Question about 1995-1997 Chevy 3500 Truck Ignition Starter Alarm Switch
2000 s-10 extreme abs code 0265 and brake comes on and goes off
Brake light and abs comes on and goes off intermitting problem. sometimes it stays on while you are driving and sometimes you can turn the motor off and restaret it and the problem goes away. the code says ebcm motor relay circuit i checke the 29 amp fuse and it was good. i am not sure if its the motor under the kelsey hays box to the right of the fuse box. sometimes the abs light and brake light will come on or go off by depressing the brake pedal. thanks for any help
  • 58 Answers
Before going into complex or expensive repair or troubleshooting, check the wiring connectors for the ABS sensors. The connector is usually on or near the wheel backing plate. These this can loosen, corrode, and just plain get crudded up. Disconnect the wire and clean to connection. If that works - good on ya; if not I'd look to the relay as the issue. It has internal contacts that can corrode from arcing during use. They can't generally be repaired and relay replacement is advised.
Posted on Jun 08, 2017
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
91 Buick park avenue abs light. This happened after my friend was driving down the freeway and his tire blew. Now it just blew the rubber off and he was able to drive t off the freeway on the belts. And...
ABS LIGHT AND MODULE TROUBLESHOOTING:
Anti lock brake system light comes up when there is issue with car brake systems. It can be low brake fluid or faulty ABS fuse or its issue with brake system or assembly. Your vehicles brake system needs inspection.
To troubleshoot these issues, I suggest you to refer the help links provided below. There are direct links with accurate solution, for these specific issues.
Click the link below and follow the procedure: ------
All types of ABS LIGHT / brake problems and repairs
http://howtobyme.blogspot.com/2011/11/abs-and-service-light-comes-on.html
ABS light stays on but brakes work fine?
http://howtobyme.blogspot.com/2011/11/abs-light-stays-on-but-brakes-work-fine.html
VCS and ABS lights go on and off intermittently on Lexus?
http://howtobyme.blogspot.com/2011/11/vcs-and-abs-lights-go-on-and-off.html
The ABS and Traction Control Lights stays ON dash of car?
http://schematicsdiagram.blogspot.com/2011/06/abs-and-traction-control-lights-stays.html
ABS & Brake lights warning indicator steady on dash and speedometer not working for Dodge Ram?
http://howtobyme.blogspot.com/2011/11/abs-brake-lights-warning-indicator.html
Battery Light and ABS Light on Dash
http://whoisbyme.blogspot.in/2012/07/battery-light-and-abs-light-on-dash.html
Sometimes ABS light comes on while Driving?
http://howtobyme.blogspot.com/2011/12/sometimes-abs-light-comes-on-while.html
How Anti-Lock Brakes Work?
http://technoanswers.blogspot.com/2011/11/how-anti-lock-brakes-work.html
Brake System Troubleshooting?
http://technoanswers.blogspot.com/2011/11/brake-system-troubleshooting.html
Anti-lock brake light stays on all the time?
http://technoanswers.blogspot.com/2012/01/anti-lock-brake-light-stays-on-all-time.html
ABS light comes on and Car makes Grinding noise?
http://repairhelpcenter.blogspot.com/2012/01/abs-light-comes-on-and-car-makes.html
ABS trouble codes for all models?
http://repairhelpcenter.blogspot.com/2011/11/abs-trouble-codes-for-all-1994-00-acura.html
2008 Toyota Highlander: ABS warning light Blinking and OBD Error codes Coming?
http://technoanswers.blogspot.in/2012/05/2008-toyota-highlander-abs-warning.html
2003 Lexus ES: VSC, TRAC OFF, ABS lights ON?
http://technoanswers.blogspot.in/2012/04/2003-lexus-es-vsc-trac-off-abs-lights.html
2008 Toyota Highlander Hybrid: Warning Lights Abs, Vsc & Brake Are On?
http://technoanswers.blogspot.in/2012/04/2008-toyota-highlander-hybrid-warning.html
ABS & Brake warning lights remains steady on dash?
http://schematicsdiagram.blogspot.com/2011/12/abs-brake-warning-lights-remains-steady.html
Can I drive the car without ABS fuse connected?
http://schematicsdiagram.blogspot.in/2012/02/can-i-drive-car-without-abs-fuse.html
Where is ABS/TCS module located on 2005 Cadillac Deville
http://schematicsdiagram.blogspot.com/2011/12/where-is-abstcs-module-located-on-2005.html
ABS motor keeps running?
http://schematicsdiagram.blogspot.com/2012/01/abs-motor-keeps-running.html
When the car stops, abs pump turns ON?
