Question about Car Audio & Video
My cd player doesn't let me put cd's in and my tape player doesn't play cd's it's says this "Side 1, Side 2, Side 1, Tape Err"
  • 6,831 Answers
Hello
Ok, first of all, if i understand you correctly, your cd player and tape player have stopped working simultaneously?
If so, the problem is most likely not mechanical, because the two separate systems work on different mechanisms. hence, this is a circuit error.
I would firstly suggest that you have a look at the warranty of the player, if still in the warranty period, i would suggest that you take it back to point of purchase. If not, you could start by resetting the layer before starting to spend money on the repair. Unfortunately, you give to little info on the specific player.
PLease do not hesitate to let me know if you have any further questions.
Kind regards
Andrea
Posted on Aug 03, 2010
2002 acura tl type s cd player works but sounds distorted, everything else plays and sounds fine?
thats a lazer problem in the cd usually a cd cleaning disk will sort that problem if not a its the lazer head thats distorted best this to do it put a conversion tape to ipod or iphone and play your tunes off those devices via your tape, there only cheap to buy.
May 04, 2014 | 2002 Acura 3.2TL
Alba DVCR-2 Err:03, Err:02, Err: 01 problems
you have a faulty SYSCON MICROCONTROLLER.+faulty associates circuits, like CLKS, RESET.
you must go to the repair shop TV for fix it.
However you can try as the last thing before to go the repair shopt, Clean tHE VHS+DVD, with tape cleaner+disc cleaner too.and Proof
God bless you.
Aug 02, 2012 | Broksonic DVCR-810 DVD Player/VCR
I have a cd stuck in my cd player and can not get it out i have a 2003 e class merc
FIRST Reduce electrocution risk by disconnecting all power supplies from the CD player and make sure any electrical charge has been removed.
Method 1
Take a blank/useless CD (such as AOL free trial CD's, you can get them in a plethora of amounts in Best Buy) and place it about 1 inch deep into the slot
Press the 'Eject' button and gently wiggle the CD around. If this doesn't work, repeat and try to get the blank CD below the the jammed CD, and gently pry the target CD upwards.
Method 2
Get a 1 inch to 2 inch wide putty knife and wrap tape around it with the sticky side of the tape on the outside of the knife. Use a strong tape like Gorilla tape for best results. The knife is typically tapered so that if you wrap the tape tight enough it will not slide off the end
Get a piece of paper and stick it to one side of the knife. Trim with scissors. You now have a thin sticky knife you can slide into the CD player opening
Insert knife into CD player with sticky side down trying to get it to go on top of the CD that is stuck. Press down gently to get the tape to stick to the CD.
Gently lift up and pull the knife out. Hopefully the CD will come with it. You might try hitting the eject button if it doesn't work the first time.
Method 3
Get a stiff plastic "card" - like a drivers license but a bit thinner. Put double-sided scotch tape on one side of the card, near the edge of one of the two narrow ends of the card.
Get a thin-stemmed flat head screwdriver (short is better).With the sticky side of the card facing down, stick it into the **** ABOVE the stuck CD. You may have to use the screwdriver to ensure the card goes in above the CD and does not stick to the CD until after you get 1/2 to 3/4 inch of the card in above the CD.
With the card still in there, insert the thin flat screwdriver ON TOP of the card and gently press down on the card. This causes the tape on the bottom side of the card to stick to the top side of the stuck CD.Remove the screwdriver and then slowly pull the card out. The CD should come with the card.
Check out this youtube viedo for a first hand look at what to do.
May 25, 2011 | 2004 Mercedes-Benz Mercedes Benz E Class
Tape to tape recording
Just put the tape to be copied in side A while the other the blank tape in side B. Press the play in side A . Then in side B simultaneously press the "Play " and the "Record". Then it will starting to record it will automatically stop.
Good luck:
Dont forget to rate:
Jul 01, 2009 | Panasonic SC-AK18 CD Shelf System
Casstte Player- '94 ford
I think you are saying you are using a cassette adapter to play the external iPod/PSP etc. and I presume the cassette plays regular tapes OK. The auto-reverse cassette player thinks the 'tape' is over, so reverses then ejects. You can try putting in a regular tape, change sides then eject. Try the adapter again. Hopefully the adapter will work in 'one' direction.
Apr 13, 2009 | Car Audio & Video
Sherwood 460 equalizer hook up
Connect the EQ to the Sherwood as if it were a tape deck: EQ's outs connect to receiver's tape ins (play) and EQ's ins connect to receiver's tape outs (record).
Then you hook the tape deck up to the tape ins and outs on the EQ: Tape deck outs connect to EQ's tape ins (play) and tape deck ins connect to EQ's tape outs (record).
This will put the EQ in your receiver's tape loop.
The CD player should be connected to the receiver though the CD in's and out's (or if your Sherwood doesn't have a CD in/out, then use AUX or TAPE2).
To hear the EQed signal with all receiver sources (like the CD player) you'll need to engage the 'Tape Monitor' button or switch which will route the tape loop to the speakers.
Jan 09, 2008 | Audio Players & Recorders
Califone 2385AV-02
PUT AN CLEANER DISK INSIDE(DISK WHICH CLEAN OPTICAL PATH INSIDE)-YOU CAN OBTAIN IT FROM NEAR RADIO SHACK.
PUT AN GOOD CD AND TEST.
Jan 04, 2008 | Califone International (2385AV-02 ) Single...
Cassette Player Stopped Working
In all likelihood the Drive belts have snapped. Get them replaced.
Sep 24, 2006 | Aiwa XR-C3RW Shelf System
Car Audio & Video Logo
18 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
