I'm not sure you can insert your OS disk to istall or not, so the solution depends on your being able to do so. It seems to me there's a strong possibility that the BIOS cannot see the drive because that software had basic drivers to recognise the IDE Drive the computer came with.
So, you have to locate the SATA Driver which can be loaded during installation of the OS from either a boot cd or boot floppy. WIndows Setup gives you a chance at the beginning of setup if you watch the progress bar below to press F6 if you need to load a "Third Party or RAID driver" A little further along the setup will stop and prompt you for this driver and you'll need it ready with the exterior CD drive or floppy drive attached with the media in it to load.
It's quite possible this is what you're going to have to do. If this isn't the solution, please don't trash my rating with a thumbs down click. I'm trying to help without complete info.
Best Wishes
Test all leads that attach to your hard drive including electrical extensions IDE SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide
this will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure dust free connections and are not faulty even the electical extensions
or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
