Question about Peg Perego John Deere Gator HPX Ride on Toy
Gear slippage. Horrible sound. - Peg Perego John Deere Gator HPX Ride on Toy
Gear box gears are probably sheared off. this happened to ours. Order new gear box--easy to install.
Posted on Aug 03, 2010
Originally, i was experiencing slippage in the lower gears but after a week it has moved to all gears..Is it possible this is a chain issue? This is a 2003 kawasaki vulcan 800.
Hello Mike
As the slippage has got worse through each gear now, it sounds like clutch slippage. at first you would of only noticed it in the lower gears as they have more mechanical advantage but as the wear in the clutch got more it now takes less power "torque" to make it slip.
This may just be adjustment, but by now the clutch may be worn out, yo should have some free travel in the cable. should be evident at the lever, usually allow the thickness of the end knob as a distance for the lever to move before it starts to disengage the clutch. there could be adjustment at either end of the cable, this will look like a thread with a lock nut that the cable goes through.
Jan 03, 2017 | kawasaki Motorcycles
I replaced the starter and am still having bad start ups
what does it sound like ,,, big high pitched screech is loose fanbelt ,,,,
Feb 14, 2012 | 2004 Jaguar X-Type
On mySuzuki 600 Bandit 2003, iI feel a knoking noise on 4Th and 5ft gear.No slippage, good power.
Normally, a knocking sound in a specific gear set indicates a broken gear tooth. When replacing a broken gear, replace the gear(s) it engages with as well. If you don't replace them you will have the pleasure of doing the repair job all over again when the weakened tooth on the existing gear(s) breaks off. Remember, whatever caused the problem in the first place put pressure on both the broken tooth and the gear it was engaged to at the time. Most likely is a tooth on a slider gear.
Mar 09, 2011 | 1991 Suzuki GSF 400 Bandit
1995 Mazda MPV - reverse gear in automatic transmission will not engage. No past problems. No history of slippage in any gear. 2 wheel drive vehicle.
SOUND LIKE BAD TRANSMISSION YOU CAN CHECK THE TRANS PAN FOR METAL SHAVINGS TO MAKE SURE YOU NEED A REBUILD. ALSO CHE YOUR TRANSMISSION FLUID SEE IF ITS RED OR BROWN BROWN MEANS USUALLY TRANSMISSION IS BURN OUT
Dec 23, 2010 | 1995 Mazda MPV
My volty is making a large sound when I hit the start switch I just changed the starter motor , but still making a horrible sound when trying to start it.?
U forgot to CHECK the BENDiX gear!
Thats the thing that makes that horrible sound!
It might STOCK or needs a lubricant!
Check that and i assure u thats the fault of that noise!
Nov 23, 2010 | 2000 Suzuki Volty
1994 Chevy Suburban Gear slippage
I have had that feeling in my 95 Blazer and it turned out to be a $15 fix. It was the U-joint. Crawl under there and wrap your hands around the drive shaft. Rotate it back and forth. If there is a lot of slop, then it is the U-joint.
Dec 25, 2009 | 1994 GMC Suburban
4th gear has a horrible noise coming from it, any ideas
sound like a trany problem tumblers or 4th gear itself mabe a shifter fork
Jun 22, 2009 | 2005 Harley Davidson FLHT - FLHTI Electra...
Slippage in second gear,pulls fine in all other gears and shifts fine,feels like broken tooth off gear or something of that nature
A broken gear tooth will cause a clicking sound. Start out in 2nd gear going slow. Hear any clicking? If so then TWO gears need to be replaced > the broken gear and the gear that meshes with it. If enough pressure was on a gear tooth to cause it to break, then similar pressure was on the gear it was engaged in. The gear may look okay, but it isn't. ALWAYS replace gears in sets.
Please rate this answer. Thanks John!
Apr 17, 2009 | 1997 kawasaki VN 800 Vulcan Classic
Peg Perego John Deere Gator HPX Ride on Toy Logo
262 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Marvin
Marvin
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
