Question about DISH Network IR Remote Control
MY DISH REMOTE WILL ONLY WORK THE ON/OFF AND THE VOLUME . IT WILL NOT CHANGE CHANNELS
  • 1,229 Answers
Check with Matelectronics.com for a relacement!
Posted on Aug 03, 2010
4 Suggested Answers
  • 336 Answers
SOURCE: dish network remote stopped working for on and off and volume
First before trying to repair the remote lets try to just reprogram it. The easiest way to do this is to do a search. 1st Turn the tv on, then on the remote press and hold the tv button until it flashes. Next press the tv power button. Next press the up arrow button slowly until the tv turns off. Then hit the # key. Now if you pressed the up arrow to many times and the tv doesn't respond to the remote just start the process over, except using the up arrow use the down. You may have to push the up arrow button many times before it finds the code. The batteries usually last quite a while since there are 4 of them. If this doesn't work call 1-800-333-dish they will either send out a tech or just mail you a new one. If you have the user guide for the 722 the instructions to do this are on page 82.
Posted on Sep 16, 2009
SOURCE: dish remote wont change channels
make shure it is turned on the sat setting
Posted on Oct 06, 2009
  • 8457 Answers
SOURCE: both remote controls for tv1
Tries Dish network box unplug,replug the box back like an hour later.By letting the box itself rebooting and upgrading it softwares,should solved this problems.If not than the box have problems.Trade in for a new box.
Posted on Dec 06, 2010
Volume is the only function that works on my Dish remote. I can't change channels on my dish remote.
look at the top of the remote. There may be a button to tell the remote to control the Dish box. Those remotes can switch modes if you bump a button.
Jan 05, 2018 | Televison & Video
Reset set t.v. to channel 60 for DISH system without a remote for RCA tv
Use the TV's original remote to put it back on channel 60. The
Jun 21, 2017 | RCA Televison & Video
VIZIO E470VA LCD HDTV Dish Hopper remote doesn't change volume
Try another remote code, many of the Dish or Cable TV remotes will have multiple codes for a particular brand of TV's
Sep 01, 2012 | Vizio E470VA 47 in. HD-Ready LCD TV
My remote will turn up the volume but has stopped changing channels.What can i do?
if its the original remote first unplug the TV to reset it, then try running the auto program to lockin the channels, then it should work. also make sure the remote is in TV mode. If its a cablebox/dish remote call the cable/dish company.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Apr 19, 2011 | Televison & Video
4.0 dish remote will not change channel or even turn satelite on or off? still controls the tv just fine, volume works etc....
Hey there! This is Becki Barned with dish Network customer service. The remote just needs to be reprogrammed! Take that remote to the front of the receiver, and then follow these simple steps! http://www.dishnetwork.com/SupportSection/remote-control Hope this helps!!!!
Dec 16, 2010 | DISH Network IR Remote Control
My new remote that came with the tv does not allow me to change channels, but my dish remote still allows me to change channels
Your dish remote is the only one that is compatible with the dish receiver. You're going to have to program all the functions you want to use to the dish remote. They are usually set up for all the normal functions, volume, power, dvr etc.
Dec 08, 2010 | Element Electronics PLX4202B 42 in. Plasma...
My remote control only works for tv on & off and volume but not to change dish channel
I experienced this problem as well. I have a dual receiver and had issues turning channels on TV2; but counld easily access the volume. After reading the Dish manual, I learned that my TV1 and TV2 remotes connect through different signals (IR = infrared for TV1; and UHF= ultra-high frequency for TV2).
Check your remote to see if there is a UHF logo at the very bottom (under the Dish Network logo). The UHF remote sends ultra-high frequency radio signals to a UHF antenna which is connected to the back panel of the receiver. Make sure that you receiver is properly dusted and then check to make certain that the UHF antenna located on the back of the receiver is positioned straight-up. When the antenna is not correctly positioned it can cause problems with your remote signals.
Oct 06, 2010 | DISH Network IR Remote Control
Cannot access channel 73 on TV2
If you are unable to access the TV menu using the buttons on the TV itself it is possible you can with the TV2 remote if it still controls the volume etc. for this TV. If it doe not you will need to find a code for your set in the manual for the receiver or you can go to the following link to find that info as well.http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/receiver/625.shtml
Assuming you have control of the volume still press the small TV button on the top left of the remote. Now press the menu button and you may be able to access the TV's menu. If so you need to run a channel scan/auto program the TV. You may need to use the buttons on the TV still to maneuver through the menu.
If you are still unable to access the menu you may need to purchase a universal to access the menu.
Jan 11, 2010 | DISH Network DVR-625 DTV Receiver /...
No antenna tv signal
Your dish remote should be set to the code for your TV. Then you will be able to control the channel number, not just up/down, as well as volume and maybe even the input. But do try to get a real remote for your TV so you can get to its menus.
Meanwhile, use menu+menu to see the channel being output by the Dish receiver. (Must be a 622/722... based on the 60 you listed.) Try to find an unused UHF channel number that your set does have in its up/down list. Match Air/Cable setting of Dish and TV. The Dish output is analog (NTSC) although the tuner(s) only accept digital (ATSC).
-Ken
Jul 26, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Remote
The Dish remote control may or may not manage all functions of your Hitachi TV. This is a common problem with Dish and Comcast remote controls.
Oct 11, 2017 | Hitachi 31KX41K * 31" TV
DISH Network IR Remote Control Logo
514 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
