Question about Toshiba 50H82 50" Rear Projection Television
Why is my toshiba tv showing double - Toshiba 50H82 50" Rear Projection Television
  • Toshiba Master
  • 8,457 Answers
The tv have a problems known as a Convergence problems,it dead.The tv convergence board require it 2 STK convergence ICS and some or all it resistors to be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Posted on Aug 03, 2010
Toshiba tv has no sound but does with DVD player on, how do I regain sound for tv shows
is the dvd player a home theatre system?if yes,does the tv play sound via the dvd home theatre speakers when it is on?if yes then maybe you should double-check your audio port connections between the two for correct configurations
Jan 04, 2016 | Toshiba Televison & Video
Toshiba 30HF84 Picture Doubling and Shaking
Check its main power regulator section for any faulty capacitors.
Sep 01, 2012 | Toshiba 30HF84 30" TV
Double photos on screen
Hi:
You have a convergence problem , the Convergence IC's are bad, Have the Convergence IC's Replaced to restore set to normal operation and Picture. The numbers on the IC's are the part numbers. They are the two large black IC's mounted on a Large /Heatsink..
Dec 27, 2009 | Toshiba 50H81 50" Rear Projection...
Toshiba Big Screen Tv Has Bad Colors
this is a rear projection tv not lcd the color is off because the convergance chips are bad take the board out that has the tow stand up chips attached to heatsinks out order the stk number search for on google then take a om meter check all the resistors aroung the chips replace them also you must be a excellent soilder person or a tech to install and remove these chips
Oct 19, 2009 | Toshiba 32 AV 500 PG 82cm 32 in. LCD TV
Tv shows double images
Look for the convergence menu in the manual and try to align it.
Apr 02, 2009 | Toshiba TP55H60 55" Rear Projection...
My TV is showing a double picture
If the picture looks like a 3D one, the problem is a convergence issue. This can be as simple as poor connections at the pins of the convergence ICs or defective ICs. If you can solder you can probably fix this yourself. Please note that there are potentially dangerous high voltages inside the set even when unplugged.
If you wish to attempt the repair, please update this and I will provide additional details and instructions.
Dan
Mar 02, 2009 | Toshiba 43HX71 43" Rear Projection...
This is a problem within the convergence circuit. If you can solder you should be able to repair this yourself. Let me know if you wish to attempt the repair and I'll provide additional details and instructions.
Dan
Jan 27, 2009 | Toshiba 55H70 55" Rear Projection...
Green and pink double vision on my tv
This is a convergence problem. Try resoldering the pins on the convergence ICs. These are large black ICs attached to a heatsink. They should have about 15 pins and be marked STKxxx. If the resoldering does not resolve the problem, replace the ICs. These should cost about $15-$25 each.
Dan
May 12, 2008 | Toshiba 43H72 43" Rear Projection...
Showing doubles
your tv IF circuit needs to be align take it to a tech.if you are using antenna then you change the position of the antenna.good luck.
Mar 30, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba 50H82 50" Rear Projection Television Logo
83 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
