So the problem relates to compressor.---------- In the compressor there is a refrigerant called FREON.With the help of this Freon the compressor cools the freezer section.Freon is a gaseous type cooling agent.The compressor will stop cooling when coolant gets leaked from its chamber.--------- Again recharging the Freon is possible, but the cost for that recharging is approx the cost of new compressor.So its always advisable to get compressor replaced.Because new compressor has warranty for few years.------------------ You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Jul 08, 2011 | Whirlpool ET8WTKXK Top Freezer...
Refrigerator not cool enough
Is it running? If so, the evaporator fan in the freezer and the condenser fan(if there is one) by the compressor need to be running. Check if compressor is running. Is there any frost build up on the evaporator cover? If so you have a defrost problem (bad heater, defrost thermost, thermister, defrost timer or circuit board). Check air channels between freezer and refrigerator sections for any ice blockage. If everything checks good you may have a sealed system problem which requires a repairman to fix and is expensive.
Oct 12, 2010 | GE Â 17.9 Cu. Ft. Top-Freezer...
Poor cooling on frezer and almost no cooling on refrigirator
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge frig not kooling but freezer works
the first thing to check is if you can here the evaporator fan running in the freezer compartment.
when the unit is in the cooling mode with the compressor running open the freezer door hold the door switch in and listen for the fan to start running.
you have to give a few seconds to engage if you do not here the fan in needs to be replaced,also look for excess ice build up somewhere in the middle or lower section of the freezer that would cause the fan to stop working.
ihope this helps with your problem best of luck
Feb 07, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator and freezer running warm
Check and make sure fan in frezer section works properly.you should be able to hear fan slowing down when you open freezer, or find door switch and press and hold..hope it helps you..
Jul 07, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Abnormal cooling in freezer/refrigerator
ok, this is insufficient air flow causing the uneven cooling. the fan that has stopped may be dead. you can test the motor with a multi meter and voltage needle. i would also preform a break point test on the thermostat as well. make sure the compressor and condenser are ok. if the noise is coming for the compressor, you may have a bad compressor unit.
Mar 16, 2009 | Refrigerators
Freezer works but refregerator is warm
If this is the model I am thinking about, you have the same compressor for each side. There should be a vent or opening that you can adjust to let cool air inside the refrigerator. Find it and adjust. You may have this opening blocked by something. Let me know if this fixes the problem.
Jan 24, 2009 | GE GBS18HBM Bottom Freezer Refrigerator
Refrigerator problem
3 most common things that cause this are a defrost problem (will notice frost build up on back freezer panel), bad evaporator fan motor (should hear fan running in the freezer), or bad damper (vent to the fridge section). If no frost and fan is running check for air flow out of the vent. It should be at the top of the fridge section.
Oct 01, 2007 | Kenmore 93361
Side by side not cooling
Couple of things... first need to see if the compressor is really hot to the touch and "clicking" on and off every 3-5 minutes due to high heat (trying to start). If that's what is happening you likely have a "start device" failure (little box on the side of the compressor). If the box is white in color and you pull it off and it makes noise when you shake it (along with little bits of debris falling out) you know it's bad. They make a kit to fix that known problem. If the compressor isn't trying to start but actually runs quietly... check that the cooling coil isn't all iced up preventing proper air flow inside the cabinet (take the panel of the rear inside of the freezer section to check it). If that is all a block of ice basically you likely have a defrost cycle problem (defrost t-stat bad, defrost timer bad, etc.). Other than that you should have a little fan right above the coils to move air around, if the compressor is running and the compressor fan (called condensor fan) is running then this fan (called evaporator fan) should also be running to move the cold air around. If that fan is dead then you will have a nice cold coil but no air flow over it to cool the rest of the refer/freezer properly. Let us know what ya find out.
Dec 28, 2006 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
302 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
