Question about Maytag Dryers
I have a Maytag Performance Series clothes dryer Model PYE2300AZW (Serial # 10027449AJ). Out of the blue, when you press the on switch/knob, absolutley nothing happens. We have never really had any problems with the machine before. Could the problem be the switch behind the knob? Is this an expensive fix? Have limited resources at this time and would truly appreciate your advice on how I might get this dryer operational again.
    President:
  • 3,074 Answers
You can bypass the door switch, as they do go bad.
Posted on Aug 03, 2010
  • Sharon Tworek Oct 05, 2011
    How do I do that?
    Where is the bypass door switch?DG410 gas dryer Maytag
Maytag clothes dryer Model PYE 2300 AYW will not start. All elements tested okay. pye2300 AYW won't start.
Check the door switch. It might be a small button under the edge of the door. It's possible it is stuck.
Sep 26, 2013 | Maytag Clothes Dryer Almond Timer Knob...
I just want to know how hot the clothes part getts in the maytag performance gas dryer does the regular mode reach 122 degrees
Dave, Dave here.
I would type Maytag into my box in the top of the computer screen and see if you can find the phone number of the Maytag factory service representative.
They might be able to tell you.
Another choice would be to put a thermometer ( like a candy thermometer) inside another dryer belonging to someone else and look at it when it is in the middle of a heat cycle. You would want to hang it inside somehow so it did not tumble and break.
Be blessed.
Feb 22, 2013 | Maytag Dryer. Gas Dryer. Performance...
Maytag dryer pye2300azw shut off when drying the clothes i check breaker from house to dryer that's OK it won't turn on back
This dryer is fairly easy to repair.
The thermal fuse is probably blown. Look for air restrictions and a bad blower wheel to be the culprit. When that blower wheel starts slipping it causes the dryer to overheat.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 29, 2011 | Maytag PYE4558A Electric Dryer
MY pye2300azw maytag dryer does not seem to be heating hot enough. can you suggest a solution please. Does it need a new thermostat, nothing wrong with the heating element.
Number 10 is the most likely suspect. The blower wheel tends to get wobbled out and won't send enough heat through the drum making it take twice as long to dry the clothes.themobilian_13.jpgthemobilian_14.jpgthemobilian_15.jpgthemobilian_16.jpgthemobilian_17.jpg
MORE HERE
Nov 02, 2010 | Maytag PYE4558A Electric Dryer
Dryer element is not drying clothes like it use
if it takes too long check your vent
Feb 07, 2010 | Dryers
No power to dryer was working fine no warning would not start
Most likely a bad fuse. There is one above the heat element, also may have one on the blower housing. Test with an ohmmeter or bypass. Hope this helps!
Feb 16, 2009 | Maytag PYE2300AY Electric Dryer
Dryer knob sticks in one spot- won't move
 Door switch / Door switch actuator leverThe dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Oct 25, 2008 | Maytag Clothes Dryer Almond Timer Knob...
Dryer will not turn on
i've had my maytag dryer since 2002. it just stopped in the middle of a cycle. i think it's the motor. isn't maytag guaranteed for life???
Dec 22, 2007 | Maytag Dryers
Dryers Logo
220 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
