Question about Psi Blue Max 2200 High Pressure Gas Power Washer
Need to know the weight of the oil that goes in pump and how much should i put in. not the enegine oil. model number 2200h
    Brigadier General:
  • 3,301 Answers
SAE 30 and uses about a 1/3 of a quart
Posted on Aug 03, 2010
What kind of oil replaced the Harley Davidson type "c" oil fork ina SS Sprint 350cc?
Fork oil is the same as hydraulic pump oil. Depending on your preference choose a light weight oil, 5-15 will give a soft ride. As the weight numbers go up the comfort level goes down. However, the heavier weight oil provides better handling. A bit of experimentation will varying weights should be considered for the optimal combination of ride comfort and handling. One final note. Always. Purchase a non-detergent oil
Nov 21, 2015 | Harley Davidson Fork Oil
What kind of pump oil for simpson gcv190
I need to know the model of the pump you have. You are giving us the model of the engine which is a Honda GCV190. Can you tell me the model on the pump itself. It is more than likely an AR pump but I need to know . It is more than likely going to take 30 weight non detergent but some pumps take specific oil. You can also call Barens at Pressure washer parts catalog quick links Pressure Washers High Pressure... They can hook you up with the correct oil for your pump. Good luckOADXAV
Feb 21, 2015 | Simpson Garden
I want to know what kind of oil to put in the machine itself, i checked the dipstick and it is needing oil
Without knowing what brand or model pressure washer you have, as a general rule:
If you're talking about the gas motor, it usually takes 10W-30, 5W-30 or 10W-40 motor oil, depending on the temperature range in your area. 10W-30 is a good all around oil to use.
If you're talking about the water pump, if it's an oil bath pump, use a straight 30 weight, non-detergent motor oil.
Jun 16, 2011 | Garden
Need manual for Remington Limb & Trim 8, Model #AQ53938. No problems, just lost the manual. Need to know oil weight, etc. Thanks.
I tried the numbers you provided and none crossed.
I went here:
Remington.com
http://www.desaparts.com/index.htm
  • Type "YourModelNo" into the "Model #:" window, then click search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Breakdown" link.
The most complete owners manual is "M15012US (and several others)" viewed as explainewd above. Page 9 discusses oil weights. Standard bar oil is 30 weight non detergent with addatives to help it adhere to the bar. That would be my recommendation. HTH
Lou
Jan 15, 2010 | Remington Garden
Type of oil for pressure washer pump.
any anti foaming oil ,you can use multi grade but it goes milky with minute air bubbles and gives the appearance of getting water in.most manufacturers recommend anti-foaming oil
Sep 04, 2009 | Campbell Hausfeld PW2102 Gas Pressure...
Need to put oil in the rear of car thats 90 weight need to no where it goes
Take it to an oil change place and tell them to check the differential oil. It won't cost much and trust me, it's hard to do at home without a lift.
May 29, 2009 | 1992 Ford Tempo
JUST DON"T KNOW
I have one also all it required is 2stroke engine oil
May 11, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
What weight oil does a 96 jeep cherokee use
The weight of engine oil is dependant on the climate you are in. When you go to the parts store or where ever you get your oil, read the back of the oil container and it will tell you the temperature variations for that grade of oil. For colder climates you will need a thinner oil or lighter weight, and for hotter climates you will need a thicker oil or heavier weight. The higher the number ie... 30, 40, 50, the thicker the oil, the lower the number the thinner it is.
Some manufacturers put the grade on the fill cap or the dipstick.
Apr 23, 2009 | Jeep Cherokee Cars & Trucks
Calibration is off
My Weight Watchers digital scales model#ww39 has gone haywire. I put new batteries in it to no avail. You tap it and the numbers come right up then changes to 000.0 as it should, when you step on the scales the numbers flash as they should but either they weight you about 100lbs to heavy or the numbers continue to blink and the LCD goes blank. Can they be fixed? Can I fix them myself at home? Do I need to shoot them? Just throw them out in the yard? Please I need help!!
Oct 01, 2008 | Taylor Dgtl Body Fat Scale
Psi Blue Max 2200 High Pressure Gas Power Washer Logo
87 people viewed this question
Top Psi Garden Experts
John Trevino
fordexpert
Jay Finke
Jay Finke
Are you a Psi Garden Expert? Answer questions, earn points and help others
