Question about Dell Dimension 8200 PC Desktop
Dell Dimension 8200 Desktop PC shuts off after it has been on for a long time. It shuts off like power has been removed from the CPU although I have an APC hooked up to it.
  • 3 Answers
Sir you should check the power supply of your system.If its working properly then its because of the heat sink of your motherboard...Try to mother heat sink fans in the pc and your problem is solved......
Posted on Aug 03, 2010
Dell dimension 8200 help
A steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Apr 09, 2014 | Dell Dimension 8200 PC Desktop
I havd a Dell Dimension 8200 that sometimes shuts down and power light turns yellow. I can usally open case and plug and on plug to get it to power back up. Recently replaced fans due to fan failure....
Thank for the detail, it really helps...
Most people forget about the power supply. If the power supply overheats, it will shutdown. When shutdown, it will cool off then operate again.
A power supply goes by WATT ratings, the average size power supply is now 450 watts for an average system and should cost around $60.
good luck and don't forget to vote.
Oct 12, 2010 | Dell Dimension 8200 PC Desktop
Dell dimension 5150. wont start
Most times when you have flashing yellow light there is issue ether with cpu or motherboard. Just to be safe test the power supply and if ok then try to replace cpu and go from there. If power supply issue just replace it. Might be easier to take it to pc repair store. Good Luck
Apr 05, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Trying to find the Jumper that controls FSB on a dell dimension 8200. Either that or some form of overclocking software that will allow me to get the full 2.8 out of my P4
modern Boards Auto-Detect FSB speeds, usually determined By CPU fsb And Memory/Ram speeds. It may be Wise to see if theres A user manual/guide for this board. or a possible bios update to support the CPU. also check the boards fsb speed ratings charts. overclocking is not recommended, as this can damage cpu/ram and motherboard.
Mike @ Compurepair.
Oct 29, 2009 | Dell Dimension 8200 PC Desktop
Wiring diagram from the LED power button board to the 0M686 CTRL PNL BOARD on a DELL DIMENSION 8200
Go to the Dell web site and type in you computer information and look for a pdf download for repairing the Dimension 8200. Dell is real good about giving you any information on fixing your computer. And it is usually free. I use them all the time. If you are having problems finding it on there site, you can call them and request the information you need...Hope this helps you,,,Darren
Oct 16, 2009 | Dell Dimension 8200 PC Desktop
Dell dimension 8200 flashing yeloow power button
Please find the complete error codes for dell 8200 and their fixes.
http://support.dell.com/support/edocs/systems/dim8200/codes.htm
This will help you to figure the type of error u are getting and its resolution.
Please feel free to rate this solution link.
Mar 19, 2009 | Dell Dimension 8200 PC Desktop
Trying to install hard drive on Dell Dimension 8200.
Sounds like the drive from the 4700 is a SATA drive which uses a different connector than the 40-pin IDE. I couldn't confirm it, but the 8200 may not have SATA connectors for this type of drive. Although the 4700 appears to have both SATA and IDE.
Dec 07, 2008 | Dell Dimension 8200 PC Desktop
Dell Dimension 8200 Processor
hi, i also hav a dimensions 8200 which i recently uprgaded to a 2.8gh, but i discovered there were two versions of this system one which supports a 400FSB and the other 533FSB, these can determine the speed of ur cpu. Like you, I havent been able to unlock my clock speeds in the bios but i think you should be able to get more from ur new cpu by updating ur bios version to A09. check the dell site for more info on how to do this.
Apr 25, 2008 | Dell Dimension 8200 PC Desktop
Dell Dimension 8200 PC Desktop Logo
55 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
