Question about SanDisk 2GB microSD Memory Card
I have a 2GB micro sd card for my blackberry when i put it in. It says media card has inserted contains errors. yo correctthe errors use a disk error-checking utility on a computer. what do i need to do?
  • 83 Answers
If this card working on yours phone then this problem related with window operating system if card have problem with phone then this is relsted with card , formatt this card with phone and restore it by system restore s/w.
Posted on Aug 03, 2010
After i insert my 1 gb sandisk micro sd card into my blackberry 8530, an error message comes up: "cannot access media card due to fatal errors" i have tried to install, repair, and format it...
It sounds like in your situation that you may have a bad card. If you cannot get your card to mount to your phone for storage, I would try to find access to a pc that has an SD card slot that you can try to format it that way. If the card still wont format, your looking at a defective card and will need to purchase a new one.
You can find Micro SD cards here for purchase.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&Depa=0&Order=BESTMATCH&Description=micro%20sd&IsRelated=1&cm_sp=KeywordRelated-_-micro_sd_card-_-micro%20sd
Sep 22, 2011 | SanDisk 2GB microSD Memory Card
I have an 8GB micro sd card for my blackberry storm when i put it in. It says media card has inserted contains errors. to correct the errors use a disk error-checking utility on a computer. what do i need...
The chances on any micro sd card showing errors can be either the files stored in it are corrupted or the card is simply bad already. You may try to identify the problem by performing the following steps.
1· Access micro sd card through a card reader. May it be built-in in a computer or an accessory that needs to be plugged-in to a computer.
2· Wait for a few seconds for the computer to read the micro sd card.
a· If it asked you to "open the folder to view files", do so then copy all contents in a new folder on your desktop. This is to make a backup copy of your files. Then, format the micro sd card with FAT32 format. Copy all files back to your micro sd card.
b· If it asked you to format the micro sd card, most likely all files are corrupted. Try to format the card for re-use. If not successful, your micro sd card is bad already and needs replacement.
I hope this works for you. Good Luck!
Mongkey
"Understanding explains better..."
Jan 30, 2011 | SanDisk 2GB microSD Memory Card
When i put my sandisk into my blackberry phone it keeps saying a media card has been inserted that contains errors. to correct the errors please use a disk error-checking utility on a computer . how do...
Put the SanDisk into your SideKick phone, and navigate through the menu-items to "format" the device, i.e., delete all pictures, and return to "factory-shipped" condition. Then, put it into your B.B., and repeat the "format" process, to be 100% "factory-setttings".
Aug 09, 2010 | SanDisk 2GB microSD Memory Card
I have a blackberry curve w/ a 2gb micro sd memory card.but i cant store or save anything to the memory card.how do i do it?
Check it first if your memory card is recognized by your unit, if not try it to insert in different phone just to check it if it is working or not.
if not then more likely it is corrupted
Nov 05, 2009 | RIM BlackBerry Curve 8310 Smartphone
Blackberry Disk no longer works. need disk error checking utiliy
your best bet is to format the media card. just insert it into a computer and then right click the drive that is assigned to it and format it. be forewarned that this will erase all of the data on your card!
Jul 11, 2009 | RIM BlackBerry Pearl 8100
LG KC550
kk to add music make sure you syn the phone and the cp do the data and all then put .mp3 on all the media files and see if it works. Then if that doesnt go to computor format the card and then put it in the phone. Otherwise you need new stuff.
Mar 13, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
Micro sd My card worked to save a video then shows an error now. I have a tmobile blackberry pearl smart phone. Please help me. It now says: “a media card has been inserted that containserrors. To...
if you have a USB cable that came with your hanset attach it to your pc or laptop, then wait for it to install the drivers ect.. if it come with a CD-ROM then insert it a dn install the blackberry software, then goto "My Computer, there should be a removable disk drive called MICROSD or something like that, right click on that icon then goto "properties" then click on the tab called "tools" then click on the button called "Check Now" under "Error-Checking"
this should fix your issue.
any problems please comment
Sep 27, 2008 | Cell Phones
4 GB micro sd and the Sandisk Sansa e250R...
If the 4gb micro SD is a high capacity SD (it will say micro SDHC on it) your player may not be able to read SDHC cards, my sansa can't because it's the 'older version' it will read 2gb and below micro SD cards though (it sucked when I found out because I had just bought a 6gb micro SDHC)
Nov 22, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk 2GB microSD Memory Card Logo
212 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Carlos Calvo
Level 1 Expert
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
