Question about Dell Dimension E521 PC Desktop
When i cleaned my dell demension i put everything back exactly how it was now when i turn on my computer none of my external devices mouse pc screen keyboard is not turning on i need help
    Problem Solver:
  • 13 Answers
I would first check and verify that the electrical outlet or power strip that they are plugged into is working. If a plug gets in a bind it could have blown a fuse on the power strip or the power strip might have a reset switch on it. Or the power strip might have failed. If you have a uninteruptable powersupply that you plug everything into you will need to confirm that it is working as well, test it and look for reset buttons or a fuse holder on it. Your electrical cords could have been pulled out from the wall outlet itself while cleaning sometimes even wall outlets if put in a bind from pressure will blow a fuse or the cord might pull out just enough that it is not making a good connection.
You might get a lamp with a bulb that you know works and plug it into the same electrical receptical that you have the dell computers power cord plugged into and then test the monitor power source the same way.
If the outlets or power strip are getting power and that is confirmed by testing them, and then you plug in the Monitor and Dell power cords into the sources that you have confirmed are getting power, and they do not come on we have a different problem.
If the monitor is hooked up wrong to the computer or not even hooked to the computer the light should come on on the front of the monitor incicating that it is getting power. If you plug it into a confirmed working electrical outlet the light should come on on the power button of the monitor. If it does not come on then somehting might hve possibly damaged all of the epuipment that was plugged in like a power spike on the electrical lines going into your home, this would be very rare but not impossible.
I am sorry for all of the senerios but you were not really clear on what you were using as power sources going to the equipment and I wanted to try and cover the most common possibilities in one email. Please let me know if this helps
Posted on Aug 03, 2010
Why does my monitor start as white when I turn it on? THe mouse pad does not work as well.
Monitor cable disconnected internally?
follow http://www.insidemylaptop.com/replace-screen-on-dell-latitude-e5420-laptop/
and disconnect, clean and reconnect ALL monitor related cables. (You may need a new screen if that fails)
You may check your laptop by connecting an external monitor first.
Aug 21, 2014 | Dell LATITUDE Computers & Internet
KEYBOARD WILL NOT WORK ON DEMENSION 3000 UNABLE TO TYPE ANYTHING
Keyboard might be bad or you might have a virus that has hijacked the keyboard.
Make sure the keyboard is plugged into the computer good. Then reboot the computer into Safe Mode and see if the Keyboard works.
Turn off the computer, then hit the power button to turn itback on and immediately start hitting the F8 key repeatedly until you see SAFEMODE. Take the Safe Mode option and let it boot up. Safe Mode will lookdifferent to you, the screen will be darker and the icons bigger, this isnormal.
Apr 02, 2012 | Dell Dimension 3000 PC Desktop
Built in mouse has not worked properly from day 1. Now my external mouse won't work either. I tried a different external moue, but it doesn't work either.
Unplug everything except the power cord, including the following:
Speakers
Printers
Scanners
USB devices
Personal Digital Assistants (PDAs)
USB flash drive or other external storage devices
External Monitor
External Keyboard
External Mouse
If your computer is attached to a docking station, undock it.
Make sure the touchpad or your finger has no dirt, grease, liquids or food on it (the touchpad has to make a good contact with your finger to work correctly).
Turn the computer back on and retest the touchpad.
When the touchpad still does not work correctly proceed to step 5.
When the touchpad does work correctly, attach one external device at a time and test the touchpad to see which one may have caused the issue.
Make sure the latest driver for the touchpad is installed (you may need to use a external USB or Bluetooth mouse), for more information refer to:
"How to Use the Drivers and Downloads Website"
May 26, 2011 | Dell Inspiron 1525 Laptop
I put new batteries in correctly. My wireless Dell mouse still does not work. I have two (2) buttons on the back of it. One is a circle with a straight line on top and one is an "arrow circle." ...
Hello barbmike, these instructions will help you.
