Question about GE DVL223EBWW Electric Dryer
Replaced heating element and it still wont fire up
I have a GE dvl223eb1ww electric dryer.Replaced heating element and it still wont fire up. Any suggestions as to what to check next. Thank you.
  • GE Master
  • 43,501 Answers
There can be many reasons why your dryerreplaced heating element and it still wont fire up - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryerreplaced heating element and it still wont fire up - 2_bing.gifng
Dryer Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Aug 03, 2010
General Electric DVL223EB1WW Electric dryer no longer heats up. Still blows air, cold, but no heat?? Any suggestion?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 15, 2011 | GE DVL223EBWW Electric Dryer
GE Dryer PBSR353ET5WW.. I believe this unit is manufactured in Canada.. unit works, but does not heat up..
Check and clear the lint filters, and reset the circuit breaker. If your dryer still does not heat up, it is likely that the SWITCH controlling the heating element, OR the HEATING ELEMENT ITSELF is faulty and needs to be replaced.
Jun 07, 2010 | GE Profile Harmony DPGT750EC Electric...
What do I do if my dryer runs, but does not heat?
Hello my name is Heath the problem is probably a bad heating element. If the dryer runs but does not heat then the heating element is bad and will need to be replaced.
Apr 07, 2010 | GE DDC4400S Electric Commercial Dryer
Just replaces heating element in GE dryer. Dried one load but does not work, now. Light works, so it has power. Suggestions?
I would check the thermal fuse or thermostat. If the thermal fuse is blown check for obstructions in your vent then replace. For a video on testing these components go to www.appliancehelponline.com/servicemanual.html scroll down to troubleshooting an electric dryer.
Mar 18, 2010 | Dryers
Ge dryer not drying but running a full cycle. sometimes turns off early
If it is electric then your heating coil is broken and needs to be replaced. If it is a gas dryer then it is most likely your electric igniter element that is cracked and prevents the unit from firing up.
Mar 14, 2010 | GE Dryers
Ok got a GE DVL223EB1WW Insufficent Heat
Yes think so , what should happen is element heats up controlled by fan blowing cold air across it this then heats to whatever thermostat is set to switch at, which in turn controls heat level..Air is then exausted via hose to waste unless its a condenser drier which then turns the steam back to water / which is collected in a waste condesate drum..hope this is helpful...
Nov 19, 2009 | GE DVL223EBWW Electric Dryer
GE Dryer
NO the heating element comes with the whole unit.
May 11, 2008 | GE DSXH43EAWW Electric Dryer
GE Electric Range
It is very common for elements to "catch fire" when they fail. It is really electical arching. But to answer your question you shouldnt be concerned if it ever happens to the bottom element immediatly kill the breaker it will stop instantly. dont use a fire extinguisher as it wont stop the arching. And most ovens do use the upper broil element for baking for very short intervals like 10secs on every minute or so to brown the top of product. Some models (especially older builder line ) do not
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE DVL223EBWW Electric Dryer Logo
135 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
