Not heating - brings up E5 fault code on fairland airconditioner
Not heating - brings up E5 fault code on fairland unit. What does E5 indicate?
3 Suggested Answers
hvac1960
  • 2133 Answers
SOURCE: E4 code on lcd dont
E-4 means short of gas. Find leak and arrest. And then vacuum, recharge gas.
Posted on Jan 06, 2011
hvac1960
  • 2133 Answers
SOURCE: Fairland aircon error code
E-5 Outdoor activation of compressor over heatprotection or motor lock.
Check out door fan motor mechanism locked, replace motor. If less rpm replace capacitor. If condenser coil dusty, clean it. If no gas/short of gas, do leak test and rectify. Thanks.
Posted on Feb 08, 2011
What must we do to rectify an F8 fault?
I went to the roof and turned the unit off, waited a minute and turned it back on and the unit worked fine after that. It was a power failure that messed ours up.
Jun 03, 2014 | Carrier 36KCARMS Air Conditioner
Fedders Air conditioner
Try a hard reset first.Disconnect the machine for about 30 minutes and reconnect after that to see if the issue is resolved.
Jun 07, 2008 | Fedders A6P09S2A Air Conditioner
E5 shows on indicator ?
What make and model is it? E5 is an error code but different manufacturers use different codes which mean different faults.
Apr 09, 2014 | Heating & Cooling
Lennox codes
e5: open or short circut of outdoor yemp. sensor or outdoor unit.
see more Air Conditioning Fault Codes
May 11, 2013 | Lennox 7 Series MS7-HO-09P MS7-HI-09P Heat...
Fairland aircon error code E5 what is wrong
Feb 08, 2011 | Heating & Cooling
E4 code on lcd dont cool at that pont on fairland airconditioner
Jan 05, 2011 | Heating & Cooling
My GE wall Airconditioner is not cooling brings out warm air?
mcdevito75, here, wall A/C do they also give out Heat, if so, refer to the owners manual for instructions on how to use the cooling. Set switch to low cool and the switch with the blue scale about 1/2 way thru the blue scale shown on the switch (Knob) Both your A/C units may be set on heat, double check position on switches, (Knobs)
Jun 24, 2010 | GE AJCQ08ACB Air Conditioner
I have a Toyo Aircon split unit Airconditioner/heat pump. 12000 Btu. When in the heating mode, I get the code E8 after it runs for 5 to 15 minutes. At that point it seems to run (at least the...
You might want to refer to the unit manual, which has a fault code section (if the unit has a manual), look up the fault code E8, in the manual and it will tell you what fault it is. Depending on where the unit was manufactured, you may not be able to contact anyone regarding the warranty or diagnoses of the fault, so instead contact your local A.C company for help. Sorry I could not be of more help.
Dec 10, 2009 | Heating & Cooling
Carrier Thermostat Displays Error Code E3
Carrier Air Conditioning display an error code E5 and then swtich off
Apr 01, 2009 | Carrier TSTATHPP 7-Day Programmable...
Air Conditioner Error code?
Error "FL" is coming It is not going by applying suggesstion in your booklet kindly enlighten
Mar 16, 2009 | Haier Energy Star ESA3183 Air Conditioner
Heating & Cooling Logo
190 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
