Question about Yamaha RX-V390 Receiver
Connecting powered subwoofer to Yamaha Rx-V390
There is no subwoofer out in Yamaha RX-V390. Is there anyway I can connect powered subwoofer to RX-V390?
Thanx
Madhu
  • onat Jul 31, 2008
    i have the rx-v390 for five years now, i'm only using the front l-r speakers and it's working fine, but i'm thinking of upgrading with a sub woofer for extra oomph. is there a way to get through this when there's no specified output for the sub? can i use the center output?
  • Ray Mitchell Dec 30, 2011
    I have the same problem and need bass for my drums, did you manage to get around it?
5 Suggested Answers
  • 236 Answers
SOURCE: Yamaha RX-V1200 subwoofer connection to Mirage BPS-150i subwoofer
just connect your subwoofer mono RCA to your amp sub single out rca connector. you do not need to megre all those 4terminals into one. in fact internal circuit of those 4rca are merging inside to one since the sub uses only a single amp. 4inputs was meant for sources with multiple sub out
Posted on May 03, 2008
  • 133 Answers
SOURCE: connect Airport Express to Yamaha RX- V659
Since you're using a standard mini jack to double RCA cable, it's safe to assume you'll be sending line level signal into your reciever, so i think any of these audio inputs will do: AUX, CD, DVD, MD, TV.
Also try the inputs on the front of the unit (i guess they are meant to be used with a video camera or similar but they are designed for line level signals so it should be ok if you decide to use them).
Anyway, keep the source signal at a moderate
level when you test any of the inputs and raise it to a suitable level after you're sure it is coming thru well.
Normally, the AUX input is suitable for any AUXilliary signal source that puts out a line level signal, but if it is already being used, you may use other free inputs.
If you use TAPE or PHONO inputs, you should keep the signal level from the source a bit lower since these inputs will amplify the signal a bit more (especially the phono input which works with signals that are lower in level than the line signal).
I hope this helps.
Regards
3rq8 (Triarcuate)
Posted on Sep 07, 2009
  • 127 Answers
SOURCE: How to connect the PS3 to RX-V365 to get best
You can connect PS3 video via HDMI to receiver and from receiver via HDMI to TV. But RX-V365 doesn't support HDMI audio, so you have to connect audio separately via SPDIF digital cable. I think PS3 uses optical SPDIF, so you will need optical cable. If you can't find cheaps optical cables in your shop, you can try byuing from ebay ($1-5 max.)
Posted on Mar 02, 2010
ProColorTV
  • 25 Answers
SOURCE: need an drawing showing hou to connect yamaha rx-
Hell Fixya customer,
Here are two links for the Yamaha receiver, and the Sony user manuals.
Please look through them concerning your specific hookup. If you still have questions or need help, please let me know.
http://www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V430e.pdf
http://www.sony.com.au/support/product/kdl-52z5500
Thank you for using Fixya
Posted on May 01, 2010
My rx-v390 will not turn on, only the red LED is turning on...
Sounds like the power transformer is dead. Would have to go in for repair
Jan 04, 2013 | Yamaha RX-V390 Receiver
Rx-v390 when i trun on power after few second auto shut off.. what could be the problem I changed all Fuse (4A 125V) still have same problem.
The problem is with either the Amplifier or the Speakers.
If you disconnect the Speakers and then turn back on and get the same fault then it is the Amplifier.
If it stays on OK then you need to turn off again and connect one Speaker at a time (turning off again between each one) until you find the fault Speaker.
If it is the Amplifier thats faulty then it could be a simple repair that would involve replacing some Capacitors but you would need a Soldering Iron and the knowledge how to de-solder and re-solder components to a PCB.
If you need any further assistance then just ask.
Jul 04, 2011 | Yamaha RX-V390 Receiver
I want to connect my DishNetwork HD receiver to my Yamaha.
Use Digital FiberOptics to connect them best sound you can get one at radioshack its as simple as pluging it into the back of each device it will not plug in wrong
Jan 11, 2011 | Yamaha RX-V390 Receiver
Connecting a subwoofer to a receiver without subwoofer out jack
Does your receiver have any kind of line level audio output? AUX OUT, LINE OUT or similar? If so, you might be able to send that a subwoofer. Most standalone subwoofers have their own crossover and level controls built in, so you can make adjustments there.
Mar 11, 2010 | Yamaha RX-V390 Receiver
My Yamaha RX-V390 receiver when volume turns up it turns off
Does it display something on LCD? Maybe you have connected speakers with wrong impendance and the receiver is overheating.
Check the impedance of speakers, it should be at least 6 ohm. Also check the receiver manual if it has settings for impendace (6 or 8 ohm).
Feb 01, 2010 | Yamaha RX-V390 Receiver
Yamaha RX-V390
Try reseting the Yamaha-Shut the power off, and while holding down presets 1,2 and 3 press power on.
Nov 24, 2008 | Motorola Mobility DRC800 Universal Remote...
Yamaha RX-V850 receiver
how can i hook a subwoofer into yamaha RX-V850
Dec 25, 2007 | Yamaha Audio Players & Recorders
Yamaha rex-v390
Modern home-theater components monitor themselves electronically for potentially dangerous malfunctions such as damaged internal parts. When a unit's microprocessor senses a problem, it will typically shut down so that no further damage -- or potentially dangerous disasters like fire! -- occurs. Your receiver is identifying something upon turn-on and shutting down as a result. My guess is that you're going to need service for your Yamaha. There's likely no fix that you're going to find. You need a professional service technician.
Dec 12, 2005 | Yamaha RX-V390 Receiver
Yamaha RX-V390 Receiver Logo
399 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
