Question about John Deere Garden
I'm attempting to replace the primary belt on a John Deere x500 w/ 54'' deck. Is there a pully adjustment or do I just ''force'' the belt onto the pulleys?
    Novelist:
  • 146 Answers
There is an idler pulley that puts tension on the belt. You unhook the spring from the idler arm, put the new belt on (it will be loose, not tight) then hook the spring back onto the idler by pulling hard on the spring with a pair of visegrip or channellock pliers. Here's a parts diagram. Good luck! Please rate my solution if helpful, thanks.
Posted on Aug 03, 2010
John Deere GX345 54C deck belt adjustment
Greetings, I read your question and I think Reliable-Store can help you in this. Here's the site link.
Best Manuals
May 22, 2017 | John Deere Garden
I have a John Deere 216 the belt keeps coming off. I've replaced all the pullies, it stays on longer but still comes off. It's the primary belt
The tension Pulley Need to Be very tight, Loosen the Adjuster Bolt and slide Pulley as far over as possible, then tighten bolt, If you still have a Problem then You either have a stretched out Belt or the wrong one
Jun 06, 2015 | John Deere Garden
How to adjust tension on belt of John Deere Ride On D140
How to adjusted Cutting Deck Belt Tension
You do not say which size cutting deck you have. I will be writing about the 48", 3 blade cutting deck
The belt on this deck is self tensioned. The tension is provided by a spring attached to a moveable pulley on the deck. When the belt is in place you can manually force this pulley forward/backward and it will release the tension.
If the belt is off track, place the belt back around all the pulleys in the correct path, lastly force this spring loaded pulley forward/backward (depending on your deck, the direction is not important, the tension is) to get the belt around the pulley. If the belt is placed correctly, when you release the spring loaded pulley it will properly tension the belt.
Typically, these belts should not be jumping off. If yours is coming off frequently the belt may be worn. When they wear they get quite a bit longer, then the tension pulley cannot apply the correct tension. Rarely does the tension spring have to be replaced.
The other problem that causes belt jumping is worn spindles and stationary pulleys. The spindles are the most likely to need replacement. You can buy excellent replacements for JD spindles on Amazon for very reasonable prices. The following spindles are super replacement spindles for the 48" deck. They may very well be the same for smaller and larger decks; I have not researched that. Just search Amazon for Silver Streak # 285851.
Silver Streak # 285851 Spindle Assembly for JOHN DEERE GY21098, JOHN DEERE GY20962,
Product description:
Spindle Assembly / John Deere GY21098 Pack Size:1 JOHN DEERE GY21098, JOHN DEERE GY20962, JOHN DEERE GY20867, JOHN DEERE GY20454 OREGON 82-359, ROTARY 12910, ROTARY 11964 JOHN DEERE D100, D110, D130, D140,D150,D160, LA100, LA105, LA110, LA115, LA120, LA125, LA130,LA135, LA140, LA145, LA155, LA165, X110, X120, X140 Includes grease Zerk, pulley lock nut, blade lock nut, and washer , Height: 7 ", OD: 5 "
You can also find replacements for the flat pulleys on Amazon. If you cannot find what you need there, go to http://www.greenpartstore.com//
Mar 08, 2015 | John Deere D140 48 in. 22 HP Front-Engine...
Why does my mower deck belt on john deere 316 keeps breaking
There are a few causes for this and its not just this brand or model. First check that belt is installed correctly, check the part that keeps the belt on the belt rollers the belt should be between the garde and belt wheel, check for shine spots where belt is rubbing, Some times the mower deck is not set even or too low it can put the belt at too much of an angel causing the top of roller to cut it. So check the deck level there are adjustment devices on the mower to adjust, check for shine spots and for correct belt installment, and check roller wheel top for cuts or sharp spots, and check belt tension to see if it is to tight or too lose, also check that rollers spin free and there is not one stuck that could be heating the belt up too much, And last but not least make sure you are using the proper belt that is made for a mower fan belts don't last very long on a mower.
Jun 02, 2014 | John Deere 420,1020,2010,2020,2510,2520...
John deere l118 belt adjustment
There are two things to check first. First is that you have the right belt on there and it is not worn. Second would be that all the springs are on the proper tensioning pulleys under the deck. After that then you need to look for an adjustable pulley that is manually tightened and held in place by a bolt. That will be your idler. You will also want to check the track of the belt to make sure nothing is bent.
May 15, 2012 | John Deere Garden
Need to know how to adjust deck belt on a 54
I would need the model # of the deck and tractor, but all newer mowers use a spring to maintain constant belt tension. I can get you a diagram if you need one.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Dec 03, 2011 | John Deere Garden
John Deere 185 deck height adjustment
having a problem with dive belt being hit by the mower deck 185 john deere suggestions !!
May 08, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Noise, idler pully rubbing against middle blade
Unless there is some other means of placing tension on the deck belt, I would say that the idler pulley does. If the idler pulley is on a pivot arm, there is a spring that typically is attached to the pivot arm, near the pulley, that attaches to a post or some other part of the deck, that creates the tension on the belt. Check the belt for proper tension.
Aug 01, 2009 | John Deere Garden
Garden Logo
867 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
