A/c outside unit is not working- fan will not work.
WeatherKing Select 10- model WAKA- 030JAZ. MFG. in 1996.
Indoor fan on our furnace is operating. Outdoor unit made a ''buzzing'' noise, but the fan will not engage. We do not have this on a circuit for this unit in the breaker box- there's a black unit outside on the side of the house by the actual a/c unit. Can't find an on/off switch to the outside unit- is there one?
    President:
  • 3,074 Answers
I assuming that the black box is a 100 amp breaker, which is connected to your condsensing unit (outside unit). If you open the box and pull the fuse then this will turn off/kill the power to your unit. As far as the buzzing noise it could be that the contactor is engaged. Hopefully, your fan motor is burnt out or the capicator is bad. If you take the access cover off and check for voltage at the contactor you should know if it is the fan motor. The voltage will come in at the bottom T1 T2 T3, once the contactor is engaged L1 L2 L3 will have the same power. Of course if your contactor is not engaging then thats the probelm, you can manual engage the contactor by pushing it in. There will be four wires two running to the capicator and the other to the contactor, these are the wires that control the fan motor. The other three wires run to your compressor. Hope this Helps Tim
Posted on Aug 03, 2010
Concept 1000 ac unit. Fan comes on but no air come into the house and the line freezes outside next to the unit. I'm lost!
Check your indoor air handler unit. If the coil is frozen, it is usually one of two problems. You are low on freon, or your filters are clogged and not allowing enough airflow over the coil.
Mar 20, 2017 | Heating & Cooling
Rudd model ukab-030jaz
You most likely have a small 3 or 5 amp fuse on the circuit board on the indoor unit that has blown. You should turn the power off at the main breaker panel and open the cover and very carefully look for a small blown fuse. It will look like one that you use in your car. Then if it is blown, replace it with the exact same size and rating.
Aug 17, 2017 | Heating & Cooling
I have Carrier 38TKB036 3 ton A/C condensing unit and one 28CCA036 3 ton A-coil to provide A/C to home thru existing furnice. A/C was on and stopped working. Turned off/on, but will not come on. Any...
Is the furnace fan (indoor fan ) running. If not the problem is with the inside unit. It supplies the control power to operate the entire system and has a control fuse on the circuit board. If it is running but not the outside unit then the problem is outside.
Aug 08, 2011 | Carrier 38CKC042 Air Conditioner
We have a weather king central air unit mod# WAKA-030JAZ. ser#5339 mo6959417. volts 208/230. compressor rla 13 5/13.5. outdoor fan motor f.l.a.9. mfd 02/05. hertz 60. l.r.a.76. hp1/6 min supply...
I would bet the outside units contactor is bad. This is the device where the two thermostat wire connect outside. If this is pulling in/out as you turn the stat on/off then it is working. I just fixed one yesterday with the same symptoms and found the start capacitors were bad. If they are bulged at the top or bottom then they are bad. Good luck.
Jun 19, 2011 | Weather King Heating & Cooling
I HAVE A WEATHERKING MODLE WAKA-037JAZ OUTSIDE AC UNIT WITH SPLIT GAS FURNACE-WHAT TON IS THIS UNIT
It appears you may have a 5ton unit, if your house is over
2000sq. feet then Im guessing that 60 thats appears in
the model number is equal to 5ton. 12,000 btus per ton
of cooling
Feb 28, 2010 | Weather King 10AJA6001AH Air Conditioner
Weatherking WRKA heat not working control board
U need to supply more info.There will be a sticker on the furnace likely in the lower Fan Compartment which will have a legend that explains each error code...ie: 3 blinks = Pressure switch etc....and u will need to provide more info on how the furnace is operating (whats it doing ) when it stops working or just prior to that
Oct 16, 2009 | Heating & Cooling
I have a weatherking model number waka-037jaz just bought this with a payne furnace from a gentelman who said they worked together when he removed them but furnace doesn't have an A coil in it how do u...
The furnace can handle three tons of AC but you will need a coil and a line set to connect the two. Get a match coil for your furnace and a line set. 7/8 and 3/8 plus tstat wire and tstat. Sometimes you get stuck buying used equipment and it cost you more in the long run. I have owned a company for 44 years and I never never sell used equipment.... If you need help write back I will be glad to help you. RUSS
Jul 18, 2009 | Heating & Cooling
BDP furnace + model 585A030080YACR
Sounds like your indoor fan motor is not working, check either the cap or the indoor fan motor it's self.
Jun 26, 2008 | Carrier Heating & Cooling
Heating & Cooling Logo
556 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
