Question about Sport & Outdoor - Others
Working on a 95 yamaha wave a raider 700 jet ski...does any body no the clearance between piston and cylinder wall on stock pistons
  • Sport & Outd... Master
  • 12,061 Answers
The factors that affect this are cylinder wall thickness, whether the block is filled, the overall compression height of the piston, piston material and thickness, and whether a marine engine is to see fresh-water cooling. Most small blocks get .004 piston to wall clearance and most big blocks get .005 due to the use of our 2618 high-strength alloy. For heavy blower and nitrous applications, it is recommends adding .001 to the standard clearance. Special note: Clearance numbers are obtained from measuring the largest diameter of the piston, typically at the bottom of the skirt. All measurements should be taken 90 degrees from the pin centerline.
.004 piston, +/- 0.0005 to wall clearance is the answer, to your question.
Posted on Aug 03, 2010
Rev limiter on 1996 Yamaha wave runner 700
Yes it is, but do you really want to be a mile offshore and have the engine give out?
New Yamaha Adjustable Rev Limiter CDI 62T 700 Waver Raider Super Jet...
Sep 21, 2015 | Yamaha Motorcycles
Why would i have 60 psi in all 3 cylinders. ran great then all at once it started to run bad
anything below 100psi on 2strokes is usless and needs new rings as long as no damage and in tolerance to pistons ! reed valves and crank seals have nothing to do with piston compression , they work on crankcase pressure !
Aug 06, 2014 | WSM 1996-1997 Yamaha Wave Venture 1100 Cc...
Jet ski troubleshooting
check for fuel to be getting through the filter..
Feb 02, 2014 | Yamaha Wave Raider 700 760 1100 Waveraider...
Jet ski smoking
what colour smoke , correct fuel ??
Jan 04, 2014 | Yamaha Wave Raider 700 760 1100 Waveraider...
Yamaha Wave Raider 1994 wont rev past 2900 rpms
check all cylinders sparking ,working by carefully removing plug caps one at a time to see if you can hear a change in sound and check compressions 100psi or more on all !!
Jun 09, 2013 | WSM 1994-1997 Yamaha Wave Raider 700 Cc...
Pw80 oil coming out the exhaust
Hi, Anonymous and the usual suspects are:
1. Engine oil over filled.
2. Piston rings worn past service specs.
3. Broken piston rings.
4. Piston pin retaining clip failure.
5. Cracked piston.
6. Broken piston ring lands.
7. Hole in the piston.
8. Valve/guide clearance worn past service specs.
9. Worn out valve seals.
10. Crushed or loose valve seal.
11. Gouges in cylinder walls.
12. Cracked cylinder or head.
13. Blown head gasket.
14. Crankcase breather blocked or hose pinched.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
HELP have oil coming out of my PW80 Exhaust
Excess oil out exhaust pipe
YAMAHA PW80 Owner Service Manual
OEM parts for Yamaha
YAMAHA PW80 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 20, 2012 | 2004 Yamaha PW 80
Piston clearance
usuaully rule of thumb .002"piston to cylinder wall clearence,anything more than .004"is about do for next size piston and bore.
Feb 16, 2011 | 2005 Yamaha DT 125 X
I have a 1987 Kawasaki js550 Jet Ski with low compression. it has 170 in the front piston and 50 in the back what could be done besides having a stuck piston ring?
You will have to pull the engine out and rebuild the top end. You will probably have to bore the cylinders. Purchase a piston kit that comes with gaskets and seals. Reseal the crankshaft with the new seals and your motor should be good for another 23 years.
Oct 22, 2010 | Encore Software Kawasaki Jet Ski...
SEIZED PISTON
excessive piston clearance.really needed bore job with oversized piston,not just honed and rings.measure piston to cylinder clearance,check spcifications and verify
Apr 05, 2009 | 2003 Yamaha YZ 125
Sport & Outdoor - Others Logo
22 people viewed this question
Top Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
