I have a Janitrol Heat Pump Thermostat HPT-18-60 and need assistance connecting my new Honeywell RTH7500D thermostat I have a Goodman Heat Pump System Indoor Unit Model#AWB24-05C REV D Outdoor Unit Model#CPLE18-1 Here is the wiring of the old thermostat Y-Yellow Wire G-Green Wire R-Red Wire O-Orange Wire W2-White Wire E-Blue Wire C-Black Wire Where should each of these be connected to the new thermostats terminals?
koolbreezes
  • 540 Answers
SOURCE: My goodman cple18-1c model central
Ths sounds like the outside unit or compressor is not kicking in, check for power to the unit at the breaker box, or at the bottom of the contacts!
Posted on Sep 13, 2008
SOURCE: Hunter 44100A programmable thermostat
Sorry Iasumed you had a heat pump t-stat. You will need to exchange to a heat pump t-stat
Posted on Sep 28, 2008
  • 56 Answers
SOURCE: Trane Weathertron XE1000 Thermostat Wiring
Check to see if you have the system switch accidently on em. heat. The way you have it wired is correct except for the having brown on e. disconnect brown wire and cut ofbare end just in case they have the wire hooked up for constant run on roof.
Posted on Feb 16, 2009
peyton32034
  • 410 Answers
SOURCE: thermostat wiring goodman model aruf032-ooa-1b
is this a heat pump or straight cool with heat strips?
Posted on Mar 16, 2009
  • 68 Answers
SOURCE: indoor an outdoor unit wiring diagram
have you tryed to look it up on the net.a lot of the time you can get that sort of info off the web
Posted on May 02, 2009
Goodman furnace a36-20 fan runs non stop
is green wire from thermostat or from outdoor. retrace and change as needed. If not Goodman has a tech support number you can call while looking at unit.
Jun 21, 2014 | Goodman Heating & Cooling
Tip
Honeywell RTH7500D Thermostat
This Honeywell thermostat is a good medium priced thermostat that will give you many bells and whistles at a very good price. The programming is very easy to do and of course the thermostat is very reliable also.
The installation of this thermostat is very easy and if you need help with the installation you can go here to see the complete installation guide.
http://customer.honeywell.com/techlit/pdf/PackedLit/69-2221ES.pdf
If you have lost your owners manual and need a copy of it you can go here
http://customer.honeywell.com/techlit/pdf/PackedLit/69-2222ES.pdf
With the help of these .pdf files you can get all the information that you need to install and troubleshoot your RTH7500D thermostat.
If you are replacing a thermostat make sure that you turn off power to your heating or air conditioning system BEFORE you start removing any wires. Failure to do so could cause you to burn out the 24v transformer of your system. Also make sure to mark all wires well before removal so that you know which wire went where and so that you can reinstall the old thermostat as it was if something goes wrong with the new installation.
For heat pump systems you WILL have to make some programming changes to the thermostat to get it to work with a heat pump system. Most all thermostats come programmed for conventional systems. This reprogramming is not difficult but is required for proper operation.
http://www.fixya.com/support/r3623083-thermostat_wiring_terminal_designations
http://www.fixya.com/support/r3892721-programmable_honeywell
http://www.fixya.com/support/r3894275-manual_honeywell_find_honeywell_manuals
on Jan 16, 2010 | Heating & Cooling
Replacing coleman evcon thermostat
The Honeywell model RTH7500D is nice, simple programming is why I love it. Home Depot has it for around $50 I think. Good luck!
Jan 09, 2014 | Heating & Cooling
Replacing a janitrol hpt 18-60 with a Filtrete 3m-22
What is the question that you have about this? What is the make and model of the hvac unit that it is running?
Apr 21, 2013 | Filtrete Thermostat. 7-Day Digital...
I install new RTH7500D thermostat Honeywell, when I set for Cool it blowes heat when I set for a Heat nothing works I wire per instruction have two stage system
It sounds like the t-stat is programmed for a heat pump or you have a heat pump and the t-stat is programmed for a regular furnace....
Check out the manuals in the tip and go into the installer setup to change the t-stat to the proper programming for your system..
http://www.fixya.com/support/r3902153-honeywell_rth7500d_thermostat
heatman101
Apr 24, 2010 | Honeywell Programmable Thermostat Heater
One honeywell to another
you need to program the thermostat for the reversing valve "O" it will tell you how to do this in the manual. you will need to chang from "O" to "B" or "B" to "O" depending on how its set.
Jun 24, 2009 | Honeywell Programmable Thermostat Heater
Feb 08, 2009 | Heating & Cooling
Changed out a Honeywell Thermostat with an Aprilaire Thermostat
The smell is usually dust on the wires for electric resistance heat.The thermostat shouldnt have anything to do with it.
Nov 19, 2008 | Heating & Cooling
Y1 W1 Wire from older Honeywell to new RTH honeywell
Y1 means for cool and W1 means for heat. Connect accordingly.
Aug 11, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
805 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
