Question about Bowflex Treadclimber
I NEED TO LUBRICATE THE TREADS ON TC5000,HOW DO I DO THATCMUSER
3 Suggested Answers
TC5000 eror ls
If you wish to get some details about treadmill repair and service ; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 02, 2017 | Exercise & Fitness
How to lubricate tc500
Nice machine! I use WD 40 on my machine. It comes with a small tube attached to the can that lets you get into joints and bearings easily. Keep the can handy if you work out regularly..it keeps it quiet and smooth!
Jan 12, 2013 | Bowflex Tc5000 Climber Treadclimber...
No treads on harmonic balancer. Should there be treads on the harmonic balancer because my serpentine belt came off and upon reinstalation properly I found that the belt had treads on the serpentine belt,...
the pulley on the crankshaft should have grooves in it for the belt, otherwise the belt will not turn. is the pulley broken off, get back to me. there are NO technical servise bulletins on this item,if you need more help get back to me, Thanks Ray
Dec 10, 2009 | 2001 Oldsmobile Aurora
I am having trouble with my Bowflex TC5000. The calibrations is failing. The treads aren't moving but the monitor is trying to calibrate.
The motor must move the drive pulley for calibration to pass. remove rear covers and check drive belt. you should hear the lwr board relay click to engage the motor. if you hear it and the motor does not move and you have checked the belt then you need to test the motor. Typically remove the belt and turn by hand...it should be very smooth and spin freely. If not replace the motor. Direct 9 volts to the motor leads unplugged from the board will tell you if the motor is good. be careful as capacitors are present and risk of shock is always possible. capacitors stay charged for about 10 mins after unit is unplugged
Jul 30, 2009 | Bowflex Treadclimber
Try to get started & get Error on led screan
Call manufactor for calibration procedure. If this doesnt work, you will probably need a lower board.
Jun 07, 2009 | Bowflex TC1000 Treadclimber
Bowflex treadclimber 5000
Napa 8300 silicone is recommended. Apply under belts from front to back one fluid spray and also in bearing areas. Squeaking can also be caused by the center of the treadles rubbing to hard. If this is the case they need to be adjusted.
May 29, 2009 | Bowflex Treadclimber TC5300
Black dust coming out
I just got a BowFlex TreadClimber TC3000. I have been using it for about 1 week and I noticed black dust coming out of the back. It was near the treadles. I called BowFlex and they said that this is normal during the first few weeks of use. This is the coating coming off of the treads. They said I could vaccum it up. They also mentioned that they only time to really worry is if there is white dust. That is the actual treads wearing off. Hope that helps!
Mar 19, 2009 | Nautilus Exercise & Fitness
Hi ddmyatt.. They sell what is call dry lube at sports store's. for spraying under the tread's and on the wheels that the tread run's on.. Lift the tread and spray as far under it as you can on both side's. She'll be lot's quieter then before and lots easier on the motor too..
Nov 03, 2008 | Bowflex Treadclimber TC5300
Bowflex Treadclimber Logo
159 people viewed this question
Top Bowflex Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
ka4iup
ka4iup
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
