Question about Microwave Ovens
My microwave has problem. It still runs (can rotate, light is on, there is noise). But there is no heating effect at all. I guess it is because my mom accidentally put Aluminum foil inside last week. Below is info of the microwave: Brand: GE; Model #: J TP86B0F3BB 6.6kW Series #: MG699966Q Manufacture date: July 2004 The following link (http://www.ehow.com/how_112488_diagnose-microwave-oven.html) says that it maybe a magnetron problem and I need to find a professional. Can anyone help and give suggest? Can I order one and replace it myself?
Falling Down
  • 67 Answers
SOURCE: Hole in plastic on inside of door
check the conductivity of the plastic with an ohmmeter by placing the probes an inch apart on the plastic surface. If the resistance is large or infinity, the plastic probably performs no role in stopping the microwave radiation. If so, any epoxy probably can be used to close the hole safely. Make sure you don't use too much and if possible place tape over the repair and orient the microwave so the epoxy presses against the tape while drying to prevent it from oozing into any door hinge/close mechanism. Otherwise, a piece of microwave door glass from a broken unit can ge glued over the hole and should stop the radiation. You can check for leakage with test units but be very carefuly anyway.
Posted on Nov 30, 2007
  • 21 Answers
SOURCE: Microwave not working, please suggest
Your magnetron tube has failed. According to the warranty on the Profile Series microwave ovens, the magnetron is covered for 5 years from the date of purchase, but labor is not included. I would call GE Customer Service and when they ask for the model number (which begins with JVM) and the serial number, be sure to give the date of purchase as the date you closed on your house. If they insist upon charging you for a service call and labor, I would call my builder's Customer Service Department and demand (very nicely) that they intervene with GE to waive the service and labor charges. That worked for me (Lennar Homes).
Posted on Aug 07, 2008
stonephoenix
  • 563 Answers
SOURCE: GE Profile Microwave will not heat
Unfortunately, there is no way to tell which part the microwave needs without opening it up for examination. There are a few parts that, if defective, would prevent the oven from heating.
  • a high voltage transformer which passes energy to the magnetron
  • a magnetron which converts high-voltage electric energy to microwave radiation
  • a magnetron control circuit (usually with a microcontroller)
This is NOT a repair that you would want to attempt yourself. The labor for the repair would cost a minimum of $50 and shouldn't exceed $100. You'll also have to pay for the necessary part if it's still available from the manufacture or their parts distributor.
Posted on Feb 04, 2009
bestdarngood
  • 3037 Answers
SOURCE: run but does not heats
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food. The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing. There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however. Benjamin
Posted on Jun 07, 2009
  • 4102 Answers
SOURCE: microwave oven wattage question
hi, you are correct it is 950 watts as you have read this on the microwave itself, when they sold these they kept the same model number but as they bought newer ones out the wattage increased so they kept the same number so its nothing to worry about it was just yours must have been a newer model then the first ones they made.
the first ones they made started at 700 then they did an 850 then a 950 so you are right its just a case of giving the same model number as the only difference is the wattage everything else is exactly the same, you wouldnt tell the difference if you had them side by side as its only the wattage that changed on this model
Posted on Jul 10, 2010
Testimonial: "Thankyou! This was very helpful information!!"
Lg mv1511M microwave making noise and not heating
I don't have a solution, but keep the oven unplugged until you find a solution, please.
Feb 14, 2013 | Microwave Ovens
GE spacemaker xl microwave oven will not heat
My guess is the magnetron is bad. It is rarely the transformer
Jan 04, 2013 | GE Profile Over the RanMicrowave....
GE spacemaker XL1400
what problem do you have mention ? attached is there a list please indicate. God bless you
    No Lights or Power, Unit seems Dead The voltage to the unit is good.Lights come on, but can not program unit, Touchpad dead
    Microwave Runs, but no Heat Turntable rotates, acts like it is heating but doesn't. This is the big one, many possibilities.
    Microwave Runs, Heats, but turntable does not move
    Microwave is arcing
    Microwave Vent Hood is not working Over The Range(OTR) Models.
    Microwave Stove Light not Working OTR models, light bulbs good.
    Microwave overheats and keeps turning off
Oct 01, 2012 | Microwave Ovens
Microwave MH6140XKQ doesnt want to start
Toss it out. The transformer is likely bad.
Nov 18, 2017 | Whirlpool MH1140XM Microwave Oven
Hi when we using oven, its light is on and the try is also rotating, but it is not cooking means the heating effect is not coming.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jul 24, 2011 | LG LMH1517 1000 Watts Convection /...
The microwave is running with a big noise and can not heat food
The magnetron "heats food" has probably failed and is loading down the high voltage transformer making it labor as it runs, also the high voltage diode and capacitor must checked since they are part of the high voltage system. This not be cost effective to repair.
Feb 01, 2011 | Sharp R-630D Microwave Oven
Microwave GE JES738 doesn't heat
Almost certainly the magnetron tube in your oven shorted and caused the light show and sound effects. This is the microwave source, and without the waves there's no heat. The tube is replaceable, but it's a costly parts. Add in repair labor, and you'd be better off replacing the oven. New ones are often cheaper than the parts alone today.
Apr 03, 2010 | GE JES738 Microwave Oven
My frigidaire microwave does not go on
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, and very detailed symptoms, answering these questions:
- Is it dead? (meaning there is no display, no light when you open the door, and no beeps when you press a key)
- Does it run but no heat? (meaning the inside light, cooling fan, and turntable all work)
- Does it make any unusual noise?
- Is it louder or quieter than normal?
Nov 25, 2009 | Frigidaire FMT116E1B Microwave Oven
Microwave runs but doesnt heat
Runs ?? I guess you mean the light comes on and it rotates ??
Make sure its is on high cook mode ( in case someone has it on defrost etc) Try it with a half glass of water - if it does not boil, chances are your microwave unit inside the case has died - not uncommon fault and not worth getting fixed as the replacement part + labor is more than the cost of buying a new one.
Nov 07, 2009 | GE JE2160 Microwave Oven
Not working
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician, as repairing microwaves is a pretty risky job.
Oct 05, 2008 | Microwave Ovens
Microwave Ovens Logo
206 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
