Question about Numark ttUSB Turntable
Ground noise beep
Just bought the TTUSB Numark turntable and I"m hearing a high beeping noise, like as if the ground isn't connected. But as far as I know that isn't nescessary. Does anyone know a solution to this problem?
  • 4 more comments
  • Anonymous Aug 23, 2008
    I got the same noise
  • bgoe Nov 22, 2008
    idem
  • Anonymous Jan 28, 2009
    the same high ground noise...
    tryed different usb ports, but the same going on...
    i will contact numark for a solution but dont believe on... :(
    same problem with this high ground noise that makes me angry...
    tryed different usb ports, no chance...
    iam going to contact numark for a solution but i dont believe in...
  • Anonymous Apr 29, 2009
    same thing...
  • msolea601 May 09, 2009
    ditto. frustrating
djproaudio
  • 515 Answers
SOURCE: Ion ttUSB turntable fault
The ION should be internally grounded, however, it's possible the Tonearm might be faulty as well. Try a different USB cable as well - make sure you have one rated for the type of USB card you have (1.1, 2,0, etc).
FYI, this isn't the most sophisticated unit on the market, and not very well made either, so you might just have a faulty unit. If it's relatively new, I suggest calling in for warranty info, or try and return/exchange it.
- TWEAK AV LAB
Posted on Nov 23, 2007
  • 104 Answers
SOURCE: Numark turntable records record AND sounds in the room
the mic is in the computer somewhere, there will be a way to mute the microphone either in the vinyl software or in the system settings of the computer!
Posted on Feb 11, 2009
  • 69 Answers
SOURCE: Where do I connect the ground wire from my amp to Numark TT USB?
i used to have stanton t80s,had the same problem no gnd on deck but diddnt need it there waqs no bad earth so if it sounds good leave it
Posted on Aug 07, 2009
  • 1348 Answers
SOURCE: im new with the use
A turntable use a magnetic cartridge and its output is only 5 to 10 millivolts.A moving coil cartridge is even lower,.2 to .5 millivolts(thats 1/2000 of a volt)in contrast, a mp3 puts out a 300 to 900 mv signal..so does a CD player. Your turntable does not have enough signal.You need to get an amplifier that has a phono input. Years ago,radio shack used to sell phono preamps that could plug into a tape or cd input.The other option is to buy a used mixer that has a phono input.The mixer output can drive the cd input easily,as the max output from a mixer is 1.5 volts to 2 volts.
Posted on Dec 30, 2010
SuperTech-11
  • 1591 Answers
SOURCE: how do i hook a numark tt 1625 turntable to a
Turntables require a special input in the amp (usually marked PHONO) because they require high gain and different equalization - and yes, that ground wire has to go to ground unless you want to get a super annoying 60Hz hum from it!
If your amp doesn't have a phono input, you're going to have to go out and get a phono pre-amp and connect it between the turntable and the amp.
Best of luck!
Posted on Feb 26, 2011
Ringing when recording into mac
This sound like it could be somekind of feedback hum, or earthing problem. Check all the connections.
Mar 14, 2014 | Numark ttUSB Turntable
When I go to record or just listen to a vinyl on my Numark TTUSB, there is a background noise, which seems to come from the HD on my PC. Luiz Alberto Gomes Uberlandia - MG - Brazil
Do you mean audible over-the-air noise; or noise entering the recording? HD's make sounds when they seek. Recording uses the HD, so what's the mystery?
Aug 17, 2010 | Numark ttUSB Turntable
External noise
get audio cable maybe try going threw vcr or dvd if tuner wont accept
Dec 05, 2009 | Numark ttUSB Turntable
Jul 18, 2009 | Numark ttUSB Turntable
During vinyl play the sound will drop Numark TTUSB
sounds like the needle is worn down...try to replace the needle.....the buzzing sound often comes from open groung connections...that can come from the cartridge itself to the jacks on the back of the unit....bad ground and buzzing is normal for turntables and will also dramatically affect your sound level because the buzz or groung fault is higher than the sound being picked up by the needle.....open grounds can be checked with a meter set to continuity....to check for continuos line feed with no breaks in the lines.....if you find a broken line ...then that's your problem....it is a very simple repair....if the ground problem is in the cartridge...replace the cartridge which comes with a new needle as well...it's cheaper to buy it that way in stead of just bying a needle...if the ground fault is anywhere after the cartridge...then it's just a mater of replacing or repairing the line..again..very cheap repair....also...if the cartridge just clips on to the shell, sometimes it makes bad connections there too....that can just be cleaned with a little sand paper and it will work again....good luck
silvio
Jul 08, 2009 | Numark ttUSB Turntable
I Bought a TTUSb from an auction. I do not have software EZ Conv
My guess is that you have not bought a Numark turntable at all, but a fake. You should contact the auction site/place and inform them you have been sold a fake. Many sites have ways of dealing with fakes. You might even get your money back. If you are lucky!
Jun 15, 2009 | Numark ttUSB Turntable
Hum from ION turntable
need to be earth,attach wire form turntable to something that¬s earth
Jan 25, 2009 | Numark ttUSB Turntable
Not hearing songs I transfered to my i tunes from my Numark TTUSB
Open Preferences, Sound, your input should be  USB Audio Codec (turntable).. make sure your output is NOT USB Audio Codec, rather, headphones (for external speakers plugged in there)... thats how i have mine set up...
Jan 07, 2009 | Numark ttUSB Turntable
- TWEAK AV LAB
Nov 15, 2007 | Numark ttUSB Turntable
Numark ttUSB Turntable Logo
108 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
