Question about Garden
How do i open the part of the weedeater that holds the twine?
    Brigadier General:
  • 3,301 Answers
The brand would have been helpful in this case, but normally you can hold the end piece and give it a twist ,, or in the middle of the unit it will have a screw on older models
Posted on Aug 03, 2010
Twine running over end of bale
The twine arm has to be adjusted If this can't be done maybe the twine arm is bent and needs to be re-shaped so it does not go off the end. But first check the adjustment. It should be in your operators manual
May 20, 2015 | Garden
2000 toyota celica gt leaks
check door seals yet, got moon roof.
only happen in rain, (big clue that)
Feb 09, 2014 | Toyota Celica Cars & Trucks
Welger ap 53 baler
My guess is that there is some kind of bind that the twine is in between the spool of twine and the knotter... resulting in the twine being continuously too tight for proper tying. Check for restrictions and then make double sure you've cleaned out ALL of the bunched up twine and twine ends... Are you using the correct twine??
Oct 30, 2013 | Garden
I seen to be having trouble sourcing baling twine for our b46 inter baler that isn't synthetic, is the old sisal twine still available anywhere?
Go on the web and type in sisal rope and twine in the google and see what you get. You should get manufactures of sisal /hemp rope and twine.
Oct 06, 2013 | Cars & Trucks
Weedeater head wont turn
Usually this means something is jammed under the head. Remove the spool (open the thing and it comes out). Then you have to take a clip or screws loos the get the bottom part out. Or sometimes the guard on top can come off. Either way, you are trying to get the twine or ivy or whatever has jammed it out.
Post model numbers for more help. Mention if it is locked up, or you feel a stuck gear, but head is free in a small range, or if the thing feels like the "brakes" are on, and its just really hard to turn. That last one usually means something is wrapped under the head.
Jun 05, 2013 | Ryobi Garden
String tensioner and knotter on new holland baler 319
I would say first check the twine tensioners where the twine comes out of the box it's held in. They are simple spring loaded slip tensioners, make sure both have the same tension. From there check all the twine passages for rust or servos
Jul 09, 2012 | Garden
Trimmer head on weedeater featherlite sst will not turn when engine is running
replacing twine on head so it can be tapped and cut when still going.
Mar 31, 2010 | Garden
My chicken is not turning in the rotisserie and i don't have a manual
DO not use a chicken larger than 5 lbs. Tie cooking twine around the chicken to hold it together so it doesn't touch the sides. I use two or three pieces of twine - wrap it around and tie - cut off the ends of the twine close to the knot.
Nov 19, 2009 | George Foreman GR82
I have a ryobi weed eater and the twine locks up and wont release
There is really no solution to this problem -- it is inherent in weed **** -- I have extensive experience with this phenomenon, spending many hours trying dozens of approaches. If you need a **** my suggestion would be buy a new one -- it'll get you through a season or two...
Apr 19, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
