Question about Bosch & Tankless LP Hot Water Heater
Bosch 240fx, power surge destroyed mother board. Replaced MB and now fires, shuts down, fires, shuts down, fires and shuts down and top light flashes. Cleaned the flame sensor still doing the same thing. Cleaned flow sensor, works as it should. What the heck is wrong with this thing?
  • 322 Answers
Check fan sensor
Posted on Aug 03, 2010
Bosch 13Hwater heater problems
Question is how am I to know what model this is? And as stated the question answers itself.....Plumber removed...did he reinstall? of course but as stated the issue is unanswerable.
Does the Pilot light? or if this is an electronic unit than something in the feedback ignition sensor is amuck. Is this a 125VP, 125B, 125H. 38B or a 240FX, 250SX or 2400/2700 or newer?
Jun 16, 2014 | Bosch & Tankless LP Hot Water Heater
Error code 12
I'm assuming this is a 240FX. Sounds like a control board issue. Since this was such a rare machine, the board cost 3/4 the cost of a new unit, and was not something recommended to replace.
Nov 02, 2013 | Bosch & Tankless LP Hot Water Heater
My Bosh (240fx) runs hot and cold constantly while you are in the shower. You can hear it turning off and on. I have done everything the bosh techs have told me to do. Now I get a tech ( Shaun ) with an...
It sounds like a bad flo switch. If not, then the problem is more likely in the mother board. Call Bosch back and ask for a supervisor right away. The peons sometimes are given advancement according to how many calls they handle, so they have a time crunch. Go right to the supervisor. Good luck!
Jan 27, 2018 | Bosch & Tankless LP Hot Water Heater
Our Rheem Tankless hot water heater worked for about 21 days and then blew a fuse and we can't get it to work now. We have replaced the mother board and the fan but it still doesn't work. The error shows...
These are very finicky units. However, it comes down to power from the breaker, internal fuse, and sensors. If the fan was damaged by a power surge or from being improperly grounded, you can be chasing your problem for a while. I highly recommend replacing it with a Bosch as they are fully serviceable and the new units have a very clear error code file. It brings you right to the source. Check boschhotwater.com for a service provider to install it for you.
Mar 27, 2010 | Rheem Tankless Hot Water Heater...
BOSH 240FX WATER HEATER WITH 11 FUALT CODE
CHECK AND MAKE SURE THE GAS SHUT OFF VALVE IS OPEN COMPLETELY.
Dec 01, 2009 | Bosch & Tankless LP Hot Water Heater
Electronic fire. fires up , Shuts down after 5 sec.
it sounds more like you have the ignitor wire shorting out on metal and won't allow it to stop trying to light the burner, hold the wire away from any metal and see if it helps, if this isn't the caee your circuit board needs to be replaced,
Jun 22, 2009 | RTO Atwood Water Heater - 6 Gal LP
Electric Bosch tankless water heater wont heat water.
Here is the run down>
Water too cold Neon light on:
Cause:
1). Water flow is too high-adjusting the water flow as follow; open fully both inlet and outlet shut-off valves at the heater, then turn on fully the highest flowing hot water faucet closest to the outlet connection. Adjust the outlet shut-off valve until the water flow from the hot faucet corresponds to the approximately 3.6gal/min at 105 degree.
2). One of the power supplies is not on-check the breaker box, there should be three ganged breaker, each corresponds to each of the heater power supply.
3). The power supply voltage has dropped-reset the breaker in the breaker box.
4). Temperature dial is turned too low- temperature adjustment is made using the dial on the bottom edge of the unit. The adjustment is between approximately 95 and 135 degree F. Turning the dial clockwise increase the temperature settings.
5). The inlet water temperature has dropped-readjust the temperature dial.
Attached link is for Bosch hotwater heater installation. This should give you idea as to what to look for.
http://www.boschhotwater.com/Portals/7/TechManuals/AE115_AE125_English.pdf
The following link is Basch Hotwater troubleshooting Q&A, this should also give you some help.
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/PowerStarModels/AE115AE125/Troubleshoot/tabid/632/Default.aspx
Please post back on this thread, If you still having problem.
Jan 27, 2009 | Bosch PowerStar AE125 AE125 Whole House...
Bosch gwh-425ef nat gas on demand heater
sound like pcb board is failing - control board
Nov 09, 2008 | Bosch & Power Vent Water Heater
Bosch & Tankless LP Hot Water Heater  Logo
159 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
