Question about Husqvarna Designer I
I have a designer se the take up lever keeps dropping the thread
  • 201 Answers
Try threading with a figure-of-eight motion - take the thread to the left of the take-up lever hook, across through the hook, then down to the needle. This makes the thread cross itself below the take-up lever hook and may help keep the thread in place. Also be sure that your thread is in the tension disks properly. Always thread with the presser foot raised so the tension disks are open and the thread can seat itself properly. If this does not help, you probably need to see a machine technician.
Posted on Aug 11, 2010
Thread uptake keeps dropping thread after about 5 stitches Ive rethreaded changed needle checked bobbin area changed bobbin and still drops
Do you mean the thread comes out of the take-up lever when you sew? I have an old Pfaff that if I sew too fast, the thread "jumps" out of the take-up lever and then it's an instant mess of thread. I fashioned a small piece of tape to cover the opening in the take-lever and no more problems. Something like a drop of hot glue may work too.
If the thread is tightening at the take-up lever and eventually breaking, it is most likely because the thread is not advancing properly through the tension disk or the thread is hanging up somewhere between the thread spool and take-up lever. If you watch it closely, you may see the thread tightening and then be able to discern where the problem originates. (Make sure the thread is not hanging up at the thread spool.)
Jan 24, 2017 | Sewing Machines
Birds nests embroidering husqvarna viking designer se
it would be a good idea to have the machine serviced
Try these suggestions for bird nesting
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case
& make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
6. Check to make sure the bobbin is not warped or damaged
7. Make sure the bobbin case is correctly in the machine,, if it's a top loading bobbin you may need to have the bobbin case checked to see if it's damaged or see if the hook and hook race has a problem
8. Also could be a timing problem, and the machine would need to be checked.
Feb 19, 2014 | Sewing Machines
Viking designer SE sewing and embroider machine -- Thread that has come out of the take-up lever
If this problem persists there is an upgrade on the take up lever that has a plastic clip that holds the thread in better. Check with your dealer.
Dec 31, 2013 | Husqvarna Viking 1
Viking designer se machine Thread that has come out of the take-up lever
Some machines had a special plastic clip that was an update on the thread take up lever. Take it to your dealer for this.
Dec 31, 2013 | Husqvarna Designer I
Singer 2732 thread not staying on the take up lever
it's a problem with the thread take up lever, either put a small
piece of tape on the take up lever or take a pair of pliers and
carefully place a cloth over the take up lever and close the take up
lever a little but don't damage the take up lever
if you don't have a manual, here is a link for a free manual
http://www.singerco.com/uploads/download/1313_2732.pdf
Dec 19, 2012 | Singer 2732 Mechanical Sewing Machine
My Designer 1 embroidery machine thread take-up lever keeps allowing thread to slip off into the inside of the machine. The thread then becomes entagled and wrapped in the gears. I have taken it in twice...
Hi Kathleen
Why don't you ask that question of Viking Husquvarna head office in your country in writing and see if they have now got an aftermarket solution to this problem. Sometimes a direct approach is best.
If the thread take up lever has an open eye and the thread keeps slipping out of this, can you perhaps modify it a little yourself by using a small piece of plastic tape to close off the eye, maybe putting a little grommet in place first so the thread runs freely through it and doesn't catch on the tape. Worth a try?
Jun 21, 2011 | Husqvarna Designer I
I am having trouble with the free motion on my Viking SE. I can feel the thread sticking up on the back and the top thread keeps breaking. I have tried changing thread (four times) and changing needle...
I presume you have set the machine for free motion quilting in the Menu? There are so many things that could be causing this, and so many variables for tweaking it to optimum performance. What foot are you using? What thread? What needle? What menu setting? Have you tried loosening the top thread tension? Bobbin tension? I will keep a lookout for further posts from you with a bit more info that we can start working on. I have a Designer1, not the SE, but have used an Se so will try my best to help.
Dec 15, 2010 | Husqvarna Designer I
While quilting with clear polyester thread, the upper bar keeps dropping the thread or the thread breaks. What is the secret?
try these suggestions
the needle top thread tension is to tight
the needle is bent or blunt
the thread & needle are not compatable--here's how to check
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
you said the upper bar keeps dropping the thread--I think you are talking about the thread take up lever-an old sewing machine service tech I knew had a sewing machine that had that problem & he took a pair of pliers & closed the gap in the thread take up lever hole & the customer never had a problem with the thread coming off the thread take up lever again.
Oct 07, 2010 | Husqvarna Huskylock Computerized 936
When I am trying to do an embroidery design, the top thread keeps breaking. What could be the cause of this?
check your thread tension
check needle could be bent-blunt or damaged
thread could be caught on something
on some sewing machines the thread comes off the thread take up lever
Sep 23, 2010 | Husqvarna Designer I
I have a Designer SE and today while sewing the 'check upper thread' message kept coming up. There was nothing wrong with the thread and I rethread it several times after the message came up. I cleaned...
It's probably the sensor in the upper thread tension unit. If you look where the thread comes to the bottom before looping back up to the take-up lever, there is a small point coming out that holds the thread downward as the takeup lever moves up and down. Take a brush and clean any lint/dust out of that area or it be serviced and cleaned by an authorized Husqvarna Viking Dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Feb 08, 2010 | Sewing Machines
Sewing Machines Logo
161 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
