Question about Leviton Decora Light Dimmer Switch
Just installed a Leviton dimmer. The power is on and the light comes on but does not dim when I slide the lever. Any idea why?
  • svanneste Aug 02, 2010
    Not for a fluorescent fixture, but regular incandescent.
    Brigadier General:
  • 3,301 Answers
If your trying to dim a florescent fixture you need one for those fixtures
Posted on Aug 02, 2010
Leviton dimmer
Your product is not identified by number given.
Leviton posts manuals online by searching Leviton xxxx .pdf.
There is a CPT 602 lighting console
However no result shows online or at Leviton for a 602 dimmer
Contact Leviton:
http://www.leviton.com/OA_HTML/SectionDisplay.jsp?section=37579&minisite=10251
Add a comment and attach photo or video for possible identification
May 27, 2013 | Leviton Electrical Supplies
We have Leviton push button slide dimmers w/the locate lights for power outlets and lights throughout our house. A couple of months ago one stopped working...you push the button to turn it on and it...
Wiring is not best suspect.
If all the Leviton devices were installed same time, they may be failing at same time due to lifespan.
For example, ordinary on-off switch is a mechanical device with mechanical parts, and mechanical switches last many years longer than wiring devices that have electronic parts.
Electronic devices usually have standard 1 year limited warranty.
http://www.leviton.com/OA_HTML/ibeCZzpHome.jsp?minisite=10025&respid=22372
Jun 29, 2011 | Leviton Decora Light Dimmer Switch
Installed a dimmer switch to a light. Put power back on and the light came on. Wouldn't dim however and when I turned it off it would not come back on. fuse is OK
Is the dimmer rating higher than the load? Are you trying to dim fluorescent lamps? A flourescent requires special dimmer switch.
If you over loaded or mis-wired a transistor or wire wound dimmer, you may have damaged it.
Is this a three way light circuit?
May 30, 2011 | Leviton Trimatron Rotary Dimmer 6602-i Lot...
Leviton TrueTouch 600W dimmer 6606-ILM is stuck on high and won't allow dim down. Is the dimmer toast?
Unfortunately with the new electronics, there is not much to do when they go bad. Sometimes they go out and nothing works, sometimes just no dimming. I have had it where I got careless installing one live, and hit the hot to the frame. Worked fine as a switch, but no dimming! Best to replace it.
Feb 19, 2011 | Leviton True Touch Lighting Control
2 n2000 dimmers controlling lights in funeral chapel are in dimming mode horizontal lines appear on video screen increasing in intensity as more dimming is applied. two circuits supply lights with a shared...
I am having the same trouble in my church with two nsi/leviton dimmers. Wide horizontal bar created on video screen during dimming. No bar at 100% or off, just anywhere in between.
Nov 20, 2010 | Leviton Electrical Supplies
The dimmer switch will turn on and off but wont dim the lights on a chandelier. model 6681-w. tried 2 different ones with the same results.
The Leviton 6681 is a push-button rotary-type incandescent dimmer with 600Watt capacity
If you have incandescent bulbs, the dimmer should work.
If the dimmer has different color wires, try reversing the wires.
If the dimmer replaced a 3-way switch, then this is not the right dimmer.
If you have compact florescent bulbs, you need a dimmer that also dims florescent.
http://www.google.com/products/catalog
Link shows the Leviton 6673 incandescent and florescent dimmer
But you also need dimmable compact florescent bulbs.
http://www.amazon.com/DIMMABLE-COMPACT-FLUORESCENT-LIGHT-SPIRAL/dp/B0014B84ZM
Oct 31, 2010 | Leviton #L11-06681-00I Ivory 600 Watt Push...
Leviton slide dimmer switch w/locator light light comes on but doesnt dim
What sort of light is it , dimmer switches normally only work on Incandescent type lights not flourescent type.
Otherwise it sounds as if the dimmer function is faulty.
Nov 02, 2008 | Leviton Decora Light Dimmer Switch
Leviton  Decora Light Dimmer Switch Logo
199 people viewed this question
Top Leviton Electrical Supplies Experts
 Kenneth
Kenneth
Steve
Hippy_dd
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
