Question about Whirlpool GGQ8831L Gas Dryer
Dryer isn't heating up - Whirlpool GGQ8831L Gas Dryer
  • 4 Answers
May need to check gas pressure to unit...
Posted on Aug 05, 2010
My Whirlpool duet dryer isn't drying on automatic or timed settings. I replaced the ther-o-mister, but the dryer isn't heating up. How do you run a diagnostic on this dryer. Model GEW9250PWO
You should know that dryer has a thermal fuse located along exhaust Of heat... When You over load the machine the flow of air is not enough... Then thermal fuse is damaged ( open due security condition ) and the flame is turn off all the time... Just replace the thermal fuse. I hope this can help You. Sincerely
Jul 10, 2013 | Dryers
Would a faulty switch interlock stop a dryer from heating?
no. It would stop it from spinning. Now if the dryer isn't spinning then obviously it wouldn't be heating, but if its spinning with no heat the interlock switch is not your problem.
Nov 15, 2012 | GE Dishwasher & Dryer Interlock Switch -...
Does Not Shut Off
1st go the the house breaker (dbl breaker) for the dryer and shut it off and turn it back on, your dryer runs on 220 volts of power but if the breaker is partially tripped it may be only running on 110 volts which is only enough power to turn the lights on and to turn the drum the element needs 220 volts to turn on. If it still doesn't heat after resetting the breaker then you may need a heating element or thermostat. The dryer isn't shutting off because it isn't detecting the clothes are getting dry so once you fix your heating problem the dryer should start shutting off on its own again.
Apr 21, 2012 | Roper Dryers
Dryer runs but does not dry clothes
Dryers run on two circuits. One runs the motor and the other runs the heat. Check to make sure the fuse isn't blown or the breaker isn't tripped. Usually there is a fuse box behind the dryer with two fuses. One is for motor, one is for heater.
Jul 24, 2011 | Dryers
Does not heat and the timer does not shut the dryer off
Most dryers have two circuits. It sounds like one of these has a blown fuse. Check the breaker/fuse box and make sure the breaker isn't tripped or the fuse isn't blown.
The dryer isn't drying. The dryer is a kitchen aid the model is kgye777bwh2. Also this is a gas model. I noticed that the pilot isn't lighting when I turn on the dryer. With the dryer running i...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;
Jul 22, 2011 | Dryers
I have an he3 dryer that isn't heating. is there a reset button on the dryer?
heatman101;
Jul 22, 2011 | Kenmore Dryers
Dryer everything works, but no heat.
You didn't mention whether it was a gas or electric dryer, but either way it probably just isn't producing heat. If it's electric, it's most likely a defective heating element. If it's gas, the burner probably isn't igniting. On both there is usually some sort of thermal shut off switch that can also go bad and shut off the heat element or the burner.
Jul 15, 2011 | Dryers
The drying light is flashing and the dryer isn't heating up
heatman101[]\==-
Jun 26, 2011 | LG DLE2514 Electric Dryer
Cabrio Electric Dryer isn't heating up
heatman101
May 29, 2011 | Whirlpool WED6200S Electric Dryer
Whirlpool GGQ8831L Gas Dryer Logo
50 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
