I have a puzzle for you ,I will describe the fault, and you leave me any information you can gather. The hard drive on Acer (xp) is 40gb, split into c&d drives The disc would not defrag as only 15% was free on drive C due to D being kept for data. Nick in work gave a disk with partition magic I made C nearly the complete size of the hard drive. This worked fine. I then defragmented the drive three times as instructed oops the computer stopped working When I turn on the computer the fan stays on ,The screen stays blank and the hard drive light stays off nothing comes up on the screen not even the Acer logo so I cannot us the recovery disk Adam thinks it is just a coincidence and that processor or motherboard has failed anything spring to mind
It is worth knowing the hard drive is up behind the battery
on the 1520 acer laptop.so no need to take the laptop to bits
anyhooo it did not solve the problem and the price
of parts makes it unviable to invest in the machine.
many thanks for trying.
Posted on Apr 27, 2008
  • 30 Answers
There is nothing that changing the partition or volume information on the Hard drive would do to cause this issue. My first suggestion would be to unplug the Hard Drive and then try turning the PC on. If you get the Acer logo up then the Hard drive has failed. Otherwise there is something wrong with the Motherboard or RAM.
I would suggest taking it in for Warranty service if it is still under warrnaty, otherwise try what I have suggested. Good luck.
Posted on Apr 25, 2008
Acer travelmate 2423
Solid state hard drive...but yes it should may be a little slower because the ram and small cpu but it should work ok.
Apr 12, 2014 | Acer Computers & Internet
Can I put in my PC Compaq Presario SR 1610NX a Hard drive Maxtor 40GB, 3.5 ? Thanks
Desktop Specs Link Motherboard Specs Link
A. From the first link above, you already have a 80GB 7200rpm hard drive and a combo drive with no further details. you can only use two additional devices one 3.5 inch external and 5.25 inch external bays.
B. Assuming that two devices are already IDE devices, that will leave you two additional IDE and two SATA device.
1. Turn off your computer before plugging any additional device and proceed with cautuion.
2. Add the additional 40GB Maxtor IDE hard drive, you will have to mount the drive into the casing and put some screw to lock or use tool lesslock if its present. (Check the jumper if its a master or slave) if you have configured the 40GB drive as master and you're going to add additional IDE drive you have to put the jumper in slave header.
3. Now put the IDE cable to the hard drive and to the IDE2 of the mother board mount firmly. (you cannot mount the IDE cable if it is in the wrong position)
4. Next the four pin power from the power supply to the hard drive. (you cannot mount the power cable if it is in the wrong position)
5. Power On your computer and press Delete or F2 to access bios, proceed to the option boot priority select your Combo drive as first boot, next your 80GB Hard driver, press F10 save.
6. Power On your computer and check your 40GB hard drive through device manager.
7. Time to add your new hard drive through disk management, so you will be able to see your new drive from your computer. I forgot how WIN XP recognize new hard drives especially the fresh one.
Hopefully this information helps.
Feel free to ask, so I can clarify things.
Thank you for using FixYa.
Sep 05, 2011 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
I have acer travelmate 2355nxc with 40 gb hdd. want to know how to increase its speed and capacity.
Hi, how are you?
To upgrade your laptop, you will have to verify the capacity for upgrade of your laptop.
The Acer Travelmate comes with:
  • Intel Celeron-M 360 Processor 1.4GHz
  • 256MB DDR SDRAM -
  • 40GB Hard Drive
  • DVD/CD-RW Combo Drive - To read DVDs and CDs and write CDs
  • 15" XGA TFT Screen
  • Intel 852GM 64MB shared graphics
  • Operating System: Windows XP Home Edition
  • Based on this information, you can upgrade your memory depending on what type of memory your motherboard supports and how many empty slots for memory does your laptop have.
    The hard drive can be upgraded also depending on which hard drives does the BIOS will recognize.
    I will suggest to contact ACER and ask for the options and upgrades capacity.
    God Bless You!!!
    Hope it helps.
    Remember to rate solutions, to keep fixya.com working for you!!
    Feb 21, 2011 | Acer Computers & Internet
    Acer vt7500 with a s88m motherboard and xp pro The hard drive(40gb) is failing and I would like to know what I could replace it with (ie. largest size) and install xp. I do not need to save the old...
    Your 40GB drive is an IDE ("Integrated Drive Electronics") drive.
    The largest IDE drive ever manufactured is 500GB.
    However, some motherboards do not support drives larger than 320GB.
    Some disk-drives (Seagate/Maxtor) come with a CD-ROM of "tools" that enable you to copy "everything" from your "old" drive to your "new" drive.
    Oct 26, 2010 | Computers & Internet
    I need the driver for the Fujitsu MHT2040AH hard
    Hi
    If using in a external usb enclosure you dont need a driver (unless you are using windows 98), Xp and later will pick it up straightaway
    Please can i ask that you leave feedback and vote if this has been useful
    Feb 11, 2010 | Fujitsu MHT2040AH 50Pk (mht2040ah-50pk) 40...
    Acer 3680. only half of the harddrive works.
    check it on the bios the size of your hard disk, if its 80 gb then go to the control panel after booting open the administrative tools, open computer management, then select disk management, check the hard disk there, if there is an unpartitioned space , then convert it to the partioned space
    Nov 09, 2008 | Acer Aspire 3680 Laptop
    Thank you for your information.
    The only other thing could be a mechanical fault. If you still have a warranty on the thing maybe you should take it back for repairs otherwise its a total loss. Thanks
    May 26, 2008 | Seagate (9Y7275557) 400 GB Hard Drive
    SEAGATE HARD DISK DRIVE PROBLEM...
    I am venturing a guess, but it could possibly be your memory and not your hard drive.
    Additionally, you can partition and format the 40Gb HD in a second PC using a third party utility such as Partition Magic which would also allow you to verify the integrity of the hard drive
    Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
    Good luck and kind regards.
    Apr 01, 2008 | Seagate HDD 40GB 7200RPM ATA100 2MB...
    Computers & Internet Logo
    80 people viewed this question
    David Payne
    David Payne