  • First, click on the "Start Button," in the [Start Search Window].
  • Type: mouse; the "Mouse Properties" window will open.
  • You can change the "Button Configurations" to exactly how you want the "Mouse" to respond.
  • Check the {Mouse} Status? {Enable}
  • Try "Updating the Drivers," by clicking on the "Properties" button.
Now in the event that neither of these solution solve the problem?
  • Try "Uninstalling the Mouse.
  • To "Uninstall the "Mouse."
  • Disconnect all the Mouse Devices "Safely," {USB...}, that are attached to the Computer.
  • Turn-off the Computer.
  • Next, turn-on the Computer, and go back to the "Mouse Properties."
  • This time click on the "Change Settings" button.
  • Next, click on the "Driver" button, and select the "Uninstall" button.
  • Once that is finished, [Shut-down] the Computer again!
  • Now, you want to "Reconnect" all the devices that were connected before.
  • "Turn-on" the Computer.
  • You will repeat exactly what you did from the start, this will "Reinstall the {Mouse}."
!Important "Restart the Computer again, after all changes have been made."
Go to this "Website," and "Fill-in" or {Choose} any information needed to get the "Drivers" you need. Than you'll be able to "Download the Drivers."
If this information helped? Return and give a "Helpful Rating," please!
Thanks, paul7of9
Click here: http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Feb 21, 2011 | Dell Computers & Internet
My dell dimension xps 400 does not detect mouseand keyboard
Hi, these instructions will help you, and "everything that you do for the Keyboard; apply the same instruction to the Mouse." First, click on the "Start" button, in the ["Start Search Window], Type: keyboard; the "Keyboard" Properties window will open. You can (Test) to see exactly how your keyboard is responding. If you are still having the same problem, (check, the Keyboard Status). "Update the Drivers," by clicking on the "Properties" button. Now in the event that neither of these solutions solve the problem, which I hope you shouldn't have to do anymore; "Uninstall the Keyboard. To "Uninstall the "Keyboard," do the following: Shut-down (turn- off completely); disconnect all the Keyboard Devices that are connected to the Computer. Next, turn-on the Computer, and go back to the "Keyboard Properties," next, click on the "Change Settings" button, next click on the "Driver" button, and select the "Uninstall" button. Once that is finished, shut-down the Computer again. Now you want to "Reconnect" all the devices that were connected before, and "Turn-on" the Computer. "You will repeat exactly what you did from the start, this will "Re-install the Keyboard. "Restart the Computer again after all changes have been made; this will ensure the changes take effect properly. "Rating the solution will let me know if it worked; or you may need further assistance, thanks."
Jun 20, 2010 | Dell Dimension XPS 400 PC Desktop
Wirless mouse and keyboard stop working after user sing in screen
u have a virus.. 2 solutions
  1. get a usb mouse and connect it when computer boots and then search for virus and remove it.
  2. if u dont want to do tht the other way out is reinstall the windows..
Aug 24, 2009 | Computers & Internet
Dead pc
try to remove all external device connected to your computer. just leave the keyboad, mouse and monitor connected.
restart computer.
if still a blank screen
remove everything connected to your computer (mouse kyeboard and monitor) restart if nothing happens
open your computer and remove all devices (hard drive, optical drives, memory... restart,,, you should be hearing beeping sounds indicating motherboard is looking for memory. try putting back 1 memory at a time and checking all mem slot. to identify if one of the memory could be causing the blank screen. if both memory will not work try to use known good working memory. if you dont get to hear the beeping sound using a known good working memory. your memory is the problem.
give me more info
Jun 19, 2008 | Dell XPS 200 PC Desktop
Front usb freeze computer
Update sp2 to sp3 link
Download everest home from this link, run the program, click on motherboard then chipset, ID the northbridge and check for updates (google it) This should update all usb controllers and hubs to eliminate the "freeze".
Mar 27, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension E521 PC Desktop Logo
70 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
