Question about Sony PlayStation 2 (PS2) Console
My son's PS 2 motor will not turn. At first it just would not do anything. I have replaced the motor and laser assembly and the laser is now working good but the motor is still not working. It is at least now trying to read the disk but can't because the motor is still not running. Is there something I missed or could there be more problems with it.
My son's PS 2 motor will not turn. At first it just would not do anything. I have replaced the motor. the motor is still not working. motor is still not running. Is there something I missed or could there be more problems with it.
Posted on Dec 23, 2009
  • 975 Answers
Do a check for a tiny switch that activates motor when the tray rest in fully. hope it helps
Posted on Apr 25, 2008
PS2 slim laser and disc motor don't work
I may not be the laser asembly or anything you described because absolutely nothing happened when you put a disc in. I may be a little switch at the very front of the drive right at the bottom right (near the power button) that may be damged or not being pressed by an piece of plastic on the same place on the lid. That switch recognises if the lid is closed or not so it know when to stop or start a disc. Try closing the lid harder or pushing more on that switch. hope that helps!
Jan 09, 2012 | Sony PlayStation 2 Slimline Console
Error code 52.0
A laser/scanner error has occurred
Recommended action:
1. From the DIAGNOSTICS menu, run the
laser/scanner motor component test.
Verify that you can hear the motor
rotate.
2. If you cannot hear the motor rotate,
verify that connector J1702 and J1505
are fully seated on the DC controller
PCA (ECU).
3. Verify that the connector J12 on the
laser/scanner assembly is securely
attached.
4. If the error persists, replace the laser/
scanner assembly
Jan 18, 2011 | HP LaserJet P3005n Printer
Defective replacement part? just got a replacement DVD assembly, laser doesn't light up motor only turns in small revolutions. Put in the old unit and the laser lights up but again motor barely turns
thanks to fixya....turns out a glob of solder needed to be removed from a new replacement part....once removed and installed my dvd player works fine.
Dec 22, 2009 | Onkyo Televison & Video
PS3 Inserted media is not spinning
I had the same problem with my PS3, I changed my 400aaa and thought it would fix the disc not spinning problem. It was'nt until i bought another brand new laser that it started to work again. I have heard rumors that some of the lasers you buy (like from e-bay) work but dont work right. I wound up spending over $140.00 to find out that my "New" laser was a refurbished one from China and didn't read any of my media. I went to a U.S. seller and he got me a new laser with a warranty and I'll be damnned if it didnt boot right up and run after that.
Aug 06, 2009 | Sony Video Game Consoles & Games
My p-2 wont read anything but one disk game-gta-3.isnt that old,or beaten,been left on a few times,,discs are in good shape,can i clean it.or ?i got a brand new game today,,wont do nothin,gta-5.,,,dvd vids...
Your PS2 is equipped with a cooling fan which keep it nice and cool, the only problem is that it sucks up dust in the process.
*** WARNING YOU MUST BE VERY, VERY CAREFUL ***
Take your PS-2 apart, you will see the "eye" or laser, this is something you NEVER touch!!!!
Do not use a air compressor, it will spray moister and it has to high of a PSI!!
Get a can of compressed air and hold it upright (do not tilt the can of air or shake it or it will spray nitrogen, freezing your PS-2) and spray the PS-2 with the air using 2 second burst, moving the PS ,not the air. Be sure to spray the "eye" and the housing.
Reassemble the PS-2 and it should work fine.
If not, you need to replace the laser.
Aug 02, 2009 | Sony PlayStation 2 (PS2) Console
Screeching noise
Taken from /www.fixyourownprinter.com and definitely works. Don't touch the shiny hexagon part when doing this.
If you hear the squeal, then it is the laser/scanner motor in the laser/scanner assembly. It can sometimes be fixed but you have to be careful. You have to remove the top cover and the big black box in the center is the laser/scanner assembly. Sometimes you can access the motor by just removing all the cables from the laser/scanner and then removing the screws which hold the cover on the laser/scanner assembly and remove the cover. If you can not access it that way, then you have to remove the 4 additioal screws which secure the assembly to the frame. Now once you have access, the motor is the silver colored round item in the back of the assembly mounted on a small circut board. Remove the circut board and remove it from the laser/scanner assembly. If you look real close there is a small white plastic piece which holds the round motor piece in place. Use a needle nose pliers to remove that white plastic piece, but do not lose it. Now you can remove the round piece from the motor itself. Now here is where you have to be very careful. You will want to use 1 or 2 very small drops of light machine oil (tri-flo or similar) into the motor shaft. I would just use 1 drop and it should all disappear down the shaft. If you can see the top of the oil you put in to much. Now put the shaft and round piece back on, put the while locking plastic piece back on and reassemble and it may just work just fine. If not then the complete laser/scanner needs to be replaced.
Jul 20, 2009 | HP LaserJet 2200D Printer
Technics SL PD8 laser replacement
The answer is yes you do. The replacement laser pickup assembly has 2 motors already fixed to it so the pegs in the suspension have to be removed (2 off) and it is best to prise open the split in the receptacle to facilitate this without damage.Then 3 screws on the pcb need unscrewing and after the solder has been removed on the motors the boards will come apart.
Dec 31, 2008 | Technics SL-PD8 5-Disc CD Changer
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Oct 22, 2008 | HP LaserJet 2840 All-In-One Printer
Smearned Printing on Ricoh Aficio AP3800C Laser Printer
Hi there the smudges are most likely down to the black PCU (Drum Unit) and following are the reasons for the two fault caode you have given me.
SC 261 LD HP sensor
not switched
off (for K only)
After the laser beam pitch was
changed, it takes more than
five seconds for the HP sensor
to switch off.
• Defective motor
• Defective sensor
• Mechanical problem
when switching the
actuator
• Brown fuse (FU81) on
the Power supply unit
1. Turn the main switch off and on.
2. Check the sensor actuator position of
the LD positioning motor.
3. Replace the LD positioning motor.
4. Replace the LD home position
sensor.
5. Check and/or replace the PSU.
SC 380 Black
development
motor error
SC 381 Color
development
motor error
When the motor speed is
within the target level, the
motor sends a lock signal
(High to Low at CN214-5) to
the BCU.
SC380 is detected under the
following conditions:
• The Lock signal stays High
2 seconds after the motor
turns on.
• The Lock signal stays Low 2
turns off.
for more than 2 seconds
while the motor is on.
• Defective motor
• Defective BCU
2. Replace the motor.
3. Replace the BCU.
Hope this is any help
Thanks J
Feb 21, 2008 | Ricoh Aficio AP3800C Laser Printer
PS" Version 12
check to make sure flat cable that connects laser is installed correctly or isnt damaged.
Jan 09, 2008 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 (PS2) Console Logo
89 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
