Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Draining condenser tray
Please assist me in draining the tray near the water filter.
    President:
  • 1,314 Answers
If your system is operating properly there is no need to drain it coils from the system under the pan will evaporate it and will dry it over time long as it don't run over don't worry about it but you can take a shop vac and dry it if brothers you
Posted on Apr 25, 2008
    Genius:
  • 1,073 Answers
Normally the drain pan will evaperate the water as the compressor fan blows air across the pan along with the compressors heat
if you still want to rempve the water you can place a towell in the pan and let it soak up the water remove the towel and it will be gone
My frigidaire air conditioner is making my apartment feel damp and when i took my filter out to clean it that part was damp too! What do I do to fix this?
You may have a clogged drain or the unit is installed without enough angle pitch for the water to drain to the back of the unit toward the outdoor section of the unit. I'm assuming it's a window air conditioner? The moisture condenses on the cooling coil near the filter and should drip down into a condensate drain pan, then the water should drain to the back of the unit into a pan at the condenser coil fan that is rejecting the heat outside. The fan blade usually has a ring on the outdoor fan that pick up the condensate moisture the fling accumulated water onto the hot condenser coil to evaporate it. Also the filter should not be touching the cooling coil. Make sure it in the correct slot. Some a/c cooling coil require a wetting agent that allow the water to slide down the coil and not pull off of the coil into the indoor circulating fan.
Sep 11, 2015 | Frigidaire Heating & Cooling
My nissan quest 95 is leaking water. It seems is coming from around the filter. Need help please
Dear Helen,
Which filter? You have the air filter, the oil filter, and the cabin filter.
If it is coming out near the air filter or the oil filter, I should suspect a leaking heater or radiator hose.
A pressure tester for the radiator will help you find those leaks.
If it is near the cabin filter, it should be the drain tube for the air conditioner condenser, which is normal to leak when the air conditioning is running.
Try to catch some of the water that is leaking and see which fluid it is.
Air conditioner condensation water is clear, it even looks drinkable.
Anti-freeze/coolant liquid is colored blue, green, red, or yellow, (it depends on the brand) and has a distinct sweet smell and taste. No, I am not recommending you should taste it.
God bless your efforts.
Sep 04, 2015 | Nissan Cars & Trucks
Water doesnt drain and water nozzle doesnt spin...but it cycles
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 02, 2011 | Hotpoint 24 in. HDA3400G Built-in...
Water wont drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Daniel
Mar 18, 2011 | Dishwashers
Wont pump out water
Hi
Daniel
Feb 09, 2011 | Kenmore Dishwashers
Water doesn't drain out. Have tried Tang, then baking soda and vinegar and hot water. Help.
Hi
Daniel
Jan 07, 2011 | Dishwashers
Water wont drain from dishwasher
Hi
Daniel
Jan 01, 2011 | Dishwashers
When the unit stops running water is leaking down through the filter.
Either the drain tube is blocked or the drain tray has a hole rusted in it. My unit is a York and I replaced the condensate drain tray.
Sep 23, 2009 | Ruud UBHC Air Conditioner
Water running out bottom of freezer
That's exactly what it it. Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Aug 27, 2009 | Kenmore 53642 / 53644 Side by Side...
Water coming from under the refrigerator.. it is getting heavier
see if defrost drain tube is in the pan under the fridge and check it is not plugged
Aug 10, 2009 | Kenmore 53642 / 53644 Side by Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
204 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
