I have a giga-byte 945gcmx-s2 motherboard and a Intel E6300 cpu. In the CMOS i have a vcore fail error. Everything else is fine and There is no problems with the system or cpu temp. Could you help me with this.
  • George Maeweather Aug 03, 2010
    thanks I will give it a try.
    Guru:
  • 632 Answers
Any multicore proc would have issues w/o the spare power to draw on.
If you have a duel power connection then it will require both the power wires to connect for the VCore to work correctly, It could also be due to power supply not powerful enough for the pc..
Try resetting your CMOS to default see if that solves anything if it doesn't then Its down the the power supply.
Posted on Aug 03, 2010
Issue modify vcore for e6300
Really?
Are we talking about the Asus P5LD2-VM motherboard, Zoltan?
(Zoltan is a C-o-o-o-o-l name!)
Because I'm looking at the motherboard manual right now, and state you are mistaken.
1) Use the Right Side Arrow key, and highlight the - Advanced - tab on top of the Main menu.
2) Use the Down Arrow key and highlight -
JumperFree Configuration
Press the Enter key.
Configure System Frequency/Voltage
AI Overclocking - [Auto]
Use the - key, (Minus), and move Auto to Manual
Use the appropriate arrow key, and highlight -
CPU VCore Voltage [ Auto ]
There are 40 Voltages you can choose from.
1.7000Volts to 1.2875Volts.
Remember,
Use SMALL increments at a time. Do a 24 hour stability test.
(Small increment example, 1.7000V to 1.6875V )
If your system is stable for 24 hours, then you can come back, and change the Voltage one more small increment.
(1.6875V to 1.6750V)
Also remember; you are changing the Front Side Bus of the Processor. (FSB)
Change it TOO much, and your ram memory, and expansion slots will not work.
(Ram Memory typically operates at a frequency rate ('Speed'), of half of the FSB of the Processor.
Processor FSB is 800MHz for example? Ram Memory operates at 400MegaHertz.
Intel Core2 Duo E6300? 1066MegaHertz Front Side Bus.
{1066MHz FSB}
Ram memory? 533MHz)
Asus Support > P5LD2-VM > Download page,
http://www.asus.com/Motherboards/Intel_Socket_775/P5LD2VM/#download
For the - Select OS box, click on the blue Down Arrow, and choose WinXP. (Doesn't matter as you are just going for the manual)
Click on the + sign next to Manual (14)
Scroll the inside scroll bar down until you come to -
Version E2281 -
P5LD2-VM User's Manual for English Edition (E2281)
Click on the blue - Global
A PDF file version of the motherboard manual will come up.
Using the PDF file page number box at the top, go to;
Page 63 - 2.4 Advanced menu
Page 65 - CPU VCore Voltage [Auto]
http://www.techwarelabs.com/reviews/processors/e6300/
Overclocking article at the end. Just one of the hundreds of overclocking articles out there.
Regards,
joecoolvette
Aug 15, 2012 | ASUS P5LD2-VM Motherboard
I don't have audio driver of GA-945GCMX-S2
Try the following website, this should resolve your issue:
http://ee.giga-byte.com/products/mb/driver/ga-945gcmx-s2_66.html
If this has helped resolve the problem then please rate my answer - thanks :)
Oct 20, 2010 | Gigabyte GA-945GCMX-S2 Motherboard
WHAT IS THE APPROPRIATE CPU FOR GIGABYTE GA-965P-DS3
This is a socket LPA 775 motherboard, it will accept almost all core 2 / quad core intel cpu's, here is the full list from gigabyte.
(you may need to unpate the bios for some CPU's)
http://ee.giga-byte.com/products/mb/cpulist/ga-965p-ds3_20.html
Sep 01, 2010 | Gigabyte 965P-DS3 (GA965PDS3) Motherboard
Giga Byte GA81RM REV 2.2 does not boot
Try clearing the CMOS by either taking the motherboard battery out for 20 minutes or moving the plastic jumper that is next to the battery to the other possition.
If this does not work then you are probably looking at a replacement motherboard.
Regards.
Feb 19, 2010 | Computers & Internet
Gigabyte ga-81915me dual core support or not
Double check your model number. GA-8I915ME, its not the number 1 to the right of the 8. Its the letter, capitial i.
I did not find your excat model number at Gigabyte, open link below;
http://www.giga-byte.com/Search/Search_List.aspx?Keyword=GA-8I915ME&SearchType=Spec Of the three listed I picked,
GA-8I915ME-C. Than I checked the CPU supported link;
http://www.giga-byte.com/Support/Motherboard/CPUSupport_Model.aspx?ProductID=1954
The GA-8I915ME-C Motherboard supports both dual core & Core 2 Quad.
Hope you find this helpful.
Cheers!
Mike
Oct 16, 2009 | Intel Motherboard
I need gigabyte fsb 1066 motherboard drivers
download from this link
http://www.lostmydrivers.com/bios-and-system-update-drivers/gigabyte/gigabyte-ga-945gcmx-s2-bios-f1.html
Jun 30, 2009 | Gigabyte Computers & Internet
I need graphics driver
Here is the download page for the Gigabyte GA-945GCMX-S2:
http://tw.giga-byte.com/Support/Motherboard/Driver_Model.aspx?ProductID=2521
Let us know if that's what you were after. ;-)
Feb 03, 2009 | Gigabyte GA-945GCMX-S2 Motherboard
Required sound drivers for windows xp
not for your os. its for ur gigabyte motherboard. visit the following link and download driver for ur respective motherboard model
or
http://www.giga-byte.com/Support/Motherboard/MainPage.aspx
Jul 19, 2008 | Intel Motherboard
Computers & Internet Logo
26 people viewed this question
Alun Cox
David Payne
David Payne
