Question about Microsoft Windows Vista Home Basic Edition
CD DVD drivers not detected at start up
For about a 3 weeks now I have not been able to use my dvd driver for the above reason. Explorer does not show it.
I have Windows Vista Home and my computer is Acer Aspire 5520G.
Tried various suggestions made in the internet. Nothing worked. Seems to be a common problem?
I have automatic updating of Windows software releases. Viruses can't be the issue.
    Guru:
  • 158 Answers
This link will take you to my directions on how to install a new Hard Drive in windows 7.I'm sure its the same for Vista,Hope it helps,don't forget to rate!!!
http://www.fixya.com/support/r4990659-find_newly_installed_harddrive_in
Posted on Aug 03, 2010
Check my verify code
Unfortunately this can be a difficult question to answer because of the amount of potential reasons for this issue to occur
Verify you have the latest drivers installed for the CD-R or recordable drive. There are numerous driver related issues that may cause a CD-R drive or other recordable to stop reading a CD-R disc. If you are running Microsoft Windows verify your drive is properly detected and listed in Device Manage with no conflicts or errors.
If Windows Device Manager detects an error on the drive or if it has other drives listed in Device Manager with errors on them remove the device from Device Manager and reboot the computer to let Windows re-initialize the drive.
If Windows shows no errors, the above steps did not resolve the issue, or you are running a different operating system check with the drive manufacturer for updated drivers.
click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd drive restart your computer then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrative tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Oct 06, 2011 | Teac (DV-W58GA-PUK) Burner
Not detecting cd drive, boot device. I have tried cd drive that i know it works in other server. I have installed new hdd and want to load os. It shows specs of hdd but wont detect hdd or cd.
make sure all leads that are attached to your cd/dvd have secure connections and are not faulty or just replace them they could be faulty ?
you might have to physically unplug the cd/dvd drive restart your computer this should activate the found new hardware wizard
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Oct 01, 2011 | Intel SR1400 (SR1400NA) Rack-Mountable...
Can this burn using dvd+r rw? 'Cause it does not detect the blank dvd if I try to burn it using Nero 7.
is it only using nero that it does not detect your blank dvd ??
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
Sep 05, 2011 | LG (GCC-H23NB) CD-RW/DVD-ROM Combo Drive
Hello. For a few days now my dvd rom player on my acer laptop has stopped working. I have just bought the sims 3 on pc dvd rom and the drive does not detect the cd. Please help . Thankyou
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps you
Aug 17, 2011 | Computers & Internet
Not detecting windows xp booting cd vista booting dvd detected but showing size 0 canot creat patition what io
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
Jun 29, 2011 | Fujitsu (MHT2040BH-50PK) (mht2040bh50pk)...
How to get detected vostro1510 dvd drive in device maneger?
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Hope this helps
May 06, 2011 | Dell DVD-rom DVD Drive
The Computer doesnt detect the DVD ROM
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Hope this helps
May 04, 2011 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
I connected my ide lg dvd rom using ide to sata adapter in my mother board as my mother board does not have any ide connection. so since ti gets detected during boot time but does not shows up or does not...
make sure that the cdrw/dvd is getting enough power test all leads that are attached to the cdrw/dvd including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Apr 02, 2011 | LG GCC-4522B (0048231293594) CD-RW/DVD-ROM...
Drivers not working. Can not play any dvd,cd's.Its been about a week. Reinstalled drivers on Help and Support, but still not working. Any Ideas?
When you say Drivers not working, can you please confirm if you are referring to the CD Drives ?
If yes you can first make sure that the Drives are detected in Windows Explorer.
Click on Start Then click on "Computer" or "My Computer"
See if the CD / DVD drive is detected
If the drive is detected in Explorer and not able to read the discs, try various discs of different brands.
If none of the disc is readable then the Drive is gone back and you will need to replace it.
In case the Drive is not detected in the Windows Explorer then you can check if the device is detected the Device Manager.
To open device manager Press the Windows key + R and type devmgmt.msc
Press Enter of click OK
It will open the device manager
look under CD/DVD drive if there is any yellow exclamation mark.
If you see the Drive listed with an Exclamation then follow the steps to delete lower filter and upper filter from the Windows registry Editor.
http://support.microsoft.com/kb/929461
Jul 17, 2010 | HP Computers & Internet
Microsoft Windows Vista Home Basic Edition Logo
66 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
