Question about D-Link AirPlus DI-524 Wireless Router
Intermitence wireless - D-Link AirPlus DI-524 Wireless Router
    Scholar:
  • 121 Answers
This can be caused by various issues but the first thing I would check is to change the channel your wireless router is broadcasing through. Many 2.4Ghz cordless phones, as well as microwaves can cause the signal level to drop in and out on your wireless devices. You have to access the web page for your router to change the channel and then you have to change the channel on your wireless device to match as well. It will be a trial and error process to determine which channel works best for your devices. There should also be step by step instructions in your user manual which will walk you through the process. Hope this helps
Posted on Aug 03, 2010
I have brother7840 printer i used it on wireless lan but why my printer is intermitent most of time it shows offline
To turn on wireless printer you need to check the printer cables and make sure that all connections are secure. Check whether any wireless printer cable is disconnected since this is the most common cause of offline printer cable. The second reason to solve this issue is you just turn off your wireless printer and wait for one or two minutes and turn it back on; this problem happens because of a certain glitch in your wireless network.
Feb 18, 2011 | Brother MFC 7840W Printer
DELL Studio 1537 intermitently disconnects from my wireless network then wont find my network but finds several others in my neighborhood that are far away or says no wireless networks available. My other...
Your signal probly getin week at times ,,walls weaken wifi,,,and if other computers goin on same wifi,,a stronger cpu,,like a desktop or so,,stronger cpu will hog all wifi from the weaker one,,,also try dell website fro driver updates
Nov 04, 2010 | Dell Studio 1537 Laptop
Intermitant internet access ,is this router compatable with windows 7
a router doesn't have any drivers, so therefore will work on all operating systems, there are quite a number of reasons for getting cut off, your first step is to phone your ISP and get them to do a line check, also if you are using wireless to connect try using an ethernet cable to make sure it isn't due to wireless interfereance, try replacing the filter, make sure you unplug all extensions apart from the routers,
Mar 16, 2010 | NetGear DG834G Wireless Router
Intermitent internet speed on medion laptop with Atheros AR5007UG wireless network adaptor
Hello, Peter_Street
What do you mean by intermittent Internet speed? Are you hardwired or wireless?
There are time when Internet traffic is heavy, does this happen at certain times of the day?
Aug 11, 2009 | Computers & Internet
My dell wireless mouse works intermittingly. Starts skipping and then works for a while. Changed battery and cleaned mousepad no improvement.
At the back of the Mouse, there will be small flushed 'reset' button. Press that. It resets and reconfigures the connection.
Have a nice day :)
Jun 11, 2009 | Logitech Wireless Access Duo Optical...
Intermitant signal
on your computer goto start - run - type services.msc and press enter.goto wireless zero configuration and enable it. now goto start - run type msconfig and press enter then goto startup and uncheck your netgear adapter.press apply and OK or close. restart your computer.goto start - control panel - network connection then right click wireless network connection and view available wireless networks.select your network and connect.once it`s connected goto start - run - .cmd - enter..type ipconfig..you`ll get ip address,subnet mask,default gateway.copy it. now right click wireless network connection again and click on properties and double click on internet protocol(TCP/IP).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
this will fix your problem...
Jun 11, 2009 | Arris SURFboard SBG900 Wireless Router...
Gateway laptop, can't connect to internet
Network controller in SouthBridge chip on motherboard needs REFLOW or replacement.
Basically board needs service.
Apr 02, 2009 | Computers & Internet
Belkin G wireless router- intermitant reception
Try getting an antina upgrade kit and possable a rang expander kit too.
Jan 15, 2009 | Belkin (F5D7230-4) Router (587009)
Garage Door Opener Intermittingly Reversing
try adjusted the sensor controls on the sode of the unit other wise replace the logic board
http://www.chamberlain-garage-door-openers.com/circuitboardcompatibilitychart.htm
Dec 24, 2007 | Sears Craftsman LiftMaster Chamberlain...
Right mouse button, wireless intellimouse explorer 2.0
the right and left buttons are controlled by a switch you need to replace the switch
Dec 07, 2007 | Microsoft Wireless IntelliMouse Explorer
D-Link AirPlus DI-524 Wireless Router Logo
62 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
