Philips TV Model 32DW6557/05 Screen Problem
I have a Philips TV Model No. 32DW6557/05. The picture horizontal alignment moves across from right to left leaving a black 1 - 2 inches margin. The picture moves back again but not fully. Am I correct in assuming that the Horizontal Synchronization Circuitry is the fault ? If this is the case, does the pcb need replacing ? Can the pcb be repaired ? Does it require specialist tools and knowledge ?
  • Victor Gatenby Apr 27, 2008
    I think that the problem lies with the horizontal sychchronization circuitry board. I would like to invite a qualified technician to confirm this is the case. In the 1960's when TV's had valves, slapping the TV may well have been the answer. I beggar belief that a pcb would respond in such a way. Please do not give me such inane advice!!!
    Scholar:
  • 131 Answers
Hi it sounds like a capacitor in the verticle circuit located on the main board. it is near the verticle ic. the verticle ic also could be bad the cost is around 85 dollars for a tv shop to fix. sometime a cold joint could be found around vert ic. a soldering iron is required with solder.tap the side of tv if picture comes back it is just cold solder joint.
thanks Doctor video
Posted on Apr 25, 2008
  • JAY SOBEL
    JAY SOBEL Apr 27, 2008
    Hi i am a tech. i have a video repair shop since 1987. We fix plasmas lcd tv dlp and crts medical equipment and i am authorized..
    I hope i can help. What i ment by taping the tv if you have a collapsed picture only a horz line that would tell me if picture comes back full .it would be cold solder connection on board and yes we see lots of these problems.
    I will give you a few examples of what it could be.
    I SUSPECT A LEAKY CAPACITOR ON PCB BOARD.
    2.IT COULD BE INTERFERANCE IN TUNER MODULE
    3CHECK FPR NOISE INTERFERANCE FROM TV CONNECTIONS OR HOUSE.
    4 If you have cable box i found them bad because of ps problem diconnect cable box from tv see if that is it.
    disconnect cable box turn it back on thanks Doctor video
I have what appears to be shadowing of the words.. and picture.. blue wave across the top of picture..
Your Convergence ICs are likely failing. It is very common on rear projections. The solution is to replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu. It is about a $300 repair at a tv service center. You will need the service manual if you decide to do this yourself.
Try This:
When you notice the symptons Use this simple test to verify.
Go to the users menu on the tv.
Look for the converge option probably under setup or video setting. Converge is short for convergence to align the red and blue colors to the green color.
If you cannot move the red either horizontal or vertical, then the STK chip has failed for red section.
If you cannot move the blue either horizontal or vertical, then the STK chip has failed for the blue section.
If you can move both in each direction then the problem is something else.
Note if one STK chip fails, you replace both regardless. They will be right next to each other.
Feb 20, 2011 | Hitachi 57SWX20B 57" Rear Projection...
Coloured lines on screen
Make sure first that the picture is centered by using the remote control to move the picture vertically and horizontally. Use the round pad towards the center of the remote and push the button according to which direction you want the frame to move.
Sep 10, 2009 | Philips 42 in. Plasma TV
Red/Orange horizontal lines
it could be that the tv convergence circuit is going bad. One shure way of finding out is to go to the tv feature menu(picture,audio etc.) and select the customer convergence setting, you should get a cross hair pattern(cross in middle of screen). that cross should be white and by aligning the red or blue colors they should move left, right, up or down
Jul 27, 2009 | Akai PT5492S 54" Rear Projection...
Horizontal lines across the top 3 inches of picture
Hi
what line started? from Left to right? or from top to bottom?
Thanks!
Nov 28, 2008 | Philips 32PT6441/37 32" TV
Philips Projection Screen TV Model PTV915 Horizontal Alignment
Problem solved, needed to get the universal remote i was using set up with the proper code. Once I did that I was able to use the remote to set up the single & multi-zone Red & Blue Alignment.  I also pulled the back plate off and manually adjusted the RGB focus knobs. It seems to be working just fine now.
Thanks to all the other posts.
Nov 25, 2008 | Philips 50P8341 50" Rear Projection...
My Siny Trinitron G21M1 is producing horizontal lines across the screen
I hope your TV model is Sony KV-G21M1 and you see color bars as horizontal lines across the screen.
Let me now are you tech guy or know how to repair TV to guide you further.
Oct 26, 2008 | Sony Televison & Video
Picture is too large for the screen, horizontally.
No my friend, there is a problem with the width circuit, and this would be in the pincussion correction circuit of the TV set. There is alot of high voltage in this circuit, and if you have no TV repair experience, play it safe and call in a tech to service this for you. there is not any adjust ment that will fix this. Good Luck
Apr 29, 2007 | Philips 32PT6441/37 32" TV
Televison & Video Logo
218 people viewed this question
Top Televison & Video Experts
