Question about Car Audio & Video
I need a print out of the speak wires colors - Car Audio & Video
    Brigadier General:
  • 3,301 Answers
I need to know what unit your installing and what your installing it in
Posted on Aug 03, 2010
I am getting a replace magenta cartridge message but have only printed about 300 pgs most of which were only b&w
The full replaement color cartridges for this printer only print 1,400 pages @ 5% coverage. If you are speaking of the starter cartridges (the ones that came with the printer) they only have about half of that. If you print with this machine in full color mode, which is the default, it counts developer revolutions even if you only print b&w. If this is a purchased toner cartridge you are speaking of, you can reset the flag gear on the side of the cartridge in order to get more prints out of it, put the print quality may not be good. To extend the life of the color cartridges when you are only printing b&w, set the printer properties to print in "graysale" or "monochrome" under preferences. When you try to print a document, in the dialog box next to the printer name click preferences. Look on all of the tabs for one of the selections I mentioned and select it. This is an expensive cost per page printer, and you may not want to use it for all of your prints. It may be adviseable to get a cheap monochrome only printer for your b&w needs and only use this brother machine for your full color prints.
Sep 30, 2010 | Brother HL3070CW Compact Digital Color...
Oki data c5200. When printing color there are streaks where it looks as though something is scraping the toner or page so to speak.
Could be 2 differents problems.
1st you can clean the leds.
2nd you can change the drum of the color problem,
Aug 18, 2010 | OKI C5200n Laser Printer
Can my printer work whit only one cartridge?. I'm sorry for my English I'm learning now, I speak Spanish, Thank you
normally yes a printer can work with only one cartirdge...and it also depends which cartridge color you have...if its black then you can only print in black and if its colour then you will be able to print in color
Jun 10, 2010 | HP PhotoSmart 7760 InkJet Printer
My HP printer will not print in color until I replace every color. We tried each color and it absolutely won't print. My husband has the exact printer and this does not happen to him. Once one color needs...
The way the print heads work if one goes low on ink it won't allow the rest to print the reason is if they run low on ink they tend to burn out the print heads and they cost $50.00 a piece.
Jan 19, 2010 | Office Equipment & Supplies
Do all cartridges need to have ink in for the printer to work? I have replaced the black ink but blue one is showing empty & it will not print black only
It should print "Black" only. You have to setup printer options, chaginf from colour tab too Blackl?
You naughty person, were's your replacements! Huh.
Nov 14, 2009 | Epson Stylus D92 InkJet Photo Printer
I just bought a used dual xd6210 stero deck for my car but i dont have the wireing manual for it. i need the wire color code sheet
there pretty simple red+ goes to keyed power wire. yello is the same keyed power wire.black ground. speake wire will be like two green two violet one will have black stripe that is the negitive solid color is positive green and green violet ant violet white and white blue and blue youll just have to figure out thr front and rear. blue wire is for amp remote turn on wire your speaker wires may be different colors but same idea
Jun 10, 2009 | Dual XD6210 CD Player
HP Color LaserJet 2600n toner problems
In speaking with other tech support people it appears my image drum needs to be replaced. Also sounds like it will be more economical to buy a new printer.
Feb 19, 2009 | HP Color LaserJet 2600n Printer
Cant print in colour
Not sure if you are using XP or Vista. I'm speaking from Vista but XP should apply, too.
1. You could have the 'Print in Grayscale' box checked. It is under Printing preferences > Color.
2. Your color cartridge may be empty. Print a test page to make sure.
3. Make sure print quality is Normal or Best.
4. There is a "Print all text as Black" in the Advanced tab. Make sure it is Disabled.
Doug DePrenger
www.smartlabsoftware.com
Jan 24, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Color print out of place
Assuming you are asking about colors out of alignment, usually this is due to the card slipping and returning to the corrent position in each pass. I have corrected this problem by thouroghly cleaning all the rollers with an alcohol wipe. With the cover open and the ribbon removed, firmly hold the wipe against the two gray and one black roller while depressing the forward and reverse [power & online buttons] and allowing the rollers to run several revolutions against the wipe. I just use typical medical or first aid wipes, no need for fancy equipment wipes. The alcohol rejuvenates the rollers and keeps them sticky so to speak, so the card is moved correctly. To clean the feed roller, send a card or self test from the driver to the printer with the cover open and the ribbon removed. While you are at it, use a wipe to com[letely clean the metal interior of the printer. Cleanliness is next to godliness when it comes to these printers. ~ Jon
Jul 16, 2008 | Fargo 4250 Thermal Printer
When printing black, the first page comes out in clear black, however subsequent pages are printed in red. In doing a second document the same thing occurs.
Be sure to update your printer drivers with the newest (correct) manufacturer's drivers.
Also, make sure when you print a document you are printing in greyscale. Otherwise, you're wasting your color cartridge. Speaking of which I would try another set of cartridges, and aligning them using the software that came with your printer. Your color cartridge could be malfunctioning.
Mar 25, 2008 | Computers & Internet
Car Audio & Video Logo
13 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
