Question about GE Spacemaker JVM1640SJ Microwave Oven
I have an older microwave oven and the plastic
I have an older GE microwave oven and the plastic cover on the inside of the door is beginning to peel off. I there any danger with this problem? Can I get a replacemnt for the plastic covering?
    Problem Solver:
  • 7 Answers
I wont worry about it. it is for grease ewntrapment
Posted on Aug 03, 2010
Is my microwave safe to use if the inside of the oven is pealing?
Most likely if the metal screen in the door is intact. That screen and the metal cover on the back and sides surrounds the insides of the oven reflect the microwaves back into the oven. Just be careful about the peeling plastic inside.
Jan 26, 2015 | Microwave Ovens
How do i remove the plastic cover to change the light bulb in GE Microwave
Hi, I have a ge modle jvm1631 and mine has two scerws in the front of the cover (can be hard to see in dim light) on some modles you might have to have door open and screws will go in from bottom of cover. Then there is a filter inside that you take out and remove a metal plate that covers bulb.
Mar 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
The plastic cover on the window of the door is peeling. iIs there any danger in this? Other than that the microwave is working perfectly. Does this cover or the microwave have to be replaced?
The plastic cover on the door stops food particles and steam entering the inside part that is not easily cleaned.
That's all.
It is like thick selotape.
Jan 03, 2011 | Emerson 025806092806 Microwave Oven
On the inside of the door of my microwave front window is an adhesive plastic covering that if you pull it off there is a black mesh screen exposed. is that clear sheet suppose to be removed.
The metal mesh is a filter screen to keep the microwaves in the oven while letting you see the food. The plastic sheet that's peeling off is meant to keep that screen clean. It's not supposed to be removed, since then food can get into the holes in the screen. A buildup of foods can lead to overheating and burn the paint and possibly damage the door. It should be replaced.
The part number is WB36X10068. A Google search turned up several sources. Here's one, but there are others. The new sheet has the adhesive applied, you just peel off the protective film and stick it in place. Clean the door inner surface first so the new sheet will stick firmly.
Good luck with the repair, and thanks for using Fixya!
Oct 17, 2010 | Hotpoint RVM1435 Microwave Oven
The inside fan cover started peeling and broke, i can't use the oven and need help!
its the fan inside the oven cavity on top, its part # AP3671492 and is a G.E. part# called the Cover,Stirrer Fan still manufactured
Sep 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Coating is peeling off my microwavww handle????
How nice of them!
Often it is caused by the use of hand cremes affecting and tarnishing the metal coating or the plastic pigments.Many items suffer from handremeitis
including the letters on keyboards car door handles, AC knobs etc etc.
Unfortunately it is the way of life that is associatedkin care and vanity.
Sep 02, 2009 | GE JVM1630 Microwave Oven
Can't clean the inside of the glass door--the screen blocks it
Have to replace the door. You probably removed the protective plastic cover inside the unit intended to keep material from passing through the screen into the area where the glass is located. That was my problem. I thought the plastic was shipping material. My Bad! No way to clean the glass from the inside because they "never imagined" someone would remove the plastic cover.
Nov 10, 2008 | GE XL1800 1100 Watts Microwave Oven
IN CABINET MICROWAVE
Hello JudyKitz,
That mesh is there to protect the user and acts as a shield to contain microwave energy to the cooking compartment. Never compromise that material.. You can purchase replacment liners at this site http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5130353 If you prefer, you can get a thin piece or sheet plastic cut to fit at many local hardware stores or home centers..You may want to make a paper template or take accurate measurements with you for that method.. Hope this helps you..
Oct 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Can't see inside oven
yes, the tape is simply there to protect the face until the consumer gets the product home.
Jun 01, 2008 | GE JES1358 Microwave Oven
Hole in plastic on inside of door
check the conductivity of the plastic with an ohmmeter by placing the probes an inch apart on the plastic surface. If the resistance is large or infinity, the plastic probably performs no role in stopping the microwave radiation. If so, any epoxy probably can be used to close the hole safely. Make sure you don't use too much and if possible place tape over the repair and orient the microwave so the epoxy presses against the tape while drying to prevent it from oozing into any door hinge/close mechanism. Otherwise, a piece of microwave door glass from a broken unit can ge glued over the hole and should stop the radiation. You can check for leakage with test units but be very carefuly anyway.
Nov 30, 2007 | GE JVM1650 1000 Watts Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