http://howtobyme.blogspot.com/2011/12/when-car-stopsabs-pump-turns-on.html
Replacing ABS unit on Buick Century?
http://technoanswers.blogspot.in/2012/02/replacing-abs-unit-on-buick-century.html
2008 Toyota Tacoma: ABS causes Brake pedal fade?
http://technoanswers.blogspot.in/2012/04/2008-toyota-tacoma-abs-causes-brake.html
Toyota Camry: Premature ABS Actuation?
http://technoanswers.blogspot.in/2012/04/toyota-camry-premature-abs-actuation.html
How to replace ABS Modulator Control Unit on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-replace-abs-modulator-control.html
How to replace ABS Pump Assembly on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-replace-abs-pump-assembly-on.html
How to remove ABS Accumulator on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-abs-accumulator-on-acura.html
How to remove ABS Control Unit on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-abs-control-unit-on-acura.html
These details will help.
Thanks.
Feb 04, 2013 | Cars & Trucks
I have a audi 2002 A6-c5 2.4 v6, the car has an intermitent problem with the ESP, Sometimes the light flashes & sometimes the light stays on, when this happens for a split second I hear a actuating...
And the codes were...?
The ESP gets input from a few sensors - ABS wheel sensors, yaw sensors, MAF...
If the 2.4 has electronic throttle (it should), then there shouldn't be any form of actuation in the footwell, so can't help you with that one.
Sep 29, 2017 | 1999 Audi A6
Brake fluid is full, no leaks, parking brake is not engaged but light stays on
There may be a switch on the equalizer valve. This is the valve that equalizes pressure to the 4 wheels.
The valve may be sticking or the switch may be faulty.
If the ABS is the problem, there should be a code stored in the body computer.
Jul 03, 2012 | 1991 Dodge D150
My 2001 gmc safari brake and abs light comes on . when I stop and restart the engine sometimes it doesn't come back on for a period of time
There's an intermitant fault in the ABS system, you will need a scanner to read the codes from the system.
May 01, 2011 | 2001 GMC Safari
I HAVE A CHEVROLET 2001 TAHOE AND HAVE NOT HAD ANY PROBLEMS WITH THE ABS IN THE LAST FIVE YEARS OF OWNING THIS VEHICLE. HAD A ABS MODULE PROBLEM SO HAD IT REBUILD. AFTER REBUILD I STARTED HAVING...
There is a ground wire connected to the engine block. Look for it on the back passenger side of the engine towards the top. Remove it and clean the connection and the wire connector and replace. Sometimes they get real bad and throw the ABS light on. Sometimes a brake light out can throw the ABS light on.
  • You said you rebuilt the ABS module, do you have a short in it you are missing? The bulletin for this originally suggested to replace the module and was corrected because the ground itself was the major offender.
  • Try to reground the EBCM. The code 0265 says "loss of communication with the brake module" The EBCM Ground is located on the frame beneath the driver's side door. If multiple grounds are found in this location, the EBCM ground can be identified as the heavy (12-gauge) wire. Clean the area, front and back, using a Whiz Wheel.
  • Install the ground, then the washer and then the bolt to the frame. Important: It is important to use the bolts, washers and nuts specified in this bulletin. These parts have been identified due to their conductive finish.
  • Install a washer and nut to the back side of the frame.
  • Tighten the nut to 9 N·m (79 lb in).
  • Cover the front and back side of the repair area using Rubberized Undercoating. An additional check can be made to ensure a good connection for the Battery Cable to Frame ground.
Regards, Tony
Apr 18, 2011 | 2001 Chevrolet Tahoe
My abs ight comes on and sometimes while driving the car. When the abs and the vsa light go off and I drive when I come to a stop and brake their is a rought scrapping noise coming from the brakes. The...
HI, It sounds like you have an intermitent ABS fault and wile you are driveing the light go's off and when you hit your brake's you hear and feel a rough scraping niose.If so it's from when the ABS resets. Chances are a wheel bearing is causing the intermitent code.If i'm misunderstanding what you are saying please comment back for clarification.Hope this helps you,if so please rate it. Thank You for useing fixya........ iluv2fish......Ray.....
Jun 12, 2010 | 2001 Acura 3.2CL
RrAntilock and Brake light
It sounds like your ABS sensor in the rear axle is on it's way out, reading sometimes, and not other times. The sensor is located near the rear differential, and has wires and a plug going to it. If you replace it, it should solve the problem, or just be ok with the light.
Hope this helps
Dec 16, 2008 | 1992 Isuzu Trooper
1995-1997 Chevy 3500 Truck Ignition Starter Alarm Switch Logo
158 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
